Trying to Battery Power my Nano 33 BLE Sense Rev2 with TP4056 and MT3608, but doesn't work
Hi everyone,
I'm trying to power my Arduino Nano 33 BLE Sense Rev2 using a 3.7V LiPo battery (with protection circuit), but I keep running into problems. Here’s what I’m doing:
My setup:
I connect the 3.7V LiPo battery (protected) to the TP4056 charging module via the JST connector and the TP4056's OUT+ and OUT- to the MT3608 boost converter's VIN+ and VIN-, respectively. THE MT3608's VOUT+ and VOUT- go into the Nano's VIN and GND. MT3608 boost converter is set to 5V.
What happens:
When I connect the battery to the TP4056, and TP4056 to MT3608, the charger gets very hot. If I instead connect MT3608 output to the 3.3V pin, it doesn't get hot—but the Nano doesn't turn on either. When I connect only USB to the TP4056 (no battery), the charging LED behaves normally.
I’ve checked:
  • Battery is charged and fine.
  • I2C sensors work when I power Nano via USB.
  • The MT3608 module output has a trimmer pot, but I don’t have a multimeter yet to check if it’s outputting 5V correctly.
Questions:
  1. Is it safe to power the Nano 33 BLE Sense Rev2 via VIN using a boosted 5V from the MT3608?
  2. Could the MT3608 or TP4056 be faulty, or is this likely a wiring/power draw issue?
  3. Is there a simpler or more reliable battery setup for this board that still allows USB charging?
Thanks in advance for any suggestion!
What is the purpose of the TP4056?
Hi! I use the TP4056 to safely charge the 3.7V LiPo and protect from overcharging etc. not to directly power the Nano 33 BLE. For that, the battery output goes via a boost converter to the Nano's VIN.
I know I could power the Nano directly from the LiPo through the VIN, but I thought it would be better to use the TP4056 for extra safety.
You may want to search the forum for more up to date info about that power circuit. Start here https://forum.arduino.cc/t/at-last-18650-charge-boost-module-with-load-sharing/1164462/5?u=sonofcy
You need to get a multi-meter so you can adjust the boost module.
Thank you!
Well that could be a problem don't you think?
Good way to destroy your nano ESP.
First thing you need to do is buy a DMM.
Hi Jim, thanks a lot, will do!
I'm not a big fan of the boost or buck converters with adjustable pots, to easy to make a mistake when experimenting.
