Hello all
I have a PCB which has an ATMEGA328pb chip on it with external 8Mhz crystal.
I am trying to burn a bootloader onto it so I can use it with Arduini IDE. I am using an UNO as an ISP, with pin 10 connected to RST on the PB (with 10k resistor connected between RST and GND), pin 11/12/13 connected to the same pins on the PB, but unsure which board to select. I have tried the board "Arduino Pro or Pro Mini" with processor Atmega328 (3v3, 8Mhz), but get the following errors when I attempt to burn the bootloader:
Arduino: 1.6.7 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
C:\Users\Chris Laptop\Desktop\Sigfox\Arduino\arduino-1.6.7-windows\arduino-1.6.7\hardware\tools\avr/bin/avrdude -CC:\Users\Chris Laptop\Desktop\Sigfox\Arduino\arduino-1.6.7-windows\arduino-1.6.7\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM8 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Chris Laptop\Desktop\Sigfox\Arduino\arduino-1.6.7-windows\arduino-1.6.7\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9516
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
enabled in File > Preferences.
Can anyone advise how I can burn loader onto my atmega328pb with 8Mhz external clock?
