Trying to control a relay based on NTP time...
Hey there! I'm semi-noob so, I apologize if my question/ problem is basic.
I am trying to get an Arduino to sync time with network time. (A local network NTP server).
And then based on that time Open/Close a relay every 5 seconds past the hour, every hour.
So, at:
1:00:05AM - Close relay for 10 seconds, open relay
2:00:05AM - Close relay for 10 seconds, open relay
3:00:05AM - Close relay for 10 seconds, open relay
etc.
I can get it to control the relay, and I can get it to sync to NTP time, but I can't get it to do both.
Any suggestions?
See the following code: (When compiling I get "'alarm1' was not declared in this scope".)
Thanks in advance.
Arduino UNOr3
Ethernet shield
2 Relay Module and ZS-042 Real Time Clock module - DS3231
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <TimeLib.h>
#include <TimeAlarms.h>
/* ******** Ethernet Card Settings ******** */
// Set this to your Ethernet Card Mac Address
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x23, 0x36 };
/* ******** NTP Server Settings ******** */
/* us.pool.ntp.org NTP server
   (Set to your time server of choice) */
IPAddress timeServer(192, 168, 11, 66);
/* Set this to the offset (in seconds) to your local time
   This example is GMT - 8 */
const long timeZoneOffset = -28800;
/* Syncs to NTP server every 15 seconds for testing,
   set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 3600;
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
time_t prevDisplay = 0;
int RELAY1 = A0;
int RELAY2 = A1;
int delayValue = 1000;
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  digitalWrite(RELAY1, HIGH);
  digitalWrite(RELAY2, HIGH);
 Alarm.alarmRepeat(0,0,5,alarm1);
 Alarm.alarmRepeat(1,0,5,alarm1);
 Alarm.alarmRepeat(2,0,5,alarm1);
 Alarm.alarmRepeat(3,0,5,alarm1);
 Alarm.alarmRepeat(4,0,5,alarm1);
 Alarm.alarmRepeat(5,0,5,alarm1);
 Alarm.alarmRepeat(6,0,5,alarm1);
 Alarm.alarmRepeat(7,0,5,alarm1);
Alarm.alarmRepeat(8,0,5,alarm1);
 Alarm.alarmRepeat(9,0,5,alarm1);
 Alarm.alarmRepeat(10,0,5,alarm1);
 Alarm.alarmRepeat(11,0,5,alarm1);
 Alarm.alarmRepeat(12,0,5,alarm1);
 Alarm.alarmRepeat(13,0,5,alarm1);
 Alarm.alarmRepeat(14,0,5,alarm1);
 Alarm.alarmRepeat(15,0,5,alarm1);
 Alarm.alarmRepeat(16,0,5,alarm1);
 Alarm.alarmRepeat(17,0,5,alarm1);
 Alarm.alarmRepeat(18,0,5,alarm1);
 Alarm.alarmRepeat(19,0,5,alarm1);
 Alarm.alarmRepeat(20,0,5,alarm1);
 Alarm.alarmRepeat(21,25,5,alarm1);
 Alarm.alarmRepeat(22,0,5,alarm1);
 Alarm.alarmRepeat(23,0,5,alarm1);
   // Ethernet shield and NTP setup
   int i = 0;
   int DHCP = 0;
   DHCP = Ethernet.begin(mac);
   //Try to get dhcp settings 30 times before giving up
   while( DHCP == 0 && i < 30){
     i++;
   if(!DHCP){
    Serial.println("DHCP FAILED");
     for(;;); //Infinite loop because DHCP Failed
   Serial.println("DHCP Success");
   //Try to get the date and time
   int trys=0;
   while(!getTimeAndDate() && trys<10) {
     trys++;
// Do not alter this function, it is used by the system
int getTimeAndDate() {
   int flag=0;
   Udp.begin(localPort);
   sendNTPpacket(timeServer);
   if (Udp.parsePacket()){
     Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
     unsigned long highWord, lowWord, epoch;
     highWord = word(packetBuffer[40], packetBuffer[41]);
     lowWord = word(packetBuffer[42], packetBuffer[43]);
     epoch = highWord << 16 | lowWord;
     epoch = epoch - 2208988800 + timeZoneOffset;
     flag=1;
     setTime(epoch);
     ntpLastUpdate = now();
   return flag;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
// Clock display of the time and date (Basic)
void clockDisplay(){
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
// Utility function for clock display: prints preceding colon and leading 0
void printDigits(int digits){
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
// This is where all the magic happens...
    // Update the time via NTP server as often as the time you set at the top
    if(now()-ntpLastUpdate > ntpSyncTime) {
      int trys=0;
      while(!getTimeAndDate() && trys<10){
        trys++;
      if(trys<10){
        Serial.println("ntp server update success");
      else{
        Serial.println("ntp server update failed");
    // Display the time if it has changed by more than a second.
    if( now() != prevDisplay){
      prevDisplay = now();
      clockDisplay();
void alarm1(){
    digitalWrite(RELAY1, LOW);
  Serial.println("LAFF Channel ID ON");
  digitalWrite(RELAY2, LOW);
    Serial.println("COURT TV ID ON");
  alarm.delay(10000);   //10 Seconds (10000 Milliseconds): Both relays ON
  Serial.println("LAFF Channel ID OFF");
   Serial.println("COURT TV ID OFF");
Why are you using these crutches? You know what time it is. You know when you want to do something. If the current time is the target time, do what needs doing.
what is alarm1? if it is a variable where did you declare it?
this would drive an OCD person into a howling frenzy:
I know, I know. It bothers me too. I will clean it up once I get it functioning.
void alarm1(){
Technically "alarm1" should set Relay 1 and 2 to "LOW"... or at least thats what I want it to do.
Its a function to be called when the alarm goes off.
