Trying to display an requisted IP address on an LCD screen but the script stops
Hello i'm new when it comes to programming with Arduino and I have a queston about a script i can't seem to get working.
I am using an Arduino Uno with an Ethernet shield and I am trying to requist an IP using the DHCP server and displaying it on a LCD screen.
I have 2 seperate scripts. The first where I show some random variables on my LCD screen and the second is where I requist an IP.
Both work, I can print the IP the Arduino got assigned and I get a reply when I ping it. But when I try to combine both scripts it just stops at the point where I use Ethernet.localIP(); as far as I can tell.
For the DHPC script I have followed this tutorial:
https://www.inkling.com/read/arduino-cookbook-michael-margolis-2nd/chapter-15/recipe-15-2
And for the LCD screen i'm following chapter 11 of the Arduino projects book and this:
https://www.inkling.com/read/arduino-cookbook-michael-margolis-2nd/chapter-11/recipe-11-1
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Ethernet.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
IPAddress myIPAddress;
  lcd.begin(16,2);
  lcd.clear();
   // start ethernet using mac & DHCP
   // if this is not possible
   if(!connection)
      Serial.println("Failed to configure Ethernet using DHCP");
      lcd.print("DHCP requist");
      lcd.setCursor(0, 1);
      lcd.print("Failed");
      // no point in carrying on, so stay in endless loop:
      while(true);
    // show that the IP needs to be requisted from the DHCP server
     Serial.println("Requisting IP");
     lcd.print("Requisting IP");
     lcd.setCursor(0,1);
     lcd.print("Waiting for DHCP");
   // requist IP
   ip();
   // show the IP
   lcd.clear();
   lcd.setCursor(0, 0);
   lcd.print("The IP is:");
   lcd.print(myIPAddress);
   Serial.println(myIPAddress);
// using ethernet with mac & dhcp
boolean connection()
  if(Ethernet.begin(mac) == 0)
    return false;
    return true;
// requisting ip
void ip()
   Serial.println("Now requisting IP"); // I receive this print
   myIPAddress = Ethernet.localIP();
   Serial.println("IP requist succesfull"); // I don't receive this or anyting after this
What is supposed to be serving you the IP address? Do you have a DHCP server set up?
PaulS:
The LCD screen is supposed to show the IP that was assigned.
And yes the DHCP server works.
If I use only this code on my Arduino then I get an IP wich I get a reply from if I ping it.
#include <SPI.h>
    while(true)   // no point in carrying on, so stay in endless loop:
  delay(1000); // give the Ethernet shield a second to initialize
  Serial.print("This IP address: ");
  IPAddress myIPAddress = Ethernet.localIP();
  Serial.print(myIPAddress);
So, modify that code to display that value on the LCD.
Paying attention to which pins you can't use (the SPI pins, for example) will pay dividends.
Thats is exactly what I have been trying to do, see code I posted above, but for some reason anything that comes after this line myIPAddress = Ethernet.localIP(); doesn't get executed.
Part of the script I posted above:
// requisting ip
void ip()
Your LCD is connected to the SPI pins, if you are using a 328-based Arduino. That CAN NOT be.
PaulS:
I finnaly understand what you meant. I changed the two SPI pins 12 and 11 to 9 and 8 and now it works.
Thank you for your reply.
