Trying to get ESP32 into sleep mode
Hello all, I'm new into the forum, so I'm sorry if I don't follow the rules properly.
After this, I will explain what is my problem.
I'm using an ESP32 with a GY-521 MPU6050, with the purpose of fall detection. The device has a power comsuption of 80mA while working, as I'm using a 600mAh battery to power it on, I have an autonomy of 7 hours theorically.
I thought of using the sleep mode of the ESP32 as well as the INT pin of the MPU6050 in order to wake up the MCU only when there is a movement. I've been looking all around the different forums but I can't get a clear answer in terms of coding.
Here is my code:
// Standard Libraries - Already Installed if you have ESP32 set up
#include <WiFi.h>
#include <FS.h>
#include <PubSubClient.h>
// Additional Libraries - each one of these will need to be installed.
#include <WiFiManager.h>
// Captive portal for configuring the WiFi
// Can be installed from the library manager (Search for "WifiManager", install the Alhpa version)
// https://github.com/tzapu/WiFiManager
#include <ESP_DoubleResetDetector.h>
// A library for checking if the reset button has been pressed twice
// Can be used to enable config mode
// Can be installed from the library manager (Search for "ESP_DoubleResetDetector")
//https://github.com/khoih-prog/ESP_DoubleResetDetector
// -------   Other Config   ------
#include <Wire.h>
#include <MPU6050.h>
#define BUZZER_PIN 14
#define BUZZER_CHANNEL 0
#define BEEP_DURATION 5000 // 1 second (in milliseconds)
#include "time.h"
const int PIN_LED = 2;
// Number of seconds after reset during which a
// subseqent reset will be considered a double reset.
#define DRD_TIMEOUT 10
// RTC Memory Address for the DoubleResetDetector to use
#define DRD_ADDRESS 0
DoubleResetDetector *drd;
unsigned long button_time = 0;
unsigned long last_button_time = 0;
const float fallThreshold = 650000; // Adjust this value to suit your needs (in m/s^3)
const int sampleInterval = 10;   // Interval in milliseconds between readings
float prevAccX = 0.0, prevAccY = 0.0, prevAccZ = 0.0;
const char* ntpServer = "in.pool.ntp.org";
const long  gmtOffset_sec = 106200;
const int   daylightOffset_sec = 0;
char dateTimeStr[30];
bool buttonInterrupted = false;
unsigned long delayStartTime = 0;
const int DOUBLE_PRESS_THRESHOLD = 1500; // Time threshold for double press in milliseconds
bool lastFallDetection = false;
unsigned long lastFallTime = 0;
struct Button {
    const uint8_t PIN;
    uint32_t numberKeyPresses;
    bool pressed;
Button button1 = {12, 0, false};
MPU6050 mpu;
void printLocalTime(){
  struct tm timeinfo;
  if(!getLocalTime(&timeinfo)){
    Serial.println("Failed to obtain time");
    return;
  // Print only the current day and time
  strftime(dateTimeStr, sizeof(dateTimeStr), "%A, %B %d %Y %H:%M:%S", &timeinfo);
void IRAM_ATTR isr() {
  button_time = millis();
  if (button_time - last_button_time > 250){
    button1.numberKeyPresses++;
    button1.pressed = true;
    last_button_time = button_time;
    buttonInterrupted = true; // Set the flag to indicate button press
///////////AÑADIDOS///////////////
#include <Preferences.h>
//#include <nvs_flash.h>
Preferences preferences;
WiFiClient espClient;
PubSubClient client(espClient);
#define NUMERO_SONDA "1"
#define TOPIC_X "homeassistant/" NUMERO_SONDA "/JerkX"
#define TOPIC_Y "homeassistant/" NUMERO_SONDA "/JerkY"
#define TOPIC_Z "homeassistant/" NUMERO_SONDA "/JerkZ"
#define TOPIC_X_ac "homeassistant/" NUMERO_SONDA "/AceleracionX"
#define TOPIC_Y_ac "homeassistant/" NUMERO_SONDA "/AceleracionY"
#define TOPIC_Z_ac "homeassistant/" NUMERO_SONDA "/AceleracionZ"
#define TOPIC_CAIDA "homeassistant/" NUMERO_SONDA "/caida"
#define TOPIC_SQRT "homeassistant/" NUMERO_SONDA "/raiz"
const char* ssid = "xxxx";
const char* password = "xxxx";
const uint8_t sda = 4;
const uint8_t scl = 5;
  Wire.begin(sda, scl);
  // Initialize MPU6050
  mpu.initialize();
  // Verify the connection
  Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  pinMode(button1.PIN, INPUT_PULLUP);
  attachInterrupt(button1.PIN, isr, FALLING);
  pinMode(PIN_LED, OUTPUT);
  delay(10);
  digitalWrite(PIN_LED, HIGH);
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  preferences.begin("credentials", false);  // "credentials" es el espacio de preferencias
  String mqttBrokerIP = preferences.getString("mqttBrokerIP","");
  // Conectar al broker MQTT
  client.setServer(mqttBrokerIP.c_str(), 1883);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  if (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
  Serial.println("");
void reconnect() {
  // Loop until we're reconnected
  if (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(NUMERO_SONDA, xxxx, xxxx)) {
      Serial.println("connected");
      // Subscribe
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
      String mqttBrokerIP = preferences.getString("mqttBrokerIP", "");
    if (mqttBrokerIP.length() == 0 || Serial.available() > 0) {
    // Pedir la dirección IP del broker MQTT por el puerto serie
    Serial.println("Introduce la IP del broker MQTT:");
    while (!Serial.available()) {
    mqttBrokerIP = Serial.readStringUntil('\n');
    // Guardar la IP en preferencias
    preferences.putString("mqttBrokerIP", mqttBrokerIP);
    Serial.print("Broker MQTT IP guardado en preferencias: ");
    Serial.println(mqttBrokerIP);
    Serial.println("Por favor, reinicie la sonda");
  static unsigned long lastTime = 0;
  // Read accelerometer data
  if (millis() - lastTime >= sampleInterval)
    lastTime = millis();
    int16_t ax, ay, az;
    mpu.getAcceleration(&ax, &ay, &az);
    Serial.print(";Eje X sin correccion; ");
    Serial.print(ax);
    Serial.println(";");
    Serial.print(";Eje Y sin correccion; ");
    Serial.print(ay);
    Serial.print(";Eje Z sin correccion; ");
    Serial.print(az);
    // Convert accelerometer readings from m/s^2 to mg (1 g = 9.8 m/s^2)
    float acceleration_mg_x = ax / 9.8;
    float acceleration_mg_y = ay / 9.8;
    float acceleration_mg_z = az / 9.8;
    client.publish(TOPIC_X_ac, String(acceleration_mg_x).c_str());
    client.publish(TOPIC_Y_ac, String(acceleration_mg_y).c_str());
    client.publish(TOPIC_Z_ac, String(acceleration_mg_z).c_str());
    // Calculate jerk by taking the derivative of acceleration with respect to time
    float jerkX = (acceleration_mg_x - prevAccX) / (sampleInterval / 1000.0);
    float jerkY = (acceleration_mg_y - prevAccY) / (sampleInterval / 1000.0);
    float jerkZ = (acceleration_mg_z - prevAccZ) / (sampleInterval / 1000.0);
    Serial.print(";Eje X con correccion; ");
    Serial.print(acceleration_mg_x);
    Serial.print(";Eje Y con correccion; ");
    Serial.print(acceleration_mg_y);
    Serial.print(";Eje Z con correccion; ");
    Serial.print(acceleration_mg_z);
    // Update previous acceleration values for the next iteration
    prevAccX = acceleration_mg_x;
    prevAccY = acceleration_mg_y;
    prevAccZ = acceleration_mg_z;
    client.publish(TOPIC_X, String(jerkX).c_str());
    client.publish(TOPIC_Y, String(jerkY).c_str());
    client.publish(TOPIC_Z, String(jerkZ).c_str());
    // Calculate the magnitude of jerk
    float jerkMagnitude = sqrt(jerkX * jerkX + jerkY * jerkY + jerkZ * jerkZ);
    client.publish(TOPIC_SQRT, String(jerkMagnitude).c_str());
    //Serial.println(jerkMagnitude);
    // Check for a fall
    if (jerkMagnitude > fallThreshold)
      // Caida detectada
      Serial.println("Fall detected!");
      client.publish(TOPIC_CAIDA, "true");
      // Reset the buttonInterrupted flag
      delayStartTime = millis();
      while (delayStartTime > 0 && millis() - delayStartTime < BEEP_DURATION)
        if (button1.pressed)
          button1.pressed = false;
          Serial.println("Buzzer stopped by button press.");
      if (!buttonInterrupted) {
      // No se ha presionado el boton, mandando señal de caida
      delayStartTime = 0;
      if (delayStartTime > 0)
        delayStartTime = 0;
      Serial.printf("Stop Button was pressed %u times\n", button1.numberKeyPresses);
  if (WiFi.status() != WL_CONNECTED){
    setup_wifi();
      reconnect();
    client.loop();
Thanks in advance.
a clear answer to which question?
Did you start with a simple asic program, without the WiFi, MPU6050 etc etc, that just put the ESP32 into a timed deep sleep or a switch wake up deep sleep ?
Hello, I tried this code from another webpage with no results: esp8266-sensor-mpu6050/GY521_interrupt/GY521_interrupt.ino at master · rondawg369/esp8266-sensor-mpu6050 · GitHub
const uint8_t MPU_addr=0x68;  // I2C address of the MPU-6050
MPU6050 testUnit(MPU_addr);
const byte interruptPin = D7;
const uint8_t threshold = 20;
const uint8_t duration = 10;
  Wire.begin();
  Serial.println("I'm Awake!");
  Serial.print("Motion detect Status : "); Serial.println(testUnit.getMotionStatus(),BIN);
  setupMotionInt();
  testUnit.setInterruptLatch(0);
  testUnit.setInterruptLatchClear(0);
  testUnit.setInterruptDrive(0);
  testUnit.setInterruptMode(1);
  Serial.println(testUnit.getInterruptMode());
  Serial.println(testUnit.getInterruptDrive());
  Serial.println(testUnit.getInterruptLatch());
  Serial.println(testUnit.getInterruptLatchClear());
  Serial.println("Going to sleep. . .");
  ESP.deepSleep(0);
void setupMotionInt(){
   testUnit.initialize();
  Serial.println(testUnit.testConnection());
  // Ensure the accelerometer is running
  testUnit.setSleepEnabled(false);
  testUnit.setWakeCycleEnabled(false);
  testUnit.setStandbyXAccelEnabled(false);
  testUnit.setStandbyYAccelEnabled(false);
  testUnit.setStandbyZAccelEnabled(false);
  //Set the accelerometer HPF to reset settings
  testUnit.setDHPFMode(MPU6050_DHPF_RESET);
  //Set the accelerometer LPF to 256Hz Bandwidth
  testUnit.setDLPFMode(MPU6050_DLPF_BW_256);
  //Enable the motion interrupt
  testUnit.setIntEnabled(0b00000000);
  testUnit.setIntMotionEnabled(true);
  //Set the motion detection duration
  testUnit.setMotionDetectionDuration(duration); //Duration in ms
  //Set the motion detection threshold
  testUnit.setMotionDetectionThreshold(threshold); // Threshold in 2mg
  //1 ms delay
  delay(1);
  //Set the accelerometer HPF to HOLD settings
  testUnit.setDHPFMode(MPU6050_DHPF_HOLD);
  // Set the wakeup frequency
  testUnit.setWakeFrequency(MPU6050_WAKE_FREQ_5);
  testUnit.setStandbyXGyroEnabled(true);
  testUnit.setStandbyYGyroEnabled(true);
  testUnit.setStandbyZGyroEnabled(true);
  // Enable cycle mode
  testUnit.setWakeCycleEnabled(true);
I attach the INT pin from the MPU6050 to the interruptPin with no results.
