Good evening everyone,
this is my first post here since I am at my wits end and I thought "maybe the wise people of the Arudino forum might be able to help me"
Basically I have a Funduino Pulse sensor connected to a ESP32S3 by Xiao and I am getting an analog Signal, calculating a Threshold, then comparing it to a new Signal and then checking if its bigger then the Threshold. Then delta gets calculated and I get a BPM. However my issue is that Delta is always huge so my BPM is just like 5 or 0, 19 if I´m lucky haha. I have some other things connected aswell since my goal was essentially to creat a "less smart smartwatch" but for now I will share my Pulse() and some stuff from my loop and main
my Pulse():
summe = 0;
sQuadrate = 0;
final_abweichung = 0;
int Threshold;
static unsigned long lastThresholdUpdate = 0;
if (millis() - lastThresholdUpdate > 500) {// nur allle 2 Sekunden neu
lastThresholdUpdate = millis();
// Signal = analogRead(PulsSensorPin);
for (int i = 0; i < Messwerte; i++) {
signale\[i\] = analogRead(PulsSensorPin); // Arduino (where the ADC range is 0-1023) but in case of ESP32 the ADC values are 0-4095.
delay(5); // Kleine Pause
for (int i = 0; i < Messwerte; i++){
summe += signale\[i\];
schnitt = summe / Messwerte; // schnitt berechnen
for (int i = 0; i < Messwerte; i ++){
abweichung\[i\] = sq(signale\[i\] - schnitt); // Abweichungen quadrieren
sQuadrate += abweichung\[i\]; // Summe der Quadrate
sQuadrate_neu = sQuadrate / Messwerte;
final_abweichung = sqrt(sQuadrate_neu); // finale abweichung sqrt
//Threshold = (schnitt + final_abweichung) \* 0.8;
Threshold = schnitt + final_abweichung \* 0.1;
Serial.println("Threshold");
Serial.println(Threshold);
int aktuellesSignal = analogRead(PulsSensorPin);
//int aktuellesSignal = signale\[Messwerte - 1\];
static bool warUeberThreshold = false;
Serial.print("aktuelles signal: ");
Serial.println(aktuellesSignal);
if
(aktuellesSignal >= Threshold && !warUeberThreshold ){ //&& warUeberThreshold == false
warUeberThreshold = true;
unsigned long currentTime = millis();
unsigned long delta = currentTime - lastBeatTime;
Serial.println("delata");
Serial.println(delta);
if (delta > 300 ) { // schützt vor Doppelzählung && delta < 1500
BPM = 60000 / delta;
lastBeatTime = currentTime;
Serial.print("BPM: ");
Serial.println(BPM);
and some of my main and loop:
int PulsSensorPin = A2;
int Signal; // holds the incoming raw data. Signal value can range from 0-4095
const int Messwerte = 200;
int signale\[Messwerte\];
int abweichung\[Messwerte\];
int sQuadrate;
int sQuadrate_neu;
int final_abweichung;
int schnitt;
int summe;
loop:
//Clock();
Puls();
//Pedometer();
static unsigned long lastPedUpdate = 0;
if (millis() - lastPedUpdate > 10000) {
lastPedUpdate = millis();
Pedometer();
static unsigned long lastOxiUpdate = 0;
if (millis() - lastOxiUpdate > 10000) {
lastOxiUpdate = millis();
Oximeter();
//delay(10);
displayBatteryLevel();
//myMessage.now = rtc.now();
myMessage.zeit = rtc.now().unixtime();
myMessage.oxygen = spo2;
myMessage.heartrate = hr;
strncpy(myMessage.schritte, report, sizeof(myMessage.schritte));
//myMessage.schritte \[256\] = report;
myMessage.puls = BPM;
myMessage.gespeicherteSteps = savedSteps;
myMessage.volt = voltage;
myMessage.prozent = percent;
myMessage.test = 5;
esp_err_t result = esp_now_send(receiverAddress, (uint8_t \*) &myMessage, sizeof(myMessage));
Serial.println("result:");
Serial.println(result);
if (result != ESP_OK) {
Serial.println("Sending error");
all the data gets send over to a reciever device so I can dispaly the data on a little screen, thats where the ESPNow comes from.
I hope there is someone that can offer some advice and if you need more info lmk ![]()
Thank you all in advance!!!
