Trying to measure milliamps.
I brought a pack of 5, 30 amp model, ACS712 modules for monitoring current draw for a solar panel project . I am looking for measuring a current draw of 250mA
Without even hooking into the arduino and just measuring the Vout pin of the module, a current in the range of 0-150mA will not do that much change to the Vout (it holds at 2.51) ,in fact all I get in the voltmeter is 10mV of a change. I am coming to the conclusion that this module is only useful for current in the Amp range instead of milliamps.
What I'm looking for is a module caple of measuring down to 10mA.
Sidenote:
Ive also noted that I only get the 0 current voltage of 2.5 volts if the grounds are tied together...meaning that the circuit that passes through the hall affect sensor must also have a ground connected into the arduino.
If I don't do this the Vout drops from 2.5 to 100mV as if it were to indicate a negative current flow.
Correct.
To measure small currents you can use a resistor and the Arduino ADC with the 1.1V internal reference. A 2.0 Ohm resistor in the solar panel ground lead will lead to a full scale (1023) reading of about 550 mA.
For 10 mA resolution, you could go as low as 0.1 Ohm.
Thanks for you reply.
Though I must understand that using the 1.1volt reference means then that anything at 1.1volt will be considered 1023, correct?
If so I understand then I will also have to recalibrate the voltage dividers reading voltages of the solar panel and battery.
Though it isn't clear to me could I call the analogreference for a specfic port or does it affect all of them?
Also correct. All the ADC pins use the same analog reference, but you can switch back and forth between references.
I suggested to use the 1.1V internal reference for measuring the current because that allows you to use a low value resistor as the current sensor. You can certainly use the 5V reference, but the resolution will be poorer.
With a 2 Ohm resistor, 250 mA would produce a voltage drop of 0.5V, or an ADC reading of about 100 using the 5V reference (2.5 mA per step).
AFAIK Arduino ground has to connect to the solar side of the shunt if you want a positive voltage on the analogue input. Not sure about the implications if you charge a battery and power the Arduino with that when the sun goes down. There will now be a negative voltage on the analogue input.
Leo..
