I have an Arduino UNO that burned up, so I bought 5 new ATMEGA328 micros. I also have an Arduino Mega 2560 board and used it to burn the bootloader onto the UNO board with a new chip in place.
The bootloader process seemed to work and now when I hit the Reset button the LED flashes and seems to reset. However I cant seem to get the board to accept a new program, I get the following error:
avrdude: stk500_getsync(): not in sync: resp=0x00
After some research I tried the Loop back test. It works with the Mega but not with the UNO. This may not matter but I also tested the voltages on the 5 and 3.3 pins and it check out.
I was hoping for some ideas and what do try next to fix the board.
I have a bread board and I am not afraid to solder and order components.
Thanks for your help!
(Fixing this, for me its about learning, not about cost/time invested)
Any idea if USB interface chips come pre-programmed or how to burn them after installing it. I am not sure if my skills are quite that good either but I will probably give it a shot as I enjoy soldering, if we think that is the mostly next step.
As far as programming it through the ICSP, To test this I am using the default blink program.
Do I still program it with the same setup as when burning the boot loader? I tried this a couple of times, using the Mega to program the UNO. I did see the LED by the L blink presumably when the Mega reset the UNO, after a few seconds I see this message pop up again:
I find it odd that I can seemingly upload the boot loader as evident that the reset button works but I cant seem to load programs. Is there an extra step I am missing somewhere?
When you're programming via ICSP you need to set the programmer to Arduino as ISP and then click File - upload using programmer, or more confident press ctrl+shift+u.
Miasmictruth:
The bootloader is on the main chip (the Atmega328P). The serial data it reads comes through the USB chip (the Atmega8U2). So it's not that surprising.
