Trying to segregate serial data and drive outputs
Good Day,
I am reading a serial value eg: ?A123.45?B246.80, and I am trying to read them as 123.45 and 246.80.
The setup is almost there, but for some reason, the "B value" 246.80 value is being ignored.
Appreciate the help....
Code is mostly credited to jimspage.co.nz
void QUESTION(){ // The first identifier was "?"
CodeIn = getChar(); // Get another character
switch(CodeIn) { // Now lets find what to do with it
case'A':                                  // Found the second identifier ("N" Eng 2 Temp position)
  egtb = "";
  egtb += getChar();
  egtb += getChar();
  egtb += getChar();
  int egtbi = egtb.toInt();               // convert it to an integer
  egtbangle = egtbi*5;                    // Range calculation to suit servo 180deg.
  egtbServo.write(egtbangle);             // Scaled output to servo
                                                 // WORKS UP TO HERE,
   break;                                  //THIS IS WHERE THE PROGRAM STOPS??? NEED HELP. THANKS
case'B':                                  // Found the second identifier ("V" Fuel Flow 1 position)
  ffa = "";
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  int ffai = ffa.toInt();                 // convert it to an integer
  ffaangle = ffai+ffai*(1./2.);           // Range calculation to suit servo 180deg.
  ffaServo.write(ffaangle);               // Scaled output to servo
toInt() likely returns 0 if you give it a floating point string.
Alan
You could grab the entire string into a c string buffer. Then use strtok() to slice it up. That would give you the two numbers preceded by the A & B letters. At that point you can point at the next char and pass that into atof() for a float version of the number.
-jim lee
Thanks for the response,
The case A works, writing to the servo. When I // the case A code, case B works, writing to the servo.
It seems that the first expression "A" is read and processed, but the second expression "B" is ignored?
Appreciate your thoughts?
Thanks
Hi, @mapain
Welcome to the forum.
To add code please click this link;
What model Arduino are you using?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Reading in the whole set of chars first is that way to go.
Arduino Software Solutions has numerous examples of reading from Serial and then parsing.
Using atof() or my SafeString toFloat() methods are the way to go after parsing out numbers
A fuller sketch would help us sort out what is happening.
Good Day Tom,
Thanks for the heads up on the forum.
As asked for I am using Arduino UNO.
I have only spent a few weeks on the Arduino programming, doing excercises etc., but challenged by what I hope to achieve within my project, just don't quite know how?
Cheers,
Mark
#include <Servo.h>
Servo flapsServo;
Servo proparpmServo;
Servo egtbServo;
Servo ffaServo;
Servo ffbServo;
Servo adfServo;
int CodeIn; // used on all serial reads
int KpinNo;
int Koutpin;
String flaps;
String proparpm;
String egtb;
String ffa;
String ffb;
String adf;
int flapsangle;
int proparpmangle;
int egtbangle;
int ffaangle;
int ffbangle;
int adfiangle;
String KoldpinStateSTR, KpinStateSTR, Kstringnewstate, Kstringoldstate;
Kstringoldstate = "111111111111111111111111111111111111111111111111111111111111111111111";
for (int KoutPin = 2; KoutPin < 20; KoutPin++) // Get all the pins ready for "Keys"
pinMode(KoutPin, INPUT);
digitalWrite(KoutPin, HIGH);
pinMode(3, OUTPUT); // For the flap position servo.
flapsServo.attach(3);
pinMode(5, OUTPUT); // For the eng 1 rpm servo.
proparpmServo.attach(5);
pinMode(6, OUTPUT); // For the egt 2 servo.
egtbServo.attach(6);
pinMode(9, OUTPUT); // For fuel flow 1 servo.
ffaServo.attach(9);
pinMode(10, OUTPUT); // For fuel flow 2 servo.
ffbServo.attach(10);
pinMode(11, OUTPUT); // For adf servo.
adfServo.attach(11);
{KEYS();} //Check the "keys" section
if (Serial.available()) {
CodeIn = getChar();
if (CodeIn == '=') {EQUALS();} // The first identifier is "="
if (CodeIn == '<') {LESSTHAN();} // The first identifier is "<"
if (CodeIn == '?') {QUESTION();} // The first identifier is "?"
if (CodeIn == '/') {SLASH();} // The firt identifier is "/" (Annunciators)
char getChar() // Get a character from the serial buffer
while(Serial.available() == 0); // wait for data
return((char)Serial.read()); // Thanks Doug
void EQUALS(){ // The first identifier was "="
// Do something
case'B':
                                          // Do something
case'C':
                                          // Do something
void LESSTHAN(){ // The first identifier was "<"
// Do something
case'B':
                                          // Do something
case'G':;                                  //("G" Flaps position)
  flaps = "";
  flaps += getChar();
  flaps += getChar();
  flaps += getChar();
  int flapsi = flaps.toInt();             // Convert to an integer.
  flapsangle = flapsi+flapsi*(4./5.);     // Manual correction to suit servo 180 deg.
  flapsServo.write(flapsangle);           // Scaled output to servo.
case'T':;                                  //("T" Prop 1 rpm position)
  proparpm = "";
  proparpm += getChar();
  int proparpmi = proparpm.toInt();         // Convert to an integer.
  proparpmangle = proparpmi*1./200.;        // Manual correction to suit servo 180 deg.
  proparpmServo.write(proparpmangle);       // Scaled output to servo.
case'K':                                  // Found the second identifier ("N" Eng 2 Temp position)
  egtb = "";
  egtb += getChar();
  egtb += getChar();
  egtb += getChar();
case'V':                                  // Found the second identifier ("V" Fuel Flow 1 position)
  ffa = "";
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  ffa += getChar();
  case'W':                                // Found the second identifier ("W" Fuel Flow 2 position)
  ffb = "";
  ffb += getChar();
  ffb += getChar();
  ffb += getChar();
  ffb += getChar();
  ffb += getChar();
  ffb += getChar();
  int ffbi = ffb.toInt();                 // convert it to an integer (Thanks Phill)
  ffbangle = ffbi+ffbi*(1./2.);           // Range calculation to suit servo 180deg.
  ffbServo.write(ffbangle);               // Scaled output to servo
case'n':                                  // Found the second identifier ("n" ADF position)
  adf = "";
  adf += getChar();
  adf += getChar();
  adf += getChar();
  adf += getChar();
  adf += getChar();
  int adfi = adf.toInt();                 // Convert to an integer.
  adfiangle = adfi/2;                     // Range calculation to suit servo 180deg.
  adfServo.write(adfiangle);              // Scaled output to servo.
void SLASH(){ // The first identifier was "/" (Annunciator)
// Do something
void KEYS()
Kstringnewstate = "";
for (int KpinNo = 2; KpinNo < 20; KpinNo++){
KpinStateSTR = String(digitalRead(KpinNo));
KoldpinStateSTR = String(Kstringoldstate.charAt(KpinNo - 2));
if (KpinStateSTR != KoldpinStateSTR)
if (KpinNo != 13){
Serial.print ("D");
if (KpinNo < 10) Serial.print ("0");
Serial.print (KpinNo);
Serial.println (KpinStateSTR);
Kstringnewstate += KpinStateSTR;
Kstringoldstate = Kstringnewstate;
Can you please edit your post with the code, select all code and click </> (that will place code tags around it). Next save the edited post.
Code tags will make it easier to copy and less annoying to read.
Here is the code in one piece
segregateSerial.ino (6.1 KB)
Question. I can see where you read a char and identify the start of a message. How do you know when the message ends / should end?
Thanks for the help,
As done below....
[code]
#include <Servo.h>
Servo flapsServo;
Servo egtbServo;
Servo ffaServo;
Servo ffbServo;
Servo adfServo;
int KpinNo;
int Koutpin;
String flaps;
String proparpm;
String egtb;
String ffa;
String ffb;
String adf;
int flapsangle;
int proparpmangle;
int egtbangle;
int ffaangle;
int ffbangle;
int adfiangle;
 ffaServo.attach(9);
    CodeIn = getChar();
                                              // Do something
    case'B':
                                              // Do something
    case'C':
                                              // Do something
                                              // Do something
    case'B':
                                              // Do something
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
      proparpm = "";
      egtb = "";
      egtb += getChar();
      egtb += getChar();
      egtb += getChar();
      ffa = "";
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffb = "";
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      adf = "";
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
                                              // Do something
void KEYS()
      if (KpinNo != 13){
      Serial.print ("D");
[/code]
I would suggest something like
String inputStr;
  ffaServo.attach(9);
  Serial.setTimeout(10); // short timeout
  inputStr.reserve(40); // enough for the expected input
    KEYS(); //Check the "keys" section
    inputStr = Serial.readString(); // reads until nothing arrives for 10mS
    char codeIn = inputStr[0];
    //CodeIn = getChar();
    if (codeIn == '=') {
      EQUALS(); // The first identifier is "="
    if (codeIn == '<') {
      LESSTHAN(); // The first identifier is "<"
    if (codeIn == '?') {
      QUESTION(); // The first identifier is "?"
    if (codeIn == '/') {
      SLASH(); // The firt identifier is "/" (Annunciators)
and then in the EQUALS etc just replace the getChar with inputStr[ .. ]
Have you confirmed the behaviour of toInt() on a float string? I suspect it will be "0".
When you receive data from serial, how do you ensure it always has 3 leading digits and 3 trailing digits? For example will the value 1.0 will be sent as 001.000? If it is not then the following ?Bxxx.xxx will be lost (eaten by the unused getChar() (s)) .
There are no floats in your code so why convert an int into float and then implicitly back again:
why not:
ffaangle = ffai+ffai/2;
or:
ffaangle = ffai*3/2;
At this point I would follow jimLee's advice.
Regards Alan
Good Day,
I am assuming that it ends based on how many integers I am reading, eg for proparpm, there are 5 getchar, based on the read value of 5 integers eg: 12532.
Taken these values, converted them for servo output, and I get a proper result, which indicates my values are good.
Not sure whether it is looking for additional values?
Thanks
Mark
[code]
#include <Servo.h>
Servo flapsServo;
Servo egtbServo;
Servo ffaServo;
Servo ffbServo;
Servo adfServo;
int KpinNo;
int Koutpin;
String flaps;
String proparpm;
String egtb;
String ffa;
String ffb;
String adf;
int flapsangle;
int proparpmangle;
int egtbangle;
int ffaangle;
int ffbangle;
int adfiangle;
 ffaServo.attach(9);
    CodeIn = getChar();
                                              // Do something
    case'B':
                                              // Do something
    case'C':
                                              // Do something
                                              // Do something
    case'B':
                                              // Do something
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
      proparpm = "";
      egtb = "";
      egtb += getChar();
      egtb += getChar();
      egtb += getChar();
      ffa = "";
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffb = "";
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      adf = "";
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
                                              // Do something
void KEYS()
      if (KpinNo != 13){
      Serial.print ("D");
[/code]
Thanks,
I will give it a go, makes good sense.
I will let you know how I get on,
Appreciated,
Mark
@Good Day Jim,
Pardon my inexperience, I searched the mentioned strtok() and atof() function to gain some understanding, and have not found any reference to them? Much the same, I have no idea how to include this function to my code.
Could you please be kind enough to include an example in my code,
Thank you,
Appreciated
[code]
#include <Servo.h>
Servo flapsServo;
Servo egtbServo;
Servo ffaServo;
Servo ffbServo;
Servo adfServo;
int KpinNo;
int Koutpin;
String flaps;
String proparpm;
String egtb;
String ffa;
String ffb;
String adf;
int flapsangle;
int proparpmangle;
int egtbangle;
int ffaangle;
int ffbangle;
int adfiangle;
  ffaServo.attach(9);
    CodeIn = getChar();
  while (Serial.available() == 0); // wait for data
  return ((char)Serial.read()); // Thanks Doug
void EQUALS() { // The first identifier was "="
  switch (CodeIn) { // Now lets find what to do with it
      // Do something
    case'B':
      // Do something
    case'C':
      // Do something
void LESSTHAN() { // The first identifier was "<"
      // Do something
    case'B':
      // Do something
    case'G':                                  //("G" Flaps position)
      flaps = "";
      flaps += getChar();
      flaps += getChar();
      flaps += getChar();
      flapsangle = flapsi + flapsi * (4. / 5.); // Manual correction to suit servo 180 deg.
    case'T':                                  //("T" Prop 1 rpm position)
      proparpm = "";
      proparpmangle = proparpmi * 1. / 200.;    // Manual correction to suit servo 180 deg.
void QUESTION() { // The first identifier was "?"
      egtb = "";
      egtb += getChar();
      egtb += getChar();
      egtb += getChar();
      egtbangle = egtbi * 5;                  // Range calculation to suit servo 180deg.
      ffa = "";
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffa += getChar();
      ffaangle = ffai + ffai * (1. / 2.);     // Range calculation to suit servo 180deg.
      ffb = "";
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffb += getChar();
      ffbangle = ffbi + ffbi * (1. / 2.);     // Range calculation to suit servo 180deg.
      adf = "";
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adf += getChar();
      adfiangle = adfi / 2;                   // Range calculation to suit servo 180deg.
void SLASH() { // The first identifier was "/" (Annunciator)
  // Do something
void KEYS()
  for (int KpinNo = 2; KpinNo < 20; KpinNo++) {
      if (KpinNo != 13) {
        Serial.print ("D");
[/code]
https://www.cplusplus.com/reference/cstring/strtok/
https://www.cplusplus.com/reference/cstdlib/atof/
-jim lee
Thanks for the links,
Got some reading and homework for the week.
Appreciate the help,
Regards,
Mark
