Trying to understand SimpleReceiverForHashCodes.ino
I am using the SimpleReceiverForHashCodes.ino code with older IR controllers. Tivo to be specific.
I am trying to assign a value to a variable from IrReceiver.decodedIRData.decodedRawData.
What data type will IrReceiver.decodedIRData.decodedRawData return?
#include <Arduino.h>
#define DECODE_HASH             // special decoder for all protocols
#define RAW_BUFFER_LENGTH 1000  // Especially useful for unknown and probably long protocols
//#define DEBUG                 // Activate this for lots of lovely debug output from the decoders.
#include "PinDefinitionsAndMore.h"
#include <IRremote.hpp>  // include the library
  while (!Serial)
    ;  // Wait for Serial to become available. Is optimized away for some cores.
  // Just to know which program is running on my Arduino
  Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
  // Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
  Serial.println(F("Ready to receive unknown IR signals at pin " STR(IR_RECEIVE_PIN) " and decode it with hash decoder."));
unsigned long data;
     * Check if received data is available and if yes, try to decode it.
     * Decoded hash result is in IrReceiver.decodedIRData.decodedRawData
  if (IrReceiver.available()) {
    IrReceiver.initDecodedIRData();  // is required, if we do not call decode();
    IrReceiver.decodeHash();
         * Print a summary of received data
    // We have an unknown protocol here, print extended info
    IrReceiver.printIRResultRawFormatted(&Serial, true);
    IrReceiver.resume();  // Early enable receiving of the next IR frame
    IrReceiver.printIRResultShort(&Serial);
    data = IrReceiver.decodedIRData.decodedRawData;
    Serial.println(" * * * ");
    Serial.println(data);
    if (IrReceiver.decodedIRData.decodedRawData == 0x4F7BE2FB) {
      // do something
    } else if (IrReceiver.decodedIRData.decodedRawData == 0x97483BFB) {
      // do something else
A glance at the code suggests that a 32 bit unsigned integer would be suitable.
Check the library code for a definitive answer.
Thank you jremington
This code worked:
    Serial.print(" * * * ");
    // UP 33556 RIGHT 47070  LEFT 55916  DOWN 24860
    if (data == 33556)Serial.print(" UP ");
     if (data == 24860)Serial.print(" DOWN ");
      if (data == 47070 )Serial.print(" RIGHT ");
       if (data == 55916 )Serial.print(" LEFT ");
In case someone later has the same question, please post all the code, so that they can see how you have declared the variable named "data".
Here is the full code. I use SimpleReceiverForHashCodes.ino to debug the IR controller then the following to implement my application. I plan on building an IR controlled robot and some IR controlled decorations. I've only assigned logic for 4 buttons.
// used tsop38238 chip
  while (!Serial)
// IR_RECEIVE_PIN defaults to PIN 2
unsigned int data;
    //IrReceiver.printIRResultRawFormatted(&Serial, true);
    //IrReceiver.printIRResultShort(&Serial);
    //Serial.println();
         * Finally, check the received data and perform actions according to the received command
    //Serial.print(" * * * ");
    //Serial.println(data);
    //Serial.println(" * * * ");
   // if (IrReceiver.decodedIRData.decodedRawData == 0x4F7BE2FB) {
      // do something
   // } else if (IrReceiver.decodedIRData.decodedRawData == 0x97483BFB) {
