Trying to upload code to nano
I am trying to upload a fairly simple code.
I have installed the servoeasing lib
here is the code
#include "ServoEasing.h"
ServoEasing servoTop;
ServoEasing servoBottom;
const int action_pin = 2;
int location = 31;
// Below numbers should be adjusted in case the facemask does not close/open to desired angle
int bottom_closed = 107;
int top_closed = 167;
int bottom_open = 20;
int top_open = 20;
 pinMode(action_pin, INPUT_PULLUP);
 servoTop.attach(9);
 servoBottom.attach(10);
 setSpeedForAllServos(190);
 servoTop.setEasingType(EASE_CUBIC_IN_OUT);
 servoBottom.setEasingType(EASE_CUBIC_IN_OUT);
 synchronizeAllServosStartAndWaitForAllServosToStop();
 int proximity = digitalRead(action_pin);
 if (proximity == LOW)
 if (location > bottom_open) {
 servoTop.setEaseTo(top_open);
 servoBottom.setEaseTo(bottom_open);
 location = bottom_open;
 delay(600);
 servoTop.setEaseTo(top_closed);
 servoBottom.setEaseTo(bottom_closed);
 location = bottom_closed;
 delay(600);
HERE ARE THE ERRORS
C:\Users\ALIENW~1\AppData\Local\Temp\ccmocYCk.ltrans0.ltrans.o: In function `setup':
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:14: undefined reference to `ServoEasing::attach(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:15: undefined reference to `ServoEasing::attach(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:16: undefined reference to `setSpeedForAllServos(unsigned int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:17: undefined reference to `ServoEasing::setEasingType(unsigned char)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:18: undefined reference to `ServoEasing::setEasingType(unsigned char)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:19: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
C:\Users\ALIENW~1\AppData\Local\Temp\ccmocYCk.ltrans0.ltrans.o: In function `loop':
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:27: undefined reference to `ServoEasing::setEaseTo(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:28: undefined reference to `ServoEasing::setEaseTo(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:29: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:33: undefined reference to `ServoEasing::setEaseTo(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:34: undefined reference to `ServoEasing::setEaseTo(int)'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:35: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
C:\Users\ALIENW~1\AppData\Local\Temp\ccmocYCk.ltrans0.ltrans.o: In function `_GLOBAL__sub_I_servoTop':
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:2: undefined reference to `ServoEasing::ServoEasing()'
C:\Users\Alienware\AppData\Local\Temp\.arduinoIDE-unsaved2024918-11712-tmmkxf.i79jf\sketch_oct18a/sketch_oct18a.ino:3: undefined reference to `ServoEasing::ServoEasing()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Did you not notice the warning above the errors?
 #warning You probably must change the line #include "ServoEasing.h" to #include "ServoEasing.hpp" in your ino file or define SUPPRESS_HPP_WARNING before the include to suppress this warning.
Including ServoEasing.hpp instead of ServoEasing.h got your sketch to compile for me.
Nope geez thanks man
WHere do you see that
Complete compile output follows:
arduino-cli compile -b arduino:avr:nano:cpu=atmega328 --warnings all --output-dir ~/tmp --no-color (in directory: /home/me/Documents/sketchbook/Nano/test)
In file included from /home/me/Documents/sketchbook/Nano/test/test.ino:1:0:
/home/me/Documents/sketchbook/libraries/ServoEasing/src/ServoEasing.h:930:2: warning: #warning You probably must change the line #include "ServoEasing.h" to #include "ServoEasing.hpp" in your ino file or define SUPPRESS_HPP_WARNING before the include to suppress this warning. [-Wcpp]
/tmp/ccTK3itH.ltrans0.ltrans.o: In function `setup':
/home/me/Documents/sketchbook/Nano/test/test.ino:14: undefined reference to `ServoEasing::attach(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:15: undefined reference to `ServoEasing::attach(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:16: undefined reference to `setSpeedForAllServos(unsigned int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:17: undefined reference to `ServoEasing::setEasingType(unsigned char)'
/home/me/Documents/sketchbook/Nano/test/test.ino:18: undefined reference to `ServoEasing::setEasingType(unsigned char)'
/home/me/Documents/sketchbook/Nano/test/test.ino:19: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
/tmp/ccTK3itH.ltrans0.ltrans.o: In function `loop':
/home/me/Documents/sketchbook/Nano/test/test.ino:27: undefined reference to `ServoEasing::setEaseTo(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:28: undefined reference to `ServoEasing::setEaseTo(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:29: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
/home/me/Documents/sketchbook/Nano/test/test.ino:33: undefined reference to `ServoEasing::setEaseTo(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:34: undefined reference to `ServoEasing::setEaseTo(int)'
/home/me/Documents/sketchbook/Nano/test/test.ino:35: undefined reference to `synchronizeAllServosStartAndWaitForAllServosToStop()'
/tmp/ccTK3itH.ltrans0.ltrans.o: In function `_GLOBAL__sub_I_servoTop':
/home/me/Documents/sketchbook/Nano/test/test.ino:2: undefined reference to `ServoEasing::ServoEasing()'
/home/me/Documents/sketchbook/Nano/test/test.ino:3: undefined reference to `ServoEasing::ServoEasing()'
collect2: error: ld returned 1 exit status
Used library Version Path
ServoEasing  3.3.0   /home/me/Documents/sketchbook/libraries/ServoEasing
Servo        1.2.1   /home/me/Documents/sketchbook/libraries/Servo
Used platform Version Path
arduino:avr   1.8.3   /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3
Error during build: exit status 1
Compilation failed.
