got this from LCD_ID ,
reg(0x0000) 95 95 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 3F 3F 3F 3F 3F Status Register
reg(0x000A) 00 00 Get Power Mode
reg(0x000C) 01 01 Get Pixel Format
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B4) 00 00 Inversion Control
reg(0x00B6) 00 00 00 00 00 Display Control
reg(0x00B7) 00 00 Entry Mode Set
reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B
reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
reg(0x00CC) 00 00 Panel Control
reg(0x00D0) 00 00 00 Power Control
reg(0x00D2) 00 00 00 00 00 NVM Read
reg(0x00D3) 00 00 00 00 ILI9341, ILI9488
reg(0x00D4) 00 00 00 00 Novatek ID
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 03 03 03 03 03 03 03 03 03 03 03 03 03 03 03 03 GAMMA-P
reg(0x00E1) 06 06 06 06 06 06 06 06 06 06 06 06 06 06 06 06 GAMMA-N
reg(0x00EF) 14 14 14 14 14 14 ILI9327
reg(0x00F2) 08 08 08 08 08 08 08 08 08 08 08 08 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
and tried all DEFINE_SUPPORT possibilities , but the same error happens.
anyone please ?
thank you
gibran
C:\Users\admin\AppData\Local\Temp\ccGFjhkm.ltrans0.ltrans.o: In function `pushColors':
C:\Users\admin\Documents\Arduino\libraries\MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:723: undefined reference to `penguin'
collect2.exe: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: C:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
Using library Adafruit GFX Library at version 1.11.11 in folder: C:\Users\admin\Documents\Arduino\libraries\Adafruit_GFX_Library-1.11.11
Using library Adafruit BusIO at version 1.14.1 in folder: C:\Users\admin\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Using library MCUFRIEND_kbv at version 3.0.0-Release in folder: C:\Users\admin\Documents\Arduino\libraries\MCUFRIEND_kbv
