turn off interrupts in isr() routine? Why not
I'm learning how to use interrupts in arduino. I've used them in Microchip applications and from what I've read there are some differences. Perhaps this is because the processor I am now using is more complex.
I am using an ATMega328P, trying to use Timer1 to capture the time of a pulse. I'm sure there is some arduino key function that will do what I want but I prefer to use the more native capabilities of the µP.
My question is:
I've read one should not enable or disable interrupts while in an isr() see: NickGammon, however in the past isr's were structured like:
turn off global isr's
save SREG
do what you have to
restore SREG
enable ISR's
Can someone tell me the reason for not enabling/disabling interrupt status in an interrupt in arduino?
Thanks
JohnRob
On AVR processors, interrupt service routines are entered with interrupts globally disabled. There is no point in disabling something that is already disabled.
Globally enabling interrupts while an interrupt service routine is running makes it possible for the interrupt service routine to be reentered. None of the Arduino code is designed for such things.
Both of those things are discussed in Nick's article.
Thank you..... I found it on Nick's interrupt page. Lots of reading there!
