Turn on LED with switch using millis (solved)
I want to push a button to turn on a LED for 4 seconds using millis. I think I almost got it, but it is not working the way i wanted to. I do not want to use a delay as I will be working with more than one LED.
code:
const int buttonPin = 41;     // the number of the pushbutton pin
const int ledPin =  39;      // the number of the LED pin
unsigned long time;
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  digitalWrite(ledPin, LOW);
void loop(){
  time = millis();
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    digitalWrite(ledPin,HIGH);
    if (time >= 1000 && time < 1020){
   }  // turn it on when its been running for a second
   if (time >= 4000 && time < 4020){
     digitalWrite(ledPin,LOW);
   }  // turn it off when its been running for 4seconds
When I use the code above, the LED would stay on after I pressed the button. I want the LED to turn on for 4 seconds after pushing button instead.
Any suggestion?
   digitalWrite(ledPin,HIGH);  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
I believe this is what keeping the LED on HIGH. If i take that out, LED would not turn on at all.
So you want the LED to come on one second after the button is pressed, like a long debounce?
Then yes, take out the line indicated.
Put in a flag to indice the button was pressed, reset the flag when you turn the LED back off.
You could take out the end time limits also (<1020 & <4020), they are not needed.
If you printed time after the condition was met, I think you would see it it always just barely past 1000 & 4000 and never close to 1020 & 4020.
So basically:
loop:
read time
read button
if button was pressed & set_pressed flag is low, then set_pressed flag = high
if time > 1000 and set_pressed flag is high, turn on led
if time > 4000, turn set_pressed flag,turn off led
end loop
Your problem is that you're only turning off the LED if the button is pressed. See, if the button was not pressed, it wouldn't even go into the first if statement, and never get to the one asking if it has been four seconds.
What I would do is have the button set the timer variable to the current time. Then I'd have a completely separate if statement asking if millis() - time > 4000. In the no case, I'd put a write high, in the yes case I'd put a write low.
The one problem with that is it would keep the LED on for 4 seconds after the button was released. You could having something where it would compare the current value of the button to the last one, and only if they were different AND the button was pressed (so it was pressed this loop but not last loop) would it set the timer variable.
Does that make sense?
this is what i have now if im following you right
void loop(){
  time = millis();
  if (buttonState == HIGH && set_pressed == LOW )
    set_pressed == HIGH;
    if (time >= 1000 && set_pressed == HIGH){
   if (time >= 4000 && set_pressed == LOW){
at the top , do i set the flag " boolean set_pressed = false"?
Yes to setting it low to start.
if time>=4000 & set_pressed == high
turn off led
set_pressed = low
it doesn't turn on the LED on at all after being pressed.
Wiz was right i think.
updated code on loop:
   if (time >= 4000 && set_pressed == HIGH){
     set_pressed == LOW;
Ah, yes - millis() is free running counter, you need to look at the elapsed time, not just the static time.
Make your time variable
unsigned long
and subtract earlier time from current time to see how much has elapsed, resetting when you start over.
time = millis; // start time running
if
Silly of me to overlook that.
Capture time again just before your if statements, make the if's
current_time = millis
if ((current_time - time) >=1000 ...
and
if ((current_time - time >=4000 ...
Then you can be doing other stuff in your loop while time marches on ...
I'm off to bed, think it thru & good luck.
Im having a hard time getting it to work. It still won't turn on .
updated code;
unsigned long time;
unsigned long current_time;
int set_pressed = 0;
void loop(){
    time = millis();
    current_time = millis();
    if ((current_time - time) >= 1000 && set_pressed == HIGH)
   if ((current_time - time) >= 4000 && set_pressed == HIGH)
     set_pressed == LOW;
What am i missing?
Maybe I'm missing something on the void setup
set_pressed == LOW;
The comment is wrong. The ledPin is set LOW regardless of the time and/or the value in set_pressed. You have curly braces where you don't need them, and you don't have them where you do need them.
And, == is the equality operator. It is not the assignment operator. set_pressed is not being set here.
Finally I got it!!!!!!!!!
unsigned long off_time;
boolean ledState=false;
void loop(){
if ((ledState) && (millis()>=off_time)) /* is it on and is it later or equal to off_time */
    ledState = false;
else if (!ledState) /* is it off? */
    if(buttonState == HIGH)
        digitalWrite(ledPin, HIGH);
        ledState = true;
        off_time = millis() + 5000;
Thanks for the insight guys
This is somewhat I am looking for. However, I want to use a continuous servo instead, but the problem is that there is gonna be 3 wires on the servo. The positive(red) wire, the ground black wire, and the control white wire.
Tried changing up the code a bit with the servos, and so far no luck. Servo doesn't turn on at all.
#include <Servo.h>
const int servobuttonPin1 = 51;
const int servoPin1 = 35;
unsigned long off_time1;
boolean servoState1 = false;
int servobuttonState1 = 0;
Servo myservo;
  pinMode(servoPin1, OUTPUT);
  pinMode(servobuttonPin1, INPUT);
  digitalWrite(servoPin1, LOW);
  myservo.attach(23); //set up the servo as usual
  if ((servoState1) && (millis()>=off_time1)) /* is it on and is it later or equal to off_time */
    digitalWrite(servoPin1,LOW);
else if (!servoState1) /* is it off? */
    servobuttonState1 = digitalRead(servobuttonPin1);
    if(servobuttonState1 == HIGH)
        digitalWrite(servoPin1, HIGH);
        servoState1 = true;
        off_time1 = millis() + 5000;
   // on this servo 1500 is stopped, above 1500 is clockwise, below is counter clockwise... 2000 is max I think
   myservo.writeMicroseconds(1000);
   delay(15);
unless i can't use this method for my servo...
Any suggestions?
These wires go where?
Is the servo control wire connected to 23 or 35? Why is 23 a constant when everything else uses names?
The code you posted makes me suspect that you are trying to power the servo using a digital pin, turning that pin on or off in the code, and then using servo.writeMicroseconds() to move the servo if it is powered. Is that what you are doing? If so, stop it. Now. Power the servo correctly, and use the appropriate argument to writeMicroseconds() to control the servo motion.
here you go theonlyone, this should work
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
#define LED 13
#define BUTTON 51
int val = 0;                    // variable for reading the pin status
int bounceCheck = 0;            // variable for debouncing
int cw = 0;                     // Servo cw value
  pinMode(BUTTON, INPUT);     // declare pushbutton as input
  pinMode(LED, OUTPUT);     // declare LED as output
void loop(){
  val = digitalRead(BUTTON);            //read input value
  delay(20);                              //wait 20ms
  bounceCheck = digitalRead(BUTTON);   //check again
  if(val == bounceCheck){                //if val is the same then not a bounce
    if (val == LOW) {                   //check if the input is LOW
  digitalWrite(LED, HIGH);
  myservo.attach(9);               // white wire of servo to pin 9
  myservo.write(cw);
  delay(5000);
  digitalWrite(LED, LOW);
  myservo.detach();
} //End if bounce check
} //end Loop
LED pin 13 just shows whether the servo is running or not running.
Red wire of servo to +5 V, white wire to pin 9, black to ground
Button pin 51
Also note that I am using a delay and not millis. I'll see if I can using millis instead of a delay.
Awesome thx man.
Anyhow , can this be done using millis?
