Turn on LEDs (code?) at certain time of day
I have build a beautiful East Coast METAR map using the code below (see pic below). I'm trying to get the LEDs to 'turn off' at certain time of day, say for example from 11pm - 6am. I hardwired a switch in, but would like to include a time function into the code. All of the examples I can find are for blinking LEDS.
Any suggestions and brief explination on where to put this into the code would be a great help.
Credit for code: https://www.rickgouin.com/make-your-own-metar-weather-map/
#include <ESP8266WiFi.h>
#include <FastLED.h>
#include <vector>
using namespace std;
#define FASTLED_ESP8266_RAW_PIN_ORDER
#define NUM_AIRPORTS 3 // This is really the number of LEDs
#define WIND_THRESHOLD 25 // Maximum windspeed for green, otherwise the LED turns yellow
#define LOOP_INTERVAL 5000 // ms - interval between brightness updates and lightning strikes
#define DO_LIGHTNING true // Lightning uses more power, but is cool.
#define DO_WINDS true // color LEDs for high winds
#define REQUEST_INTERVAL 900000 // How often we update. In practice LOOP_INTERVAL is added. In ms (15 min is 900000)
#define USE_LIGHT_SENSOR false // Set USE_LIGHT_SENSOR to true if you're using any light sensor.
// Set LIGHT_SENSOR_TSL2561 to true if you're using a TSL2561 digital light sensor.
// Kits shipped after March 1, 2019 have a digital light sensor. Setting this to false assumes an analog light sensor.
#define LIGHT_SENSOR_TSL2561 false
const char ssid[] = "EDITME"; // your network SSID (name)
const char pass[] = "EDITME"; // your network password (use for WPA, or use as key for WEP)
// Define the array of leds
CRGB leds[NUM_AIRPORTS];
#define DATA_PIN    14 // Kits shipped after March 1, 2019 should use 14. Earlier kits us 5.
#define LED_TYPE    WS2811
#define COLOR_ORDER RGB
#define BRIGHTNESS 20 // 20-30 recommended. If using a light sensor, this is the initial brightness on boot.
/* This section only applies if you have an ambient light sensor connected */
#if USE_LIGHT_SENSOR
/* The sketch will automatically scale the light between MIN_BRIGHTNESS and
MAX_BRIGHTNESS on the ambient light values between MIN_LIGHT and MAX_LIGHT
Set MIN_BRIGHTNESS and MAX_BRIGHTNESS to the same value to achieve a simple on/off effect. */
#define MIN_BRIGHTNESS 20 // Recommend values above 4 as colors don't show well below that
#define MAX_BRIGHTNESS 20 // Recommend values between 20 and 30
// Light values are a raw reading for analog and lux for digital
#define MIN_LIGHT 16 // Recommended default is 16 for analog and 2 for lux
#define MAX_LIGHT 30 // Recommended default is 30 to 40 for analog and 20 for lux
#if LIGHT_SENSOR_TSL2561
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2561_U.h>
#include <Wire.h>
Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 12345);
#else
#define LIGHTSENSORPIN A0 // A0 is the only valid pin for an analog light sensor
#endif
#endif
std::vector<unsigned short int> lightningLeds;
std::vector<String> airports({
  "LIFR", // 1 order of LEDs, starting with 1 should be KKIC; use VFR, WVFR, MVFR, IFR, LIFR for key; NULL for no airport
  "IFR", // 2
  "MVFR", // 3
#define DEBUG false
#define READ_TIMEOUT 15 // Cancel query if no data received (seconds)
#define WIFI_TIMEOUT 60 // in seconds
#define RETRY_TIMEOUT 15000 // in ms
#define SERVER "www.aviationweather.gov"
#define BASE_URI "/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&hoursBeforeNow=3&mostRecentForEachStation=true&stationString="
boolean ledStatus = true; // used so leds only indicate connection status on first boot, or after failure
int loops = -1;
int status = WL_IDLE_STATUS;
  //Initialize serial and wait for port to open:
  Serial.begin(74880);
  //pinMode(D1, OUTPUT); //Declare Pin mode
  //while (!Serial) {
  //    ; // wait for serial port to connect. Needed for native USB
  pinMode(LED_BUILTIN, OUTPUT); // give us control of the onboard LED
  digitalWrite(LED_BUILTIN, LOW);
  Wire.begin(D2, D1);
  if(!tsl.begin()) {
    /* There was a problem detecting the TSL2561 ... check your connections */
    Serial.println("Ooops, no TSL2561 detected ... Check your wiring or I2C ADDR!");
    tsl.enableAutoRange(true);
    tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);
  #else
  pinMode(LIGHTSENSORPIN, INPUT);
  #endif
  #endif
  // Initialize LEDs
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_AIRPORTS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS);
void adjustBrightness() {
  unsigned char brightness;
  float reading;
  sensors_event_t event;
  tsl.getEvent(&event);
  reading = event.light;
  #else
  reading = analogRead(LIGHTSENSORPIN);
  #endif
  Serial.print("Light reading: ");
  Serial.print(reading);
  Serial.print(" raw, ");
  if (reading <= MIN_LIGHT) brightness = 0;
  else if (reading >= MAX_LIGHT) brightness = MAX_BRIGHTNESS;
  else {
    // Percentage in lux range * brightness range + min brightness
    float brightness_percent = (reading - MIN_LIGHT) / (MAX_LIGHT - MIN_LIGHT);
    brightness = brightness_percent * (MAX_BRIGHTNESS - MIN_BRIGHTNESS) + MIN_BRIGHTNESS;
  Serial.print(brightness);
  Serial.println(" brightness");
  FastLED.setBrightness(brightness);
  FastLED.show();
#endif
  digitalWrite(LED_BUILTIN, LOW); // on if we're awake
  adjustBrightness();
  #endif
  int c;
  loops++;
  Serial.print("Loop: ");
  Serial.println(loops);
  unsigned int loopThreshold = 1;
  if (DO_LIGHTNING || USE_LIGHT_SENSOR) loopThreshold = REQUEST_INTERVAL / LOOP_INTERVAL;
  // Connect to WiFi. We always want a wifi connection for the ESP8266
  if (WiFi.status() != WL_CONNECTED) {
    if (ledStatus) fill_solid(leds, NUM_AIRPORTS, CRGB::Orange); // indicate status with LEDs, but only on first run or error
    FastLED.show();
    WiFi.mode(WIFI_STA);
    WiFi.hostname("LED Sectional " + WiFi.macAddress());
    //wifi_set_sleep_type(LIGHT_SLEEP_T); // use light sleep mode for all delays
    Serial.print("WiFi connecting..");
    WiFi.begin(ssid, pass);
    // Wait up to 1 minute for connection...
    for (c = 0; (c < WIFI_TIMEOUT) && (WiFi.status() != WL_CONNECTED); c++) {
      Serial.write('.');
    if (c >= WIFI_TIMEOUT) { // If it didn't connect within WIFI_TIMEOUT
      Serial.println("Failed. Will retry...");
      FastLED.show();
      ledStatus = true;
      return;
    Serial.println("OK!");
    if (ledStatus) fill_solid(leds, NUM_AIRPORTS, CRGB::Purple); // indicate status with LEDs
    FastLED.show();
    ledStatus = false;
  // Do some lightning
  if (DO_LIGHTNING && lightningLeds.size() > 0) {
    std::vector<CRGB> lightning(lightningLeds.size());
    for (unsigned short int i = 0; i < lightningLeds.size(); ++i) {
      unsigned short int currentLed = lightningLeds[i];
      lightning[i] = leds[currentLed]; // temporarily store original color
      leds[currentLed] = CRGB::White; // set to white briefly
      Serial.print("Lightning on LED: ");
      Serial.println(currentLed);
    delay(25); // extra delay seems necessary with light sensor
    FastLED.show();
    delay(25);
      leds[currentLed] = lightning[i]; // restore original color
    FastLED.show();
  if (loops >= loopThreshold || loops == 0) {
    loops = 0;
    if (DEBUG) {
      fill_gradient_RGB(leds, NUM_AIRPORTS, CRGB::Red, CRGB::Blue); // Just let us know we're running
      FastLED.show();
    Serial.println("Getting METARs ...");
    if (getMetars()) {
      Serial.println("Refreshing LEDs.");
      FastLED.show();
      if ((DO_LIGHTNING && lightningLeds.size() > 0) || USE_LIGHT_SENSOR) {
        Serial.println("There is lightning or we're using a light sensor, so no long sleep.");
        digitalWrite(LED_BUILTIN, HIGH);
        delay(LOOP_INTERVAL); // pause during the interval
        Serial.print("No lightning; Going into sleep for: ");
        Serial.println(REQUEST_INTERVAL);
        delay(REQUEST_INTERVAL);
      delay(RETRY_TIMEOUT); // try again if unsuccessful
bool getMetars(){
  lightningLeds.clear(); // clear out existing lightning LEDs since they're global
  fill_solid(leds, NUM_AIRPORTS, CRGB::Black); // Set everything to black just in case there is no report
  uint32_t t;
  char c;
  boolean readingAirport = false;
  boolean readingCondition = false;
  boolean readingWind = false;
  boolean readingGusts = false;
  boolean readingWxstring = false;
  std::vector<unsigned short int> led;
  String currentAirport = "";
  String currentCondition = "";
  String currentLine = "";
  String currentWind = "";
  String currentGusts = "";
  String currentWxstring = "";
  String airportString = "";
  bool firstAirport = true;
  for (int i = 0; i < NUM_AIRPORTS; i++) {
    if (airports[i] != "NULL" && airports[i] != "VFR" && airports[i] != "MVFR" && airports[i] != "WVFR" && airports[i] != "IFR" && airports[i] != "LIFR") {
      if (firstAirport) {
        firstAirport = false;
        airportString = airports[i];
      } else airportString = airportString + "," + airports[i];
  BearSSL::WiFiClientSecure client;
  client.setInsecure();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (!client.connect(SERVER, 443)) {
    Serial.println("Connection failed!");
    client.stop();
    return false;
    Serial.println("Connected ...");
    Serial.print("GET ");
    Serial.print(BASE_URI);
    Serial.print(airportString);
    Serial.println(" HTTP/1.1");
    Serial.print("Host: ");
    Serial.println(SERVER);
    Serial.println("User-Agent: LED Map Client");
    Serial.println("Connection: close");
    // Make a HTTP request, and print it to console:
    client.print("GET ");
    client.print(BASE_URI);
    client.print(airportString);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(SERVER);
    client.println("User-Agent: LED Sectional Client");
    client.println("Connection: close");
    client.println();
    client.flush();
    t = millis(); // start time
    FastLED.clear();
    Serial.print("Getting data");
    while (!client.connected()) {
      if ((millis() - t) >= (READ_TIMEOUT * 1000)) {
        Serial.println("---Timeout---");
        client.stop();
        return false;
      Serial.print(".");
    while (client.connected()) {
      if ((c = client.read()) >= 0) {
        yield(); // Otherwise the WiFi stack can crash
        currentLine += c;
        if (c == '\n') currentLine = "";
        if (currentLine.endsWith("<station_id>")) { // start paying attention
          if (!led.empty()) { // we assume we are recording results at each change in airport
            for (vector<unsigned short int>::iterator it = led.begin(); it != led.end(); ++it) {
              doColor(currentAirport, *it, currentWind.toInt(), currentGusts.toInt(), currentCondition, currentWxstring);
            led.clear();
          currentAirport = ""; // Reset everything when the airport changes
          readingAirport = true;
          currentWind = "";
          currentGusts = "";
        } else if (readingAirport) {
          if (!currentLine.endsWith("<")) {
            currentAirport += c;
            for (unsigned short int i = 0; i < NUM_AIRPORTS; i++) {
              if (airports[i] == currentAirport) {
                led.push_back(i);
        } else if (currentLine.endsWith("<wind_speed_kt>")) {
          readingWind = true;
        } else if (readingWind) {
            currentWind += c;
        } else if (currentLine.endsWith("<wind_gust_kt>")) {
          readingGusts = true;
        } else if (readingGusts) {
            currentGusts += c;
        } else if (currentLine.endsWith("<flight_category>")) {
          readingCondition = true;
        } else if (readingCondition) {
            currentCondition += c;
        } else if (currentLine.endsWith("<wx_string>")) {
          readingWxstring = true;
        } else if (readingWxstring) {
            currentWxstring += c;
        t = millis(); // Reset timeout clock
      } else if ((millis() - t) >= (READ_TIMEOUT * 1000)) {
        fill_solid(leds, NUM_AIRPORTS, CRGB::Cyan); // indicate status with LEDs
        FastLED.show();
        ledStatus = true;
        client.stop();
        return false;
  // need to doColor this for the last airport
  led.clear();
  // Do the key LEDs now if they exist
  for (int i = 0; i < (NUM_AIRPORTS); i++) {
    // Use this opportunity to set colors for LEDs in our key then build the request string
    if (airports[i] == "VFR") leds[i] = CRGB::Green;
    else if (airports[i] == "WVFR") leds[i] = CRGB::Yellow;
    else if (airports[i] == "MVFR") leds[i] = CRGB::Blue;
    else if (airports[i] == "IFR") leds[i] = CRGB::Red;
    else if (airports[i] == "LIFR") leds[i] = CRGB::Magenta;
  client.stop();
  return true;
void doColor(String identifier, unsigned short int led, int wind, int gusts, String condition, String wxstring) {
  CRGB color;
  Serial.print(identifier);
  Serial.print(": ");
  Serial.print(condition);
  Serial.print(" ");
  Serial.print(wind);
  Serial.print("G");
  Serial.print(gusts);
  Serial.print("kts LED ");
  Serial.print(led);
  Serial.print(" WX: ");
  Serial.println(wxstring);
  if (wxstring.indexOf("TS") != -1) {
    Serial.println("... found lightning!");
    lightningLeds.push_back(led);
  if (condition == "LIFR" || identifier == "LIFR") color = CRGB::Magenta;
  else if (condition == "IFR") color = CRGB::Red;
  else if (condition == "MVFR") color = CRGB::Blue;
  else if (condition == "VFR") {
    if ((wind > WIND_THRESHOLD || gusts > WIND_THRESHOLD) && DO_WINDS) {
      color = CRGB::Yellow;
      color = CRGB::Green;
  } else color = CRGB::Black;
  leds[led] = color;
Excellent map of the US of A, circa 1802! The Real Time Clock (for example; DS3231, DS1307) is the device for Time of day alarms.
You can use non-blocking timer code, but that will be unrelated to the actual time.
An RTC module is under $10 and wires easily. With built in battery backup, your app can always know when it is.
You could also add a WiFi module and pull the time off the internet when you reset.
Up 2 U! :smiley:
Thank you. Yes, circa 1802! Funny.
Since the board I'm using has wifi, can I not use some kind of ntp pull?
So essentially, my code would be something like
  1. Define hours where leds would be 'active'
  2. Pull current time from NTP site
  3. If time in 'active' hours, then run remainder of code (as posted above)
  4. If time in 'inactive' hours, then turn all leds off (Color: 0,0,0)
some weeks ago we had a very similar question.
I came up with
just make your time definitions into HHMM (HH *100 + MM) and put the parameters to the function.
It will return true or false and will work over midnight.
