This is the basic and I mean basic sketch that I am using. I've built a light with an LDR in it so I can put it on my patio and trying to make it a automatic on in dark, off in light..... nothing new here.
Here's the part of the sketch I'm using and for some reason I cannot get this to turn off.... not really sure why. I think I'm missing something simple here but it eludes me
void loop(){
ldr = analogRead(LDR);
ldrValue = map(ldr, 0, 40, 15, 0);
// For testing so you can set your above ldrValue map function
Serial.print("\t ldr :");
Serial.println(ldr);
//Serial.print("ldrValue :");
//Serial.print(ldrValue );
if (ldr > 20){
Fire2012(); // run simulation frame
FastLED.show(); // display this frame
FastLED.delay(100 / FRAMES_PER_SECOND);
FastLED.clear();
delay(10); //repeat every 0.1 second
That should be very straight forward and turn it off when LDR value drops..... however it's not. It stays on... suggestion? Thanks all!
