Why have your function declarations got semicolons at the end ?
UKHeliBob:
Thanks for noticing that, but I am still getting the error in the loop section saying that the function is not declared.
See attached image.
The semi-colons were the problem. It compiles fine in Sketch when you remove them. Must be a side effect of whatever not-Sketch program you are using, that is causing it to not acknowledge the checkButtons as a void, it's expecting a data type.
INTP:
You're right. I just tried it on another online coding programmer and it worked. It didn't fail. Weird.
Thanks for your help on that.
That error message looks very odd to me.
Which version of the IDE are you running ?
UKHeliBob:
That error message looks very odd to me.Which version of the IDE are you running ?
IDE? I have been using a website online to work on the programming. Here is the link for my project on the website:
You can view the current code and test the programming. I can get you the license, too, once the website stops acting up and loads the page.
I also got the servo to start with the button but I can't get it to stop when I press the button again. I have hear just about everywhere I look that I need to use millis() instead of delay(), I just don't know how to write it.
//Add Servo library
#include <Servo.h>
//List Servo names
Servo eyeservo, tailservo;
//Set up Constant Pins
const int actPin = 3; //Activation Button
const int output1Pin = 9; // Eye Servo
const int output2Pin = 6; // Tail Servo
const int ledPin = 13; //Test LED
//Positions for Tail Servo
const byte maxTDeg = 160;
const byte minTDeg = 45;
byte tailPos = minTDeg;
//Positions for Eye Servo
const int maxEDeg = 179;
const int minEDeg = 1;
byte eyePos = maxEDeg;
//Attach Servos to pins
eyeservo.attach(output1Pin);
tailservo.attach(output2Pin);
//Move Servos to starting positions
tailservo.write(tailPos);
eyeservo.write(eyePos);
delay(5000);
//Set up pinModes
pinMode(actPin, INPUT_PULLUP);
pinMode(output1Pin, OUTPUT);
pinMode(output2Pin, OUTPUT);
pinMode(ledPin, OUTPUT);
//read the pushbutton value into a variable
int sensorVal = digitalRead(3);
//print out the value of the pushbutton
Serial.println(sensorVal);
// Keep in mind the pullup means the pushbutton's
// logic is inverted. It goes HIGH when it's open,
// and LOW when it's pressed. Turn on pin 13 when the
// button's pressed, and off when it's not:
if (sensorVal == HIGH) {
digitalWrite(13, LOW);
digitalWrite(13, HIGH);
//Tail Sweep Program
if(sensorVal == LOW){ //Has the button been pressed?
for(tailPos = 0; tailPos < 160; tailPos += 1)
delay(15);
for(tailPos = 160; tailPos>=1; tailPos-=1)
delay(15);
if(sensorVal == HIGH){
tailservo.write(90);
delay(15);
Why not download and use the IDE ? It is, after all, free !
UKHeliBob:
I have been doing most of my programming in between projects at work and I can't download programs to this computer, hence the reason for using the website.
DracoAnimatronica:
Can someone help me with this? I haven't made any changes to my code since I last posted it.
Thanks
Can probably just define a new variable as 'servoState', treat it like an on/off led.
Push button first time, servo stuff turns on, but also sets servoState to 1/0, HIGH/LOW, TRUE/FALSE, whatever you wanna call it. Push button second time, will change its state and use that variable to command servo.
INTP:
I did that but it doesn't work. Plus I want the servo to return to its starting point when the button is pressed.
Try this
unsigned long sweepStepStartTime;
unsigned long sweepStepInterval = 15;
unsigned long currentTime;
const byte buttonPin = A1;
byte currentButtonState;
byte previousButtonState = HIGH;
boolean sweeping = false;
int servoPos = 0;
int servoStepSize = 1;
pinMode(buttonPin, INPUT_PULLUP);
currentButtonState = digitalRead(buttonPin);
if (currentButtonState != previousButtonState)
if (currentButtonState == LOW) //button has become pressed
Serial.println("Button press");
sweeping = !sweeping; //change state
if (!sweeping) //stopped sweeping
servoPos = 0;
else //sweeping active
currentTime = millis();
if (currentTime - sweepStepStartTime >= sweepStepInterval) //time to move ?
sweepStepStartTime = currentTime; //note the time the servo moved
servoPos += servoStepSize; //update the servo position variable
if (servoPos <= 0 || servoPos >= 180) //end of servo travel
servoStepSize = -1 * servoStepSize; //reverse the servo
Serial.print("Servo is at position ");
Serial.println(servoPos);
previousButtonState = currentButtonState; //ready for the next check
You will need to add code to actually move the servo and it would be a good idea add code to debounce the switch too. You will, of course, also need to change the pin number and maybe the logic to detect a button press to match your setup.
DracoAnimatronica:
How about updating the code you posted in Reply #19 to take account of the comments you received and then see if that works.
...R
Robin2:
How about updating the code you posted in Reply #19 to take account of the comments you received and then see if that works....R
Please see Reply #27 for most recent code.
DracoAnimatronica:
I had seen that before I wrote Reply #34
...R
Hi Robin2, INTP, and UKHeliBob. Just thought I would put an updated here for you guys who were trying to help me. I did manage to figure out why the programming that I was trying to use from post #19 wasn't working. I didn't know that I needed to have programming in each of the functions for the program to stop failing. I am getting closer to having what I want to run but I still have a ways yet to go.
Anyways here's what I currently have:
// Libraries
#include <Servo.h>
// Constants
//Pins
const int actPin = 7; //Activation Button
const int onBoardLedPin = 13; //Test LED
const int output1Pin = 9; // Eye Servo Pin
const int output2Pin = 6; // Tail Servo Pin
//Degrees for Eye servo
const int maxEDeg = 90;
//Degrees for Tail servo
const byte minTDeg = 0;
//Item Intervals & Durations
const int onBoardLedInterval = 500; // number of millisecs between blinks
const int buttonInterval = 300; // number of millisecs between button readings
const int blinkDuration = 500; // number of millisecs that Led is on
// Variables
//Call out servo names
//Servo Starting positions
int eyePos = 179;
int tailPos = 1;
int servoSlowInterval = 10; // millisecs between servo moves
int servoFastInterval = 10;
int servoInterval = servoSlowInterval; // initial millisecs between servo moves
int servoDegrees = 2; // amount servo moves at each step
// will be changed to negative value for movement in the other direction
//Button variable (will be used to tell the servos to run the sleep program)
int push = 0;
//Item States
byte onBoardLedState = LOW; // used to record whether the LED is on or off
byte buttonLed_State = LOW; //used to record whether the button is pushed or not
//Millis()
unsigned long currentMillis = 0; // stores the value of millis() in each iteration of loop()
unsigned long previousOnBoardLedMillis = 0; // will store last time the LED was updated
unsigned long previousButtonMillis = 0; // time when button press last checked
unsigned long previousEServoMillis = 0; // the time when the Eye servo was last moved
unsigned long previousTServoMillis = 0; // the time when the Tail servo was last moved
Serial.println("Starting DragonModes.ino"); // so we know what sketch is running
//Set up OUTPUT Pins
pinMode(onBoardLedPin, OUTPUT);
//Set up Button INPUT Pin
//Set up Servos
//Millis()
currentMillis = millis();
//Call out functions
checkButton();
Power();
setLED();
servoTailSweep();
// servoEyeBlink();
void checkButton()
{ //check the state of the button
if (millis() - previousButtonMillis >= buttonInterval)
if (digitalRead(actPin) == LOW)
buttonLed_State = ! buttonLed_State;
previousButtonMillis += buttonInterval;
//Add program for push variable?
void Power()
{ //Turn on Programs
digitalWrite(onBoardLedPin, onBoardLedState); //On board light
//Tail Servo (to be written)
//Eye Servo (to be written)
void setLED()
{ //Set LED state based on button
if (onBoardLedState == LOW)
if (currentMillis - previousOnBoardLedMillis >= onBoardLedInterval) {
onBoardLedState = HIGH;
previousOnBoardLedMillis += onBoardLedInterval;
if (currentMillis - previousOnBoardLedMillis >= blinkDuration) {
previousOnBoardLedMillis += blinkDuration;
void servoTailSweep()
{ //Start the Tail Sweep servo
if (currentMillis - previousTServoMillis >= servoInterval)
previousTServoMillis += servoInterval;
tailPos = tailPos + servoDegrees;
if (tailPos <= minTDeg)
if (servoInterval == servoSlowInterval)
servoInterval = servoFastInterval;
if ((tailPos >= maxTDeg) || (tailPos <= minTDeg))
servoDegrees = - servoDegrees;
//void servoEyeBlink()
//{ //Start the Eye Blink servo
//I haven't written the program for this yet
DracoAnimatronica:
Glad to hear you are making progress.
Let us know when you need more assistance.
...R
Robin2:
Let us know when you need more assistance....R
Thanks. I actually have been using the "several things at the same time" coding to get things working but I actually am kind of confused about how the LED's in the program know if the button was pushed or not. I don't understand what links them to each other. Its quiet puzzling to me.
Oops. I see what I'm missing now.
Nevermind.
Hi All!
I have been having some slight difficulty suddenly with my program. For some reason the servos aren't moving; well the one that I have set up with code that is. Can someone help me with figuring out why its not moving?
Also could use some help with getting the button to tell the servo to go to a preset location if its in the off position?
Thanks.
Here's the most updated code and I have attached a picture of my setup:
// Libraries
#include <Servo.h>
// Constants
//Pins
const int onBoardLedPin = 13; //On Board LED
const int TestPin = 10; //Test LED
// Variables
int eyePos = 179;
int tailPos = 1;
//NOTE: NOT IMPLIMENTED YET IN PROGRAM!
int push = 0;
//Item States
//Millis()
pinMode(TestPin, OUTPUT);
//Set up Servos
//Millis()
checkButton();
Power();
setLED();
servoTailSweep();
// servoEyeBlink();
void checkButton()
void Power()
digitalWrite(TestPin, buttonLed_State); //Test LED
void setLED()
{ //Set On Board LED state to blink
//Need to figure out how to connect this to the button.
