The test for whether the current timing period has ended depends on Serial data being available. How long will such data be available and what happens if nothing is available ?
bool relayIsBlinking = false;
… // other variables and setup()
switch(Serial.read()) {
case 's': relayIsBlinking = true; break; // possibly initialize timing variables etc
case 'w': relayIsBlinking = false; break;// possibly turn it off depending if you want to keep the last state or not
default: break; // ignore anything else
if (relayIsBlinking) {
// handle the blinking
To handle the blinking study blink without delay, one of the available example in the IDE.
For extra information and examples using millis look at
turn on/off the relay every 5 seconds
5 seconds on
5 seconds off
repeat
The explanation of this code is similar to your description:
almost non-existant.
unsigned long MyRelayTimer = 0; // Timer-variables MUST be of type unsigned long
const byte relayPin = 6;
const byte OnBoard_LED = 13;
Serial.println("Setup-Start");
PrintFileNameDateTime();
BlinkHeartBeatLED(OnBoard_LED,250);
if ( TimePeriodIsOver(MyRelayTimer,5000) ) {
digitalWrite(relayPin, !digitalRead(relayPin) );
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file ") );
Serial.println( F(__FILE__) );
Serial.print( F(" compiled ") );
Serial.print( F(__DATE__) );
Serial.print( F(" ") );
Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
if this is not what you want to have. There is no way around describing with more precision and more details what you really want to have
