Reference: Arduino Portal Turret (HD Video) - YouTube
Motion triggers a PIR sensor, which in turn triggers a PING sensor to look for an obstacle within 2 feet.
If no object is found, the servo will start rotating and do continuous sweep until the PING sensor finds an object within the predetermined frame of distance. The turret then locks on and does other functions (LED turns on, audio plays).
In my design, I have an HC-SR04 ultrasonic sensor instead of a PING sensor. Also, two servos operate in pan-tilt fashion. Instead of 2 feet, i set a distance of 10 units.
My problem is that the ultrasonic sensor will only do continuous reading if the max allowed distance read is smaller than 10 units (servos stop due to target lock on).
Above 10 units of distance, the servos rotate, looking for a target, but only 1 reading is done by the ultrasonic sensor. Just as one itch of movement triggers the PIR sensor.
How is it possible to have repeated ultrasonic reading while the servos rotate? Unless the target is within 10 units at the time of activation, the turret is not able to find a target.
#include <Servo.h>
Servo myservoy; //creates a servo object
Servo myservox;
//a maximum of eight servo objects can be created
int pos = 0; //variable to store servo position
//amount of time we give the sensor to calibrate(10-60 secs according to the datasheet)
int calibrationTime = 10;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 12; //digital pin connected to the PIR's output
int pirPos = 13; //connects to the PIR's 5V pin
// defines pin numbers for ultrasensor
const int trigPin = 11;
const int echoPin = 10;
// defines variables
long duration;
int distance;
void setup(){
Serial.begin(9600); //begins serial communication
pinMode(pirPin, INPUT);
pinMode(pirPos, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
digitalWrite(pirPos, HIGH);
//give the sensor time to calibrate
Serial.println("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(calibrationTime - i);
Serial.print("-");
Serial.println("done");
//while making this Instructable, I had some issues with the PIR's output
//going HIGH immediately after calibrating
//this waits until the PIR's output is low before ending setup
while (digitalRead(pirPin) == HIGH) {
Serial.print(".");
Serial.print("SENSOR ACTIVE");
void loop(){
while(digitalRead(pirPin) == HIGH){ //if the PIR output is HIGH, turn servo
/*turns servo from 0 to 180 degrees and back
it does this by increasing the variable "pos" by 1 every 5 milliseconds until it hits 180
and setting the servo's position in degrees to "pos" every 5 milliseconds
it then does it in reverse to have it go back
to learn more about this, google "for loops"
to change the amount of degrees the servo turns, change the number 180 to the number of degrees you want it to turn
myservoy.attach(4);
myservox.attach(3);
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
if(distance > 10){
for(pos = 90; pos < 180; pos += 1) //goes from 0 to 180 degrees
{ //in steps of one degree
myservoy.write(pos); //tells servo to go to position in variable "pos"
myservox.write(pos);
delay(20); //waits for the servo to reach the position
for(pos = 180; pos>=1; pos-= 1) //goes from 180 to 0 degrees
myservoy.write(pos); //to make the servo go faster, decrease the time in delays for
delay(20); //to make it go slower, increase the number.
for(pos = 0; pos < 180; pos += 1) //goes from 0 to 180 degrees
for(pos = 180; pos > 90; pos -= 1)
delay(20);
delay(400);
myservoy.detach();
myservox.detach();
if(distance <= 10){
myservoy.detach();
myservox.detach();
if(lockLow){
//makes sure we wait for a transition to LOW before further output is made
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
if(takeLowTime){
lowIn = millis(); //save the time of the transition from HIGH to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we can assume the motion has stopped
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
