[tuto] WS2812 independent patterns on a single strip
Hi! :slight_smile:
I'm opening this topic to share what I have found on this subject, share my work in progress and get some help if needed :wink:
► I would like to display independent patterns on one single strip: the project is to light a pinball.
chasing effect below the ramp
blink target to get bonus
rainbow effect when success
fading effects to illuminate backglass
► list of components:
About LED technologies comparison:
I've bought a WS2812/WS2811 strip of 50 RGB leds
https://fr.aliexpress.com/item/50pcs-Pre-wired-WS2812B-led-Chip-with-Heatsink-DC5V-WS2811-control-individually-Addressable-led-pixel-strip/32582314997.html
9€
I'm using a Arduino Nano 328
Arduino Nano — Arduino Official Store 20€
and a power supply 5V
50 LEDs: 15 Watts (about 3 Amps at 5 Volts)
https://fr.aliexpress.com/item/1PCS-5V3A-AC-100V-240V-Converter-Adapter-DC-5V-3A-3000mA-Power-Supply-EU-Plug-5/32700939534.html 2€
In order to get independence in the tasks, I followed the hint of "blink without delay"
a johnwasser code example "DaftPunkLights"
https://forum.arduino.cc/index.php?topic=105210.msg789378#msg789378
another code example
► libraries
and I found some dedicated libraries
neopixel adafruit GitHub - adafruit/Adafruit_NeoPixel: Arduino library for controlling single-wire LED pixels (NeoPixel, WS2812, etc.)
and tutorial Deconstructing the Loop | Multi-tasking the Arduino - Part 3 | Adafruit Learning System
FastLEd
Arduino Light Animation (ALA)
Check out my code in Reply #4 in this thread
https://forum.arduino.cc/index.php?topic=412232.0
This tutorial Deconstructing the Loop | Multi-tasking the Arduino - Part 3 | Adafruit Learning System
explains in detail how to drive several strips, each strip with its own pattern
But I would like to spare some pins and drive only a single strip!
I'll try to adapt the code to my use. Or I will rethink cutting the strip in multiple strips...
Thanks Grumpy_Mike, I will look at your code right now!
Then that is even simpler. Just use a restricted range of LED numbers for each pattern you want to work on.
I did it on a matrix and had each line of the matrix do a different pattern. However the code was in Python so not much point in posting it here.
I did that (but I didn't find it simplier ::slight_smile: ... I had to pass sub strips instead of patterns to the functions.
I created a structure to store informations on the sub strips and its associated pattern.
This draft is compiling OK (but untested yet, my hardware is at home)
// StrandTest from AdaFruit implemented as a state machine
// pattern change by push button
// By Mike Cook Jan 2016
#define PINforControl   7 // pin connected to 1 single NeoPixels strip
#define NUMPIXELS1      20 // number of LEDs on strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS1, PINforControl, NEO_GRB + NEO_KHZ800);
// Pattern types supported:
enum  pattern_type { NONE, BLINK, RAINBOW, RAINBOW_CYCLE, THEATER_CHASE_RAINBOW, COLOR_WIPE, FADING };
[b]struct subStrips {
  uint16_t startIndex;
  uint16_t nb_LED;
  pattern_type  activePattern;
  unsigned long patternInterval;
  unsigned long lastUpdate;
};[/b]
[b]// declare substrips
// the 20 LED are grouped by 7, 1, 1, 1, 1, 1, 7 (see image in the post)
subStrips stripRamp = {0, 7, THEATER_CHASE_RAINBOW, 20, 0 };
subStrips stripSingle1 = {7, 1, NONE, 20, 0 };
subStrips stripSingle2 = {8, 1, FADING, 20, 0 };
subStrips stripSingle3 = {9, 1, RAINBOW, 20, 0 };
subStrips stripSingle4 = {10, 1, BLINK, 20, 0 };
subStrips stripSingle5 = {11, 1, RAINBOW, 20, 0 };
subStrips stripAmbilight = {12, 7, RAINBOW_CYCLE, 20, 0 };[/b]
unsigned long patternInterval = 20 ; // time between steps in the pattern
unsigned long lastUpdate = 0 ; // for millis() when last update occoured
unsigned long intervals [] = { 20, 20, 50, 100 } ; // speed for each pattern
const byte button = 2; // pin to connect button switch to between pin and ground
  strip.begin(); // This initializes the NeoPixel library.
  wipe(); // wipes the LED buffers
  pinMode(button, INPUT_PULLUP); // change pattern
  // subStrip Ramp
  if(millis() - stripRamp.lastUpdate > stripRamp.patternInterval) updateSubStripPattern(stripRamp);
  // subStrip Single1
  if(millis() - stripSingle1.lastUpdate > stripSingle1.patternInterval) updateSubStripPattern(stripSingle1);
void  updateSubStripPattern(subStrips &substripOut){ // out parameter
  switch(substripOut.activePattern) {
    case NONE :
    wipeSubStrip(substripOut);
    case RAINBOW :
        rainbow(substripOut);
    case RAINBOW_CYCLE:
        rainbowCycle(substripOut);
    case THEATER_CHASE_RAINBOW:
        theaterChaseRainbow(substripOut);
    case COLOR_WIPE:
         colorWipe(substripOut, strip.Color(255, 0, 0)); // red
    case BLINK:
        blinkEffect(substripOut, 111);
void blinkEffect(subStrips &substrip, uint32_t color) {
    for(int i=substrip.startIndex; i<(substrip.startIndex+substrip.nb_LED) ; i++) {
      if (strip.getPixelColor(i) == 0) { strip.setPixelColor(i, color); }
      else { strip.setPixelColor(i, 0); }
    strip.show();
    substrip.lastUpdate = millis(); // time for next change to the display
void rainbow(subStrips &substrip) { // modified from Adafruit example to make it a state machine
  static uint16_t j=0;
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
     j++;
  if(j >= 256) j=0;
void rainbowCycle(subStrips &substrip) { // modified from Adafruit example to make it a state machine
void theaterChaseRainbow(subStrips &substrip) { // modified from Adafruit example to make it a state machine
void colorWipe(subStrips &substrip, uint32_t c) { // modified from Adafruit example to make it a state machine
void wipeSubStrip(subStrips &substrip){ // clear all LEDs
       strip.setPixelColor(i, strip.Color(0,0,0));
    strip.show();
    // substrip.lastUpdate = millis(); // no need to refresh LED off
 substrip.patternInterval = 10000000; // no need to refresh LED off
void wipe(){ // clear all LEDs
     for(int i=0;i<strip.numPixels();i++){
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
That seems an odd and complex way of doing things.
  • I'm glad to say it works fine! : multiple simultaneous patterns on my single LED strip!
(just corrected my draft Blink function which didn't blink :smiley: i'll edit the previous post)
    strip.show();
  • Thanks Grumpy_Mike!
    In my grand scheme :-[ it seemed interesting to address orders to sub strip passing pattern as an argument.
    Please advice me another way to follow!
Hi Mat
Did you ever finish this program by adding the extra Modes in?
Thanks for help
P.
Hi! I added few effects but not many... as I'm busy on other parts of my pinball code.
I needed a proof of concept to validate my choice for lightning. I'll come back later and dig deeper :wink:
What's your project @Pandora114118?
Mat13:
Maybe you can create another pixel strip object for different segment of the same strip and put them running into the same State Machine timing control.
OR , try this library
hi Mat13.. something wrong with your code here.. can you fix it?
thanks
Mat13:
struct subStrips {
uint16_t nb_LED;
// subStrip Ramp
// subStrip Single1
case NONE :
case RAINBOW :
case RAINBOW_CYCLE:
case COLOR_WIPE:
case BLINK:
strip.show();
strip.show();
j++;
if(j >= 256) j=0;
strip.show();
if(WheelPos < 85) {
WheelPos -= 85;
WheelPos -= 170;
ok.
Grumpy_Mike:
Hello @Mike,
Can you please share your python code. i am trying to do exactly what IOTcore trying to do but in python using RPi
Thanks
I am sorry, I am not trying to be funny but I can't seem to find it at the moment. What I did do was something in the Raspberry Pi for Dummies 3rd edition was a Broach on an 8 X 8 matrix board. That is just a long strip folded over, but that did not have separate patterns just a changing pattern. This was listing 17.7 in the book.
EDIT:- OK I remember now what happened, I wrote it for the Raspberry Pi for Dummies 3rd edition but it was not printed because the chapter was cut back due to page count issues. However, unfortunately I can't find it now. I think it was a victim of sudden SD card failure which affects all Pis that are not shut down correctly. Unfortunately you sometimes just have to pull the power plug from a Pi if it locks up and there is no other way of shutting it down.
In the MagPi magazine issue 69, I have a bouncing magnetic toy. That had an animation on effectively one one strip split into two regions, a circular section and a straight section at 90 degrees to it which I called a totem section. So this was basically two animation on a single strip.
You can get free PDF downloads of the article for the Magazine's web site. Here is a video of it in action:-
