TVout demo not compiling [Fixed]
I've placed all the header files in the libraries folder but get the following errors:
In file included from C:\Users\Henry\Documents\Arduino\libraries\TVout\pollserial.cpp:28:
C:\Users\Henry\Documents\Arduino\libraries\TVout\/pollserial.h:46: error: conflicting return type specified for 'virtual void pollserial::write(uint8_t)'
C:\Program Files\Arduino\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
Is this something stupid that I've (not) done (more than likely) or is it an error in the TVout code?
Also, how can I get to see ALL the tabs when some are off the RHS of the IDE screen? I can't find how to scroll through them.
How did you install the library ? (exactly how I mean. Explain everything you did from moment you downloaded it.
Goto Pollserial.h, on line 46 change virtual void to virtual size_t.
Also inside the function you need to return 0x01
When Arduino was upgraded to verison 1.0 the Print library was modified. Your library is a pre 1.0 version.
pYro_65:
Thanks, pYro, but I'm not certain what you mean by
Here's the original code:
  pollserial.h Heavily modified version of:
  HardwareSerial.h - Hardware serial library for Wiring
  Copyright (c) 2006 Nicholas Zambetti.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  Modified July 2010 by Myles D. Metzler
#ifndef PSERIAL_H
#define PSERIAL_H
#include <inttypes.h>
#include "Print.h"
typedef struct {
	uint8_t head;
	uint8_t tail;
	unsigned char * buffer;
} rbuffer;
//define a void function() return type.
typedef void (*pt2Funct)();
class pollserial : public Print {
	public:
		pt2Funct begin(long);
		void end();
		uint8_t available(void);
		int read(void);
		void flush(void);
		virtual void write(uint8_t);
		using Print::write; // pull in write(str) and write(buf, size) from Print
void USART_recieve();
#endif
I think he means this
	public:
		void end();
		int read(void);
		void flush(void);
		virtual size_t write(uint8_t);
                return 0x01;
raschemmel:
public:
	void end();
	int read(void);
	void flush(void);
return 0x01;
That causes even more errors!
Not quite, the class modification is fine, except for the return:
public:
void end();
int read(void);
void flush(void);
return 0x01;
In the location where the class functions are defined ( with code between {} ) you need to modify the function.
Maybe in pollserial.cpp there should be something that resembles the function below.
void pollserial::write(uint8_t){
  //some code
you need to modify it to look like:
size_t pollserial::write(uint8_t){
  //some code
  return 0x01;
pYro_65:
public:
void end();
int read(void);
void flush(void);
return 0x01;
//some code
  //some code
  return 0x01;
Thanks very much, pYro
