I want to write code where the two Arduinos exchange some data (two integers) via Ethernet, on a local network. Is there any code example for that?
this applies for the Wiznet shields with Ethernet library too:
could you give a setup code for both as well? I cannot make it work
see the examples of the Ethernet library
This is my issue, on the examples. For starters, I am not sure which model should I implement. Setup one board as web server and the other as web client? Is this enough for bidirectional data exchange?
not "web", just client and server
Which are the examples of the server-client model?
start with the ChatServer or PagerServer example and TelnetClient example
