hi, I want to create two effects in the same led strip, is it possible? or do I need to use two strips to control each effect? I just want to use an arduino nano for it.
i wish to combine a lightning effect and a monowave.
#include "FastLED.h"
#define NUM_LEDS 13
#define LED_DT 2
#define LED_CK 11
#define COLOR_ORDER GRB
#define CHIPSET WS2812
#define FREQUENCY 20 // controls the interval between strikes
#define FLASHES 8 // the upper limit of flashes per strike
#define BRIGHTNESS 255
CRGB leds[NUM_LEDS];
unsigned int dimmer = 1;
uint8_t ledstart; // Starting location of a flash
uint8_t ledlen; // Length of a flash
/* AZUL*/
// the data pin for the NeoPixels
#define DATA_PIN 3
// How many LEDs we will be using, charge according to your needs
#define NUM_LEDS 13
//time for a full loop in milliseconds. e.g : 5000ms is 5s.
#define TIME_LOOP 5500
//size of the wave
//e.g : NUM_LEDS to have a wave of the size of your LED strip that you already defined
//20 (or anything else) to have a shorter wave than the length of your LED strip
#define waveLength 20
* Define the color of the wave. You can use RGB, HEX or HSV color.
* Color values must be between 0 & 255.
* e.g for red color:
* RGB : const CRGB defaultColor = CRGB(255,0,0);
* HEX : const CRGB defaultColor = CRGB(0xFF0000);
* HSV : const CRGB defaultColor = CHSV(0,255,255);
const CRGB defaultColor = CRGB(0, 0, 255);
/********ADVANCED SETTINGS********/
* HALF_WAVE_SIZE : size ratio of the first part of the wave. Second part would be the remaining space.
* Used to determine the size and also the easing for the start and the end of the size.
* Must be between 0 & 1
#define HALF_WAVE_SIZE 0.5
* Define the Wave shape, choose one of the following choice.
* SOFT : Smooth wave, recommended
* HARD : Smooth with a deeper curve
* LINEAR : Spike effect
#define WAVE_TYPE SOFT
/******************CODE*****************/
/**************DO NOT TOUCH*************/
/*********unless you really need********/
#if WAVE_TYPE == SOFT
#define WAVE_EASING CubicEaseInOut
#elif WAVE_TYPE == HARD
#define WAVE_EASING QuinticEaseInOut
#else
#define WAVE_EASING Linear
#endif
//time variable
unsigned long time;
//half wave size, used for a smooth effect later
const int halfWaveSize = waveLength * HALF_WAVE_SIZE ;
void renderLEDs() {
time = millis();
for (int i = 0; i < NUM_LEDS; i++) {
float delta = ((float)(time % TIME_LOOP) / TIME_LOOP) * NUM_LEDS;
float v = getPixelValue(i, delta);
int r = defaultColor.r * v;
int g = defaultColor.g * v;
int b = defaultColor.b * v;
//used to prevent weird corlor variation.
if (r == 0 && defaultColor.r > 0 && v>0)
r = 1;
if (g == 0 && defaultColor.g > 0 && v>0)
g = 1;
if (b == 0 && defaultColor.b > 0 && v>0)
b = 1;
leds[i] = CRGB(r , g , b);
FastLED.show();
float getPixelValue(int index, float deltaI) {
float position = (index - deltaI);
if (position < 0) {
position = position + NUM_LEDS;
if (position >= 0 && position < waveLength) {
if (position < (float)halfWaveSize) {
float p = position / (halfWaveSize);
return WAVE_EASING(p);
else if (position < waveLength) {
float p = 1 - (position - halfWaveSize) / (halfWaveSize);
else {
return 0;
/******************EASING FUNCTIONS*****************/
float Linear(float p){
return p;
float CubicEaseInOut(float p)
if (p < 0.5)
return 4 * p * p * p;
float f = ((2 * p) - 2);
return 0.5 * f * f * f + 1;
float QuinticEaseInOut(float p)
if (p < 0.5)
return 16 * p * p * p * p * p;
return 0.5 * f * f * f * f * f + 1;
delay(1000); // allows reprogramming if accidently blowing power w/leds
LEDS.addLeds<CHIPSET, LED_DT, COLOR_ORDER>(leds, NUM_LEDS); // Use this for WS2812
// LEDS.addLeds<CHIPSET, LED_DT, LED_CK, COLOR_ORDER>(leds, NUM_LEDS); // Use this for WS2801 or APA102
FastLED.setBrightness(BRIGHTNESS);
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
//strip.begin(); // initialize the strip
//strip.show(); // make sure it is visible
//strip.clear(); // Initialize all pixels to 'off'
//strip.setBrightness(60);
//Serial.begin(9600);
} // setup()
ledstart = random8(NUM_LEDS); // Determine starting location of flash
ledlen = random8(NUM_LEDS-ledstart); // Determine length of flash (not to go beyond NUM_LEDS-1)
for (int flashCounter = 0; flashCounter < random8(3,FLASHES); flashCounter++) {
if(flashCounter == 0) dimmer = 5; // the brightness of the leader is scaled down by a factor of 5
else dimmer = random8(1,3); // return strokes are brighter than the leader
fill_solid(leds+ledstart,ledlen,CHSV(255, 0, 255/dimmer));
FastLED.show(); // Show a section of LED's
delay(random8(4,10)); // each flash only lasts 4-10 milliseconds
fill_solid(leds+ledstart,ledlen,CHSV(255,0,0)); // Clear the section of LED's
FastLED.show();
if (flashCounter == 0) delay (150); // longer delay until next flash after the leader
delay(50+random8(100)); // shorter delay between strokes
} // for()
delay(random8(FREQUENCY)*100);
} // loop()
and this
#include <FastLED.h>
FASTLED_USING_NAMESPACE
// FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN 5
//#define CLK_PIN 4
#define LED_TYPE WS2812
#define NUM_LEDS 60
#define BRIGHTNESS 64
#define FRAMES_PER_SECOND 120
delay(3000); // 3 second delay for recovery
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
//FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
// set master brightness control
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
rainbow(0, 19);
sinelon(20, 39);
juggle(40, 59);
// send the 'leds' array out to the actual LED strip
FastLED.show();
// insert a delay to keep the framerate modest
FastLED.delay(1000/FRAMES_PER_SECOND);
// do some periodic updates
EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void rainbow(int firstLed, int lastLed)
// FastLED's built-in rainbow generator
fill_rainbow( &leds[firstLed], lastLed-firstLed+1, gHue, 7);
void sinelon(int firstLed, int lastLed)
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( &leds[firstLed], lastLed-firstLed+1, 20);
int pos = beatsin16( 13, firstLed, lastLed );
leds[pos] += CHSV( gHue, 255, 192);
void juggle(int firstLed, int lastLed) {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for( int i = 0; i < 8; i++) {
leds[beatsin16( i+7, firstLed, lastLed )] |= CHSV(dothue, 200, 255);
dothue += 32;
thanks!
