Hi all, I am trying to install two libraries for testing but having some issues, I don't want to use them in the same sketches, but I want to have both installed for convenience.
It's a text file in the root folder of the Nico Hood MSGEQ7 library. library.properties contains metadata about the library. If present the name= field is used by Arduino as the display name of the library. If there is no library.properties file present in the root folder of the library then the library folder name is used for the library display name. MSGEQ7EngineeredEntropy doesn't contain a library.properties file so that's why the display name changed when you changed the folder name.
