Hi folks, hope someone can give me a useful pointer here…
I'm having trouble getting a GPS fix with a Neo 6M GPS module which I'm using to build a retro-styled (7-segment display) dashboard clock.
More specifics: it's a GY-GPS6MV2, hooked up to an Arduino Nano.
I'm a bit of a bodger rather than experienced coder, and have had some input from a more experienced friend on the coding side of this… long story short: I had the basics working previously (ie. module getting a fix, reading the UTC time from the GPS data, and using this to set the clock time) but with some display problems. Now that I've returned to it and resolved the display issues, the board just doesn't seem to be able to get a fix.
I haven't changed the hardware, and I don't think it is a code issue, nor a problem with the GPS board being damaged, as running a simple sketch to return data to the serial monitor will show me this kind of thing, over and over:
$GPRMC,,V,,,,,,,,,,N53
$GPVTG,,,,,,,,,N30
$GPGGA,,,,,,0,00,99.99,,,,,,48
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.9930
$GPGSV,1,1,0079
$GPGLL,,,,,,V,N64
$GPTXT,01,01,02,u-blox ag - www.u-blox.com50
⸮$GPTXT,01,01,02,u-blox ag - www.u-blox.com50
$GPTXT,01,01,02,HW UBX-G60xx 00040007 FF7FFFFFp53
$GPTXT,01,01,02,ROM CORE 6.02 (36023) Oct 15 2009 16:52:0856
$GPTXT,01,01,02,ANTSUPERV=AC SD PDoS SR20
$GPTXT,01,01,02,ANTSTATUS=DONTKNOW33
The "ANTSTATUS=DONTKNOW*33" part of it makes me wonder whether there's a problem with the antenna, but that seems a rather unlikely part of the system to be damaged by anything I've done - which is, basically, nothing hardware-wise apart from moving the test system outside so I can get a getter look at the sky (have always had trouble getting a fix indoors)
Any thoughts?
