sherzaad:
Not sure what you doing but I check the code with the fix I suggested and it return the expected value./*CRC-16 CCITT
CRC 16 bits
Polynomial 0x1021
Initial value 0xFFFF
No inverted input
No inverted output
No final XOR (0x0000)
uint16_t crc16_ccitt(int16_t data, int16_t data_len) {
uint16_t crc = 0xFFFF;
if (data_len == 0)
return 0;
for (unsigned int i = 0; i < data_len; ++i) {
uint16_t dbyte = data[i];
crc ^= dbyte << 8;
for (unsigned char j = 0; j < 8; ++j) {
uint16_t mix = crc & 0x8000;
crc = (crc << 1);
if (mix)
crc = crc ^ 0x1021;
return crc;
uint16_t test_data[9] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
Serial.println("crc16_ccitt algorithm test");
Serial.print("Data set: ");
for (int i = 0; i < 9; ++i) {
Serial.print(test_data[i], DEC);
Serial.print(", ");
Serial.print("\ncrc16_ccitt: 0x");
Serial.print(crc16_ccitt(test_data, 9), HEX);
Serial.println("");
Serial Monitor Output:
Data set: 49, 50, 51, 52, 53, 54, 55, 56, 57,
crc16_ccitt: 0x29B1CRC calculator check:
Yes, that's work Thank you ! ???
I have another issue: If I insert data in string like below code, I'll have error? Could you expalin me what will happen? I'm a little bit confused on the datatype configuration!
char test_data = "123456789";
Thank you in advance,
