uBlox Neo 6M with Arduino
Has anyone some experience of linking the uBlox 6M GPS to the arduino?
At first I would like it to print the the NMEA string $GPGGA to the terminal window…
ANY help, code ect would be greatly appreciated.
Many Thanks
A link to the GPS in question would be nice.
How have you tried connecting it? What code are you using? What results did you have?
Sorry, GPS is found http://www.u-blox.com/images/downloads/Product_Docs/NEO-6_DataSheet_(GPS.G6-HW-09005).pdf
Things have moved on a little now, I’ve got it reading now, using this code. I’ve had to use the old 023 version of Arduino to upload though, issue with BYTE.
Any help to get it to upload using the latest Arduino would be appreciated.
// A simple sketch to read GPS data and parse the $GPRMC string
// see http://www.ladyada.net/make/gpsshield for more info
#include <NewSoftSerial.h>
NewSoftSerial mySerial =  NewSoftSerial(5, 3);
#define powerpin 4
#define GPSRATE 9600
//#define GPSRATE 38400
// GPS parser for 406a
#define BUFFSIZ 90 // plenty big
char buffer[BUFFSIZ];
char *parseptr;
char buffidx;
uint8_t hour, minute, second, year, month, date;
uint32_t latitude, longitude;
uint8_t groundspeed, trackangle;
char latdir, longdir;
char status;
  if (powerpin) {
    pinMode(powerpin, OUTPUT);
  pinMode(13, OUTPUT);
  Serial.begin(GPSRATE);
  mySerial.begin(GPSRATE);
  // prints title with ending line break
  Serial.println("GPS parser");
   digitalWrite(powerpin, LOW);         // pull low to turn on!
  uint32_t tmp;
  Serial.print("\n\rread: ");
  readline();
  // check if $GPRMC (global positioning fixed data)
  if (strncmp(buffer, "$GPRMC",6) == 0) {
    // hhmmss time data
    parseptr = buffer+7;
    tmp = parsedecimal(parseptr);
    hour = tmp / 10000;
    minute = (tmp / 100) % 100;
    second = tmp % 100;
    parseptr = strchr(parseptr, ',') + 1;
    status = parseptr[0];
    parseptr += 2;
    // grab latitude & long data
    // latitude
    latitude = parsedecimal(parseptr);
    if (latitude != 0) {
      latitude *= 10000;
      parseptr = strchr(parseptr, '.')+1;
      latitude += parsedecimal(parseptr);
    // read latitude N/S data
    if (parseptr[0] != ',') {
      latdir = parseptr[0];
    //Serial.println(latdir);
    // longitude
    parseptr = strchr(parseptr, ',')+1;
    longitude = parsedecimal(parseptr);
    if (longitude != 0) {
      longitude *= 10000;
      longitude += parsedecimal(parseptr);
    // read longitude E/W data
      longdir = parseptr[0];
    // groundspeed
    groundspeed = parsedecimal(parseptr);
    // track angle
    trackangle = parsedecimal(parseptr);
    // date
    date = tmp / 10000;
    month = (tmp / 100) % 100;
    year = tmp % 100;
    Serial.print("\nTime: ");
    Serial.print(hour, DEC); Serial.print(':');
    Serial.print(minute, DEC); Serial.print(':');
    Serial.println(second, DEC);
    Serial.print("Date: ");
    Serial.print(month, DEC); Serial.print('/');
    Serial.print(date, DEC); Serial.print('/');
    Serial.println(year, DEC);
    Serial.print("Lat: ");
    if (latdir == 'N')
       Serial.print('+');
    else if (latdir == 'S')
       Serial.print('-');
    Serial.print(latitude/1000000, DEC); Serial.print('\°', BYTE); Serial.print(' ');
    Serial.print((latitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
    Serial.print((latitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((latitude%10000)*6/10)%100, DEC); Serial.println('"');
    Serial.print("Long: ");
    if (longdir == 'E')
       Serial.print('+');
    else if (longdir == 'W')
       Serial.print('-');
    Serial.print(longitude/1000000, DEC); Serial.print('\°', BYTE); Serial.print(' ');
    Serial.print((longitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
    Serial.print((longitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((longitude%10000)*6/10)%100, DEC); Serial.println('"');
  //Serial.println(buffer);
uint32_t parsedecimal(char *str) {
  uint32_t d = 0;
  while (str[0] != 0) {
   if ((str[0] > '9') || (str[0] < '0'))
     return d;
   d *= 10;
   d += str[0] - '0';
   str++;
  return d;
void readline(void) {
  char c;
  buffidx = 0; // start at begninning
  while (1) {
      c=mySerial.read();
      if (c == -1)
        continue;
      Serial.print(c);
      if (c == '\n')
        continue;
      if ((buffidx == BUFFSIZ-1) || (c == '\r')) {
        buffer[buffidx] = 0;
        return;
      buffer[buffidx++]= c;
It outputs in this format:
read:
$GPVTG,T,M,0.412,N,0.763,K,A*26
read:
$GPGGA,11.00,.90332,19,039,42,17,34,307,10*7E
read:
$GPGSV,9,12,157,31,20,65,236,22,23,18,177,14,28,18,261,20*7C
read:
,3,11,31,04,093,32,78,081,29,37,28,151,33*42
read:
$GPGLL,***.90315.84932,W,1*****1.00,A,A79
read:
$GPRMC,12.00,A,55.90332,N,000.84927,W,0.000,241112,A66
Time: 14:29:42
Date: 11/24/12
Lat: +
’ 1.99"
Long: -
*’ 29.56"
Only real issue is not being able to upload with 1.0 and is there something very simple I can run to output the data from the GPS (attached to pin4) to the terminal?
The exact messages that you get when you try to compile using 1.0 would be useful. The compiler, as I recall, practically holds your hand though, doing everything but typing the changes for you.
PaulS:
In file included from sketch_nov24a.ino:4:
D:\arduino-1.0.2-windows\arduino-1.0.2\libraries\NewSoftSerial/NewSoftSerial.h:55: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
D:\arduino-1.0.2-windows\arduino-1.0.2\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
sketch_nov24a.ino: In function 'void loop()':
sketch_nov24a:123: error: 'BYTE' was not declared in this scope
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
Highlighted in the cose is:
User downloaded libraries DO NOT go in the core libraries folder. Delete your install of Arduino 1.0.2, and start over.
Then, NewSoftSerial is NOT to be used with 1.0+. Use SoftwareSerial, instead.
