Hi
I have been trying to interface ublox neo 6m gps module, for a long time now, with many tries without success
Details are,
I am using ARduino Mega 2560 board connected
vcc of gps to 5v of mega
gnd of gps to gnd of mega
rx of gps to 11 of mega
tx of gps to 10 of mega
And the code is full example code of tinygpsplus of mikal hart available in arduino library manager
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
This sample code demonstrates the normal use of a TinyGPSPlus (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 10, TXPin = 11;
static const uint32_t GPSBaud = 4800;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F("FullExample.ino"));
Serial.println(F("An extensive example of many interesting TinyGPSPlus features"));
Serial.print(F("Testing TinyGPSPlus library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
Serial.println(F("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum"));
Serial.println(F(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail"));
Serial.println(F("----------------------------------------------------------------------------------------------------------------------------------------"));
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
printFloat(gps.hdop.hdop(), gps.hdop.isValid(), 6, 1);
printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
printInt(gps.location.age(), gps.location.isValid(), 5);
printDateTime(gps.date, gps.time);
printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.deg()) : "*** ", 6);
unsigned long distanceKmToLondon =
(unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON) / 1000;
printInt(distanceKmToLondon, gps.location.isValid(), 9);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
printFloat(courseToLondon, gps.location.isValid(), 7, 2);
const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
printInt(gps.charsProcessed(), true, 6);
printInt(gps.sentencesWithFix(), true, 10);
printInt(gps.failedChecksum(), true, 9);
smartDelay(1000);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
char sz[32] = "*****************";
if (valid)
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
if (!d.isValid())
Serial.print(F("********** "));
char sz[32];
sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
Serial.print(sz);
if (!t.isValid())
Serial.print(F("******** "));
char sz[32];
sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
Serial.print(sz);
printInt(d.age(), d.isValid(), 5);
smartDelay(0);
static void printStr(const char *str, int len)
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
smartDelay(0);
and the output it shows is some thing like this..
07:00:31.810 -> FullExample.ino
07:00:31.810 -> An extensive example of many interesting TinyGPSPlus features
07:00:31.810 -> Testing TinyGPSPlus library v. 1.0.2
07:00:31.843 -> by Mikal Hart
07:00:31.843 ->
07:00:31.843 -> Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum
07:00:31.843 -> (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail
07:00:31.843 -> ----------------------------------------------------------------------------------------------------------------------------------------
07:00:31.843 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 0 0 0
07:00:32.941 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 116 0 0
07:00:34.139 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 243 0 0
07:00:35.204 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 324 0 0
07:00:36.268 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 405 0 0
07:00:37.366 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 486 0 0
07:00:38.430 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 567 0 0
07:00:39.527 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 648 0 0
07:00:40.591 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 729 0 0
07:00:41.688 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 810 0 0
07:00:42.756 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 891 0 0
07:00:43.856 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 972 0 0
07:00:44.924 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1053 0 0
07:00:46.063 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1219 0 0
07:00:47.198 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1300 0 0
07:00:48.262 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1381 0 0
07:00:49.359 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1462 0 1
07:00:50.437 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1543 0 1
07:00:51.501 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1624 0 1
07:00:52.598 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1705 0 1
07:00:53.664 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1786 0 1
07:00:54.732 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1867 0 1
07:00:55.809 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1952 0 1
07:00:56.911 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2033 0 1
07:00:58.019 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2181 0 1
07:00:59.152 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2276 0 1
07:01:00.255 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2357 0 1
07:01:01.318 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2442 0 1
07:01:02.385 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2523 0 1
07:01:03.485 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2604 0 1
07:01:04.550 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2685 0 1
07:01:05.647 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2770 0 1
07:01:06.712 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2851 0 1
07:01:07.810 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2932 0 1
07:01:08.873 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3013 0 1
07:01:09.973 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3135 0 1
07:01:11.136 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3256 0 1
07:01:12.200 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3337 0 1
07:01:13.299 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3422 0 1
07:01:14.362 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3503 0 1
07:01:15.468 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3584 0 1
07:01:16.534 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3665 0 1
07:01:17.611 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3746 0 1
07:01:18.710 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3827 0 1
07:01:19.779 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3908 0 1
07:01:20.842 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3989 0 1
07:01:21.939 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4102 0 1
07:01:23.113 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4236 0 1
07:01:24.212 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4317 0 1
07:01:25.277 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4398 0 1
07:01:26.374 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4479 0 1
07:01:27.437 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4560 0 1
07:01:28.503 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4641 0 1
07:01:29.600 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4722 0 1
07:01:30.669 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4803 0 1
07:01:31.771 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4888 0 1
07:01:32.835 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4969 0 1
07:01:33.904 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5050 0 1
07:01:35.068 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5212 0 2
07:01:36.165 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5293 0 2
07:01:37.262 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5374 0 2
07:01:38.326 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5455 0 2
07:01:39.424 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5540 0 2
07:01:40.487 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5621 0 2
07:01:41.586 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5702 0 2
07:01:42.650 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5783 0 2
07:01:43.714 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5864 0 2
07:01:44.811 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5945 0 2
07:01:45.876 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6026 0 2
07:01:47.007 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6169 0 2
07:01:48.141 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6273 0 2
07:01:49.225 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6354 0 2
07:01:50.325 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6435 0 2
07:01:51.396 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6516 0
Can anyone out here help me in this? Thank you
