UDP Data to Variables
Mod edit space added to VB .NET
i have 2 Values coming through UDP from VB .NET and i am seeing them in My Serial Console,
image_2022-11-22_143230676
15000 , 8882 i need to place these values into 2 Variables in my Arduino to use elsewhere, can someone give me an example of this. thank you
have a look at Serial input basics section on Receiving numbers rather than text and parseInt()
you could use sscanf(), e.g.
  while(!Serial.available());   // wait for data
  char data[100]={0};
  Serial.readBytesUntil('\n',data,100);
  int  i,j;
  // find last space in string convert two integers
  if(sscanf(strrchr(data, ' '),"%d,%d", &i, &j)==2){
    Serial.println(i);
    Serial.println(j);
void loop() {}
when run using serial monitor input "Remote IP: 192.168.111.168 50155 15000,8882" output was
05:17:58.916 -> 15000
05:17:58.916 -> 8882
are you planning to connect your VB program to the COM port normally used by the Serial Monitor or use a seperate COM port?
The Data is Coming from Ethernet UDP Via VB.NET
read the UDP datagram into a char array and parse it as post # 2
e.g. this reads a UDP datagram and parses it
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 999;//8888;      // local port to listen on
EthernetUDP Udp;
  Serial.println("UDP  program");
  // start the Ethernet and UDP:
  if (Ethernet.begin(mac))Serial.println("Configured Ethernet using DHCP OK");
  else Serial.println("Failed to configure Ethernet using DHCP");
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  if (Udp.begin(localPort))Serial.println("UDP begin() OK");
  else Serial.println("UDP begin() failed!");
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize) {
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i = 0; i < 4; i++) {
      Serial.print(remote[i], DEC);
      if (i < 3) {
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    // read the packet into packetBufffer
    char data[50] = {0};
    int i = 0;
    Serial.print("data = ");
    for (i = 0; i < packetSize; i++) // process UDP PACKET FOR DATA
      Serial.print(data[i] = (char)Udp.read());     // read the NEXT byte and check it
    int  k, j;
    if (sscanf(strrchr(data, ' '), "%d,%d", &k, &j) == 2) {
      Serial.print("\nk= ");
      Serial.println(k);
      Serial.print("j= ");
      Serial.println(j);
I run a Java program to send a datagram
F:\temp>java UDPchat
chat program: IP address DELL2/192.168.1.68 port 999
Sending to 192.168.1.177 socket 999 data: Remote IP: 192.168.111.168 50155 15000,8882
on a UNO with Ethernet Shield V2 the Serial Monitor displays
07:47:14.369 -> UDP  program
07:47:26.476 -> Configured Ethernet using DHCP OK
07:47:26.511 -> My IP address: 192.168.1.177.
07:47:26.511 -> UDP begin() OK
07:47:40.575 -> Received packet of size 43
07:47:40.575 -> From 192.168.1.68, port 59021
07:47:40.575 -> data = Remote IP: 192.168.111.168 50155 15000,8882
07:47:40.575 -> k= 15000
07:47:40.575 -> j= 8882
running a VB.NET program to send a datagram console displays
VB.NET program: transmit UDP datagram
enter text to transmit ?
Arduino serial monitor displays
08:20:42.419 -> From 192.168.1.68, port 53555
08:20:42.419 -> data = Remote IP: 192.168.111.168 50155 15000,8882
08:20:42.419 -> k= 15000
08:20:42.419 -> j= 8882
