I am struggling with following code.
My idea is to send Weather values over Lora.
The programming comes more or less from my helium nodes where I use this.
However the decoding in Arduino is my problem.
I get as answer from the receiver:
Received packet '0 , 150 , 1 , 103 , 0 , 130 , 1 , 24 , 10 , 140 , 1 , 44 , 3 , 245 , 15 , 12 , ' with RSSI -62
How can I declutter it back to Integers again on the receiving end?
Best regards
Bart
Sender Code
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 866E6
int counter = 0;
uint8_t data[16];
//initialize Serial Monitor
Serial.println("LoRa Sender Test")
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
if (!LoRa.begin(BAND)) {
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("LoRa Initializing OK!");
LoRa.setSpreadingFactor(12);
LoRa.setSignalBandwidth(250000);
LoRa.setCodingRate4(8);
LoRa.enableCrc();
delay(2000);
// Generatepayload();
Serial.print("Sending packet: ");
Serial.println(counter);
int WindSpeed = 15;
int WindDir = 359;
int WindAv = 13;
int WindGust = 28;
int WindVar1 = 270;
int WindVar2 = 30;
int Qnh = 1013;
int Temp = 15;
int Dew = 12;
int LWS = ((int)(WindSpeed * 10));
int LWD = (int)(WindDir);
int LWA = (int)(WindAv * 10);
int LWG = (int)(WindGust * 10);
int LWV1 = (int)(WindVar1 * 10);
int LWV2 = (int)(WindVar2 * 10);
int LQ = (int)(Qnh);
byte LT = (int)(Temp);
byte LD = (int)(Dew);
data[0] = LWS >> 8;
data[1] = LWS;
data[2] = LWD >> 8;
data[3] = LWD;
data[4] = LWA >> 8;
data[5] = LWA;
data[6] = LWG >> 8;
data[7] = LWG;
data[8] = LWV1 >> 8;
data[9] = LWV1;
data[10] = LWV2 >> 8;
data[11] = LWV2;
data[12] = LQ >> 8;
data[13] = LQ;
data[14] = LT;
data[15] = LD;
// send packet
LoRa.beginPacket();
// LoRa.write(data);
LoRa.write((uint8_t *)(&data), sizeof(data));
LoRa.endPacket();
counter++;
delay(3000);
Receiver code
#include <SPI.h>
#include <LoRa.h>
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 866E6
Serial.println("LoRa Sender Test");
//SPI LoRa pins
while (1);
LoRa.enableCrc();
delay(2000);
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
uint8_t input = (uint8_t)LoRa.read();
Serial.print(input);
// Serial.print("(0x");
// Serial.print(input, HEX);
Serial.print(" , ");
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
int data[20]; //big enough to hold the data
byte index = 0; // start at zero
// read packet
data[index++] = input; // save the current data item
The values are now in the array to do whatever you want with
If I do that it returns with following error: error: invalid types 'uint8_t {aka unsigned char}[int]' for array subscript
LWS = (data[0] << 8) | data[1];
struct Data {
int WindSpeed;
int WindDir;
int WindAv;
int WindGust;
int WindVar1;
int WindVar2;
int Qnh;
int Temp;
int Dew;
Data data = { 15, 359, 13, 28, 170, 30, 1013, 15, 12 };
nothing was wrong with the bitshifting in the sender
in the receiver you need to read the bytes into an array then bitshift them out
e.g. a version of your sender - minor changes for the Feather 32u4 board and printing the transmitted data (always a good idea when testing)
//Sender Code
#include <SPI.h>
#include <LoRa.h>
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 866E6
int counter = 0;
uint8_t data[16];
while (!Serial);
//SPI LoRa pins
//SPI.begin(SCK, MISO, MOSI, SS);
//LoRa.setPins(SS, RST, DIO0);
LoRa.setPins(8, 4, 7); // for Lora 32u4
while (1);
LoRa.enableCrc();
delay(2000);
int WindSpeed = 15;
int WindDir = 359;
int WindAv = 13;
int WindGust = 28;
int WindVar1 = 270;
int WindVar2 = 30;
int Qnh = 1013;
int Temp = 15;
int Dew = 12;
data[0] = LWS >> 8;
data[1] = LWS;
data[2] = LWD >> 8;
data[3] = LWD;
data[4] = LWA >> 8;
data[5] = LWA;
data[6] = LWG >> 8;
data[7] = LWG;
data[9] = LWV1;
data[11] = LWV2;
data[12] = LQ >> 8;
data[13] = LQ;
data[14] = LT;
data[15] = LD;
// send packet
LoRa.beginPacket();
LoRa.endPacket();
for (int i = 0; i < sizeof(data); i++) {
// ((byte *) &data)[i] = LoRa.read();
Serial.print(' ');
Serial.print(((byte *) &data)[i]);
counter++;
delay(3000);
receiver code with bitshifting added
// Receiver code
#include <SPI.h>
#include <LoRa.h>
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 866E6
while (!Serial)
Serial.println("LoRa receiver Test");
//SPI LoRa pins
while (1)
LoRa.enableCrc();
delay(2000);
if (packetSize) {
uint8_t data[16];
LoRa.readBytes((byte *)&data, packetSize);
// read packet
//while (LoRa.available())
for (int i = 0; i < packetSize; i++) {
Serial.print(' ');
Serial.print(((byte *)&data)[i]);
int WindSpeed = 15;
int WindDir = data[0] << 8 | data[1];
Serial.print("WindDir ");
Serial.println(WindDir);
int WindAv = data[2] << 8 | data[3];
Serial.print("WindAv ");
Serial.println(WindAv);
int WindGust = data[4] << 8 | data[5];
Serial.print("WindGust ");
Serial.println(WindGust);
int WindVar1;
int WindVar2;
int Qnh;
int Temp;
int Dew = data[15];
Serial.print("Dew ");
Serial.println(Dew);
the bitshift code is assuming 16bit integers - probably have problems on a 32bit int host
it is s good idea to use int16_t just in case the code is ported to a different host
