I'm new to coding and have encountered this function in a new code I wanted to try however I don't understand what it means or what it exactly does. Can someone please clarify my doubt .Any help is appreciated.
This is the full code:
#include <Encoder.h>
// Delays for certain events in ms
const int ROTARY_DELAY = 100; // Time between checking for rotary turns
const int BUTTON_DELAY = 800; // Button debouncing, and repeating
const int FLASH_DELAY = 600; // How long to flash the entire row after button press
const int CURSOR_DELAY = 200; // How quickly to flash the cursor led
// Pin Assignments
uint8_t rota = 2;
uint8_t rotb = 3;
uint8_t button = 4;
uint8_t dataIn = 5;
uint8_t load = 6;
uint8_t clock = 7;
uint8_t trigger = 12;
int maxInUse = 1;
uint8_t x = 0;
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
Encoder knobLeft(rota, rotb);
char id = 0;
void putByte(byte data) {
byte i = 8;
byte mask;
while (i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask) { // choose bit
digitalWrite(dataIn, HIGH);// send 1
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the "easy" function to use for a //single max7219
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
digitalWrite(load, LOW); // and load da shit
digitalWrite(load, HIGH);
void maxAll (byte reg, byte col) { // initialize all MAX7219's in the system
int c = 0;
for ( c = 1; c <= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219's,
//whilele having a couple of them cascaded
int c = 0;
for ( c = maxInUse; c > maxNr; c--) {
putByte(0); // means no operation
for ( c = maxNr - 1; c >= 1; c--) {
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
pinMode(button, INPUT);
pinMode(trigger, OUTPUT);
digitalWrite(button, HIGH);
digitalWrite(13, LOW);
digitalWrite(trigger, LOW);
//initiation of the max 7219
maxAll(max7219_reg_scanLimit, 0x07);
maxAll(max7219_reg_decodeMode, 0x00); // using an led matrix (not digits)
maxAll(max7219_reg_shutdown, 0x01); // not in shutdown mode
maxAll(max7219_reg_displayTest, 0x00); // no display test
for (x = 1; x <= 8; x++) { // empty registers, turn all LEDs off
maxAll(x, 0);
maxAll(max7219_reg_intensity, 0x01 & 0x0f); // the first 0x0f is the value you can set range: 0x00 to 0x0f
// Value to display a single LED on a row
uint8_t values[9] = {0, 1, 2, 4, 8, 16, 32, 64, 128};
// Array with all rows, indicating which 'value' to show
uint8_t line[8] = {0, 0, 0, 0, 0, 0, 0, 0};
// What row we are current working with
uint8_t idx = 0;
// Our delay counters (in ms)
int delayButton = 0;
int delayRotary = ROTARY_DELAY;
int delayFlash = 0;
int delayCursor = CURSOR_DELAY;
int cursorState = 0;
// Rotary position, reset after each loop
long pos = 0;
// Do we update the matrix this run?
uint8_t update = 1;
void loop () {
// Flash the row after a button press
if (delayFlash && idx != 8) {
maxSingle(idx + 1, 255);
if (delayFlash == 1) {
maxSingle(idx + 1, values[line[idx + 1]]);
delayFlash--;
if (delayButton) delayButton--;
return;
// Check for button press
if (!digitalRead(4) && delayButton == 0) {
if (idx == 8)
idx = 0;
idx++;
delayButton = BUTTON_DELAY;
delayFlash = FLASH_DELAY;
// Checks for rotary turning, and update
// the matrix buffer
// My rotary encoder had '2 turns' per detent, making
// it awkward to move a single position. This is why
// the check is for > 1 and < -1 to make it a full detent.
if (delayRotary) delayRotary--;
if (delayRotary == 0 && idx != 8) {
pos = knobLeft.read();
if (pos > 1) {
if (line[idx] != 0)
line[idx]--;
line[idx] = 8;
update = 1;
} else if (pos < -1) {
if (line[idx] != 8)
line[idx]++;
line[idx] = 0;
update = 1;
if (update) {
knobLeft.write(0);
if (pos) {
cursorState = 1;
// Toggle the state of the cursor after the
// cursor delay (in ms) has been reached
if (delayCursor) delayCursor--;
if (delayCursor == 0 && idx != 8) {
cursorState = 1 - cursorState;
update = 1;
// Update the matrix only if a change has been made
if (update) {
for (x = 0; x < 8; x++) {
if (x == idx) {
if (cursorState && line[x] != 0)
maxSingle(x + 1, values[line[x]]);
maxSingle(x + 1, 0);
if (line[x] == 0) continue;
digitalWrite(trigger, HIGH);
digitalWrite(trigger, LOW);t
update = 0;
delay(1);
