Hello all, I found this code online and I want to add a second ultrasonic sensor to it. I have them wired to the same pins. Would I have to include the second sensor into the code? If so could someone help me?
Please post your code.
In code tags.
Are you saying you've got both sensors wired to the same pins as each other?
Or same pins as the example code?
What type of ultrasonic sensors are you using ?
Please post a schematic of your project
Your post was MOVED to its current location as it is more suitable
Here is the link for the project im modifying.
https://create.arduino.cc/projecthub/ronfrtek/arduino-led-ring-ultrasonic-distance-sensor-d15582
It is the Hc-sr04 both sensors are wired to the same pins.
// Sketch Generated by Visuino
// www.visuino.com
// Version 8.0.0.37
//------------------ Source --------------------
// neo-pixel-distance-ultrasound.visuino
#define VISUINO_ARDUINO_NANO
#include <OpenWire.h>
#include <Mitov.h>
#include <Mitov_UltrasonicRanger.h>
#ifdef __VISUINO_USE_NEO_PIXELS_BUS_LIBRARY__
#include <NeoPixelBrightnessBus.h> // The NeoPixelBus library https://github.com/Makuna/NeoPixelBus needs to be installed trough the Arduino IDE for this Scetch to compile!
#else // __VISUINO_USE_NEO_PIXELS_BUS_LIBRARY__
#include <Adafruit_NeoPixel.h> // The Adafruit NeoPixel library https://github.com/adafruit/Adafruit_NeoPixel to be installed trough the Arduino IDE for this Scetch to compile!
#endif // __VISUINO_USE_NEO_PIXELS_BUS_LIBRARY__
#include <Mitov_NeoPixel.h>
#include <Mitov_RampToValue.h>
#include <Mitov_Converters.h>
#include <Mitov_MultiMerger.h>
#include <Mitov_Math.h>
// Shared Component Member Variables
namespace ComponentVariables
class
public:
bool Value1 : 1;
uint32_t Value2 : 3;
bool Value3 : 1;
bool Value4 : 1;
bool Value5 : 1;
bool Value6 : 1;
bool Value7 : 1;
bool Value8 : 1;
bool Value9 : 1;
bool Value10 : 1;
} BitFields;
class Variable1
public:
inline static bool GetValue() {
return BitFields.Value1;
inline static void SetValue( bool AValue ) {
BitFields.Value1 = AValue;
class Variable2
public:
inline static uint32_t GetValue() {
return BitFields.Value2;
inline static void SetValue( uint32_t AValue ) {
BitFields.Value2 = AValue;
class Variable3
public:
return BitFields.Value3;
BitFields.Value3 = AValue;
class Variable4
public:
return BitFields.Value4;
BitFields.Value4 = AValue;
class Variable5
public:
return BitFields.Value5;
BitFields.Value5 = AValue;
class Variable6
public:
return BitFields.Value6;
BitFields.Value6 = AValue;
class Variable7
public:
return BitFields.Value7;
BitFields.Value7 = AValue;
class Variable8
public:
return BitFields.Value8;
BitFields.Value8 = AValue;
class Variable9
public:
return BitFields.Value9;
BitFields.Value9 = AValue;
class Variable10
public:
return BitFields.Value10;
BitFields.Value10 = AValue;
class Shared_float_0 : public ::ComponentVariables::Variable6
protected:
static float FValue;
public:
inline static float GetVariableValue( const float AInitialValue )
if ( ::ComponentVariables::Variable6::GetValue() )
return FValue;
return AInitialValue;
inline static void SetVariableValue( const float AValue ) {
FValue = AValue;
::ComponentVariables::Variable6::SetValue( true );
inline static float &GetReference() {
return FValue;
inline Shared_float_0() {
::ComponentVariables::Variable6::SetValue( false );
float Shared_float_0::FValue;
} // ComponentVariables
// Arduino Constant Declarations
namespace VisuinoConstants
class FloatValue0
public:
inline static constexpr float GetValue() {
return 10000;
class FloatValue3
public:
return 1000;
class FloatValue2
public:
return 0;
class FloatValue5
public:
return 10;
class FloatValue1
public:
return 0.401123046875;
class FloatValue4
public:
return 1;
} // VisuinoConstants
// Pin Call Declarations
namespace PinCalls
class PinCallerReceive0
public:
void Notify( void *_Data );
class PinCallerReceive1
public:
class PinCallerReceive2
public:
class PinCallerReceive3
public:
class PinCallerReceive4
public:
class PinCallerReceive5
public:
class PinCallerReceive6
public:
class PinCallerReceive7
public:
} // PinCalls
// Call Chains
namespace CallChains
class InterruptRaising1
public:
inline static uint32_t Count() {
return 1;
static void Call();
class InterruptFalling1
public:
return 1;
static void Call();
class TryActive1
public:
return 0;
static void Call( bool & AResult );
class TryActive2
public:
return 0;
} // CallChains
// System Objects Declarations
namespace BoardDeclarations
Mitov::TElapsedMicros ElapsedSystemMicros;
} // BoardDeclarations
// Arduino Board Declarations
namespace Types
typedef Mitov::ArduinoDigitalOutputChannel <
Mitov::ConstantProperty<22, bool, false>, // IsAnalog
Mitov::ConstantProperty<24, bool, false>, // IsCombinedInOut
Mitov::ConstantProperty<21, bool, false>, // IsOpenDrain
Mitov::ConstantProperty<26, bool, false>, // IsOutput
Mitov::ConstantProperty<20, bool, false>, // IsPullDown
Mitov::ConstantProperty<5, bool, false >, // IsPullUp
Mitov::ConstantProperty<23, bool, false>, // IsRawInput
Mitov::DigitalPin_NoImplementation<6 >, // OutputPin
3 // PIN
> ArduinoDigitalChannel_3;
} // Types
namespace Instances
Types::ArduinoDigitalChannel_3 ArduinoDigitalChannel_3;
} // Instances
// Interrupts
namespace Interrupts
void __ICACHE_RAM_ATTR__ Handler3();
OpenWire::PinChangeInterrupt<3, ::CallChains::InterruptRaising1, ::CallChains::InterruptFalling1> Pin3;
Pin3.InterruptHandler();
} // Interrupts
// Declarations
namespace Declarations
namespace Types
typedef Mitov::UltrasonicRanger_Interrupt <
Mitov::ConstantProperty<5, bool, false>, // ClockInputPin_o_IsConnected
Mitov::ConstantProperty<7, bool, true >, // Enabled
Mitov::TypedVariable<15, bool, ::ComponentVariables::Variable1 >, // FClocked
Mitov::TypedVariable<17, uint32_t, ::ComponentVariables::Variable2 >, // FState
Mitov::AnalogPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive0 >, // OutputPin
Mitov::ConstantProperty<12, uint32_t, 100 >, // PauseTime
Mitov::DigitalPin_DirectBoardPinImplementation<2 >, // PingOutputPin
Mitov::ConstantProperty<11, uint32_t, 2 >, // PingTime
Mitov::ConstantProperty<9, uint32_t, 1000 >, // Timeout
Mitov::DigitalPin_NoImplementation<6 >, // TimeoutOutputPin
Mitov::ConstantPropertyFloat<10, float, ::VisuinoConstants::FloatValue0 >, // TimeoutValue
Mitov::ConstantProperty<8, Mitov::TArduinoRangerUnits, Mitov::rdCm > // Units
> UltrasonicRanger1;
} // Types
namespace Instances
Types::UltrasonicRanger1 UltrasonicRanger1;
} // Instances
namespace NeoPixel_Declarations
namespace NeoPixelType
typedef NeoPixelBrightnessBus<NeoGrbFeature, Neo800KbpsMethod> NeoPixels1;
NeoPixelType::NeoPixels1 NeoPixels1( 16, 6 );
typedef Adafruit_NeoPixel NeoPixels1;
NeoPixelType::NeoPixels1 NeoPixels1( 16, 6, NEO_GRB + NEO_KHZ800 );
} // NeoPixel_Declarations
namespace Types
typedef Mitov::NeoPixels <
NeoPixel_Declarations::NeoPixelType::NeoPixels1, // 0_TYPE
NeoPixel_Declarations::NeoPixels1, // 1_NAME
Mitov::ConstantPropertyFloat<6, float, ::VisuinoConstants::FloatValue1 >, // Brightness
Mitov::TypedVariable<8, bool, ::ComponentVariables::Variable3 > // FModified
> NeoPixels1;
} // Types
namespace Instances
Types::NeoPixels1 NeoPixels1;
} // Instances
namespace Types
typedef Mitov::NeoPixelsColorPixelGroup <
Declarations::Types::NeoPixels1, // 0_TYPE_OWNER
Declarations::Instances::NeoPixels1, // 1_NAME_OWNER
16, // COUNT
Mitov::TypedVariable<7, bool, ::ComponentVariables::Variable4 >, // FModified
Mitov::VariablePropertyColor<3, Mitov::TRGBWColor, uint64_t, 0x00000000 >, // InitialColor
Mitov::VariableProperty<6, uint32_t, 0 >, // InitialIndex
0 // START
> TArduinoNeoPixelsColorPixelGroup1;
} // Types
namespace Instances
Types::TArduinoNeoPixelsColorPixelGroup1 TArduinoNeoPixelsColorPixelGroup1;
} // Instances
namespace Types
typedef Mitov::ValueSource <
Mitov::EmbeddedCallChain<CallChains::TryActive1 >, // Elements_TryActive
Mitov::TypedPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive1, Mitov::TColor >, // OutputPin
Mitov::TColor, // TYPE
Mitov::ConstantPropertyColor<5, Mitov::TColor, uint32_t, 0x0000FF > // Value
> ColorValue1;
} // Types
namespace Instances
Types::ColorValue1 ColorValue1;
} // Instances
namespace Types
typedef Mitov::RampToValue <
Mitov::ConstantProperty<5, bool, true >, // Enabled
Mitov::TypedVariable<10, bool, ::ComponentVariables::Variable5 >, // FModified
Mitov::VariablePropertyFloat<7, float, ::VisuinoConstants::FloatValue2 >, // InitialValue
Mitov::ConstantPropertyFloat<9, float, ::VisuinoConstants::FloatValue2 >, // MaxStep
Mitov::AnalogPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive2 >, // OutputPin
Mitov::ConstantPropertyFloat<8, float, ::VisuinoConstants::FloatValue3 > // Slope
> RampToValue1;
} // Types
namespace Instances
Types::RampToValue1 RampToValue1;
} // Instances
namespace Types
typedef Mitov::AnalogToUnsigned <
Mitov::ConstantProperty<7, bool, true >, // Constrain
Mitov::TypedPin_EmbeddedPinImplementation<5, ::PinCalls::PinCallerReceive3, uint32_t >, // OutputPin
Mitov::ConstantProperty<6, bool, true >, // Round
Mitov::ConstantPropertyFloat<4, float, ::VisuinoConstants::FloatValue4 > // Scale
> AnalogToUnsigned1;
} // Types
namespace Instances
Types::AnalogToUnsigned1 AnalogToUnsigned1;
} // Instances
namespace Types
typedef Mitov::MultiMerger <
2, // COUNT_InputPins
Mitov::TypedPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive4, Mitov::TRGBWColor > // OutputPin
> RGBWColorMultiMerger1;
} // Types
namespace Instances
Types::RGBWColorMultiMerger1 RGBWColorMultiMerger1;
} // Instances
namespace Types
typedef Mitov::CompareValue_Binding <
Mitov::CompareType_Implementation_ctBigger, // CompareType
Mitov::ConstantProperty<4, bool, true >, // Enabled
Mitov::TypedVariable<9, bool, ::ComponentVariables::Variable7 >, // FStarted
Mitov::ConstantProperty<8, bool, true >, // OnlyChanged
Mitov::DigitalPin_EmbeddedPinImplementation<5, ::PinCalls::PinCallerReceive5 >, // OutputPin
float, // TYPE
Mitov::SharedVariablePropertyFloat<6, float, ::VisuinoConstants::FloatValue5, ::ComponentVariables::Shared_float_0 > // Value
> CompareValue1;
} // Types
namespace Instances
Types::CompareValue1 CompareValue1 = Types::CompareValue1( 0.0f );
} // Instances
namespace Types
Mitov::CompareType_Implementation_ctSmaller, // CompareType
Mitov::TypedVariable<9, bool, ::ComponentVariables::Variable8 >, // FStarted
Mitov::DigitalPin_EmbeddedPinImplementation<5, ::PinCalls::PinCallerReceive6 >, // OutputPin
float, // TYPE
Mitov::SharedVariablePropertyFloat<6, float, ::VisuinoConstants::FloatValue2, ::ComponentVariables::Shared_float_0 > // Value
> CompareValue2;
} // Types
namespace Instances
Types::CompareValue2 CompareValue2 = Types::CompareValue2( 0.0f );
} // Instances
namespace Types
Mitov::EmbeddedCallChain<CallChains::TryActive2 >, // Elements_TryActive
Mitov::TypedPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive7, Mitov::TColor >, // OutputPin
Mitov::ConstantPropertyColor<5, Mitov::TColor, uint32_t, 0x00FF00 > // Value
> ColorValue2;
} // Types
namespace Instances
Types::ColorValue2 ColorValue2;
} // Instances
} // Declarations
// Type Converters
namespace TypeConverters
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable9 >> Converter0;
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable10 >> Converter1;
} // TypeConverters
// Bindings
namespace Bindings
inline void CompareValue1_ValueInputPin_o_Receive( void * ___PTR___, float __AOriginalValue__ )
float ___A_VALUE___ = *(float *)___PTR___;
Declarations::Instances::CompareValue1.SetValue( __AOriginalValue__, ___A_VALUE___ );
inline void CompareValue2_ValueInputPin_o_Receive( void * ___PTR___, float __AOriginalValue__ )
Declarations::Instances::CompareValue2.SetValue( __AOriginalValue__, ___A_VALUE___ );
} // Bindings
// Call Chains
void InterruptRaising1::Call()
Declarations::Instances::UltrasonicRanger1.InterruptHandler( true );
void InterruptFalling1::Call()
Declarations::Instances::UltrasonicRanger1.InterruptHandler( false );
void TryActive1::Call( bool & AResult )
void TryActive2::Call( bool & AResult )
} // CallChains
namespace PinCalls
void PinCallerConverterReceive1( void *_Data );
void PinCallerConverterReceive2( void *_Data );
} // PinCalls
// Pin Call Implementations
namespace PinCalls
void PinCallerReceive0::Notify( void *_Data )
float __Value_CompareValue1_ValueInputPin__ = Declarations::Instances::CompareValue1.Value();
float __Value_CompareValue2_ValueInputPin__ = Declarations::Instances::CompareValue2.Value();
Declarations::Instances::RampToValue1.InputPin_o_Receive( _Data );
::Bindings::CompareValue1_ValueInputPin_o_Receive( _Data, __Value_CompareValue1_ValueInputPin__ );
::Bindings::CompareValue2_ValueInputPin_o_Receive( _Data, __Value_CompareValue2_ValueInputPin__ );
void PinCallerReceive1::Notify( void *_Data )
Declarations::Instances::RGBWColorMultiMerger1.InputPins_o_Receive( 0, _Data );
void PinCallerReceive2::Notify( void *_Data )
Declarations::Instances::AnalogToUnsigned1.InputPin_o_Receive( _Data );
Declarations::Instances::CompareValue1.InputPin_o_Receive( _Data );
Declarations::Instances::CompareValue2.InputPin_o_Receive( _Data );
void PinCallerReceive3::Notify( void *_Data )
Declarations::Instances::TArduinoNeoPixelsColorPixelGroup1.IndexInputPin_o_Receive( _Data );
void PinCallerReceive4::Notify( void *_Data )
Declarations::Instances::TArduinoNeoPixelsColorPixelGroup1.ColorInputPin_o_Receive( _Data );
void PinCallerReceive5::Notify( void *_Data )
TypeConverters::Converter0.Convert( _Data, PinCallerConverterReceive1 );
Declarations::Instances::ColorValue1.ClockInputPin_o_Receive( _Data );
void PinCallerReceive6::Notify( void *_Data )
TypeConverters::Converter1.Convert( _Data, PinCallerConverterReceive2 );
Declarations::Instances::ColorValue2.ClockInputPin_o_Receive( _Data );
void PinCallerReceive7::Notify( void *_Data )
Declarations::Instances::RGBWColorMultiMerger1.InputPins_o_Receive( 1, _Data );
} // PinCalls
namespace ComponentsHardware
void SystemUpdateHardware()
} // ComponentsHardware
//The setup function is called once at startup of the sketch
BoardDeclarations::ElapsedSystemMicros.SystemStarted();
BoardDeclarations::Instances::ArduinoDigitalChannel_3.SystemInit();
Declarations::Instances::NeoPixels1.SystemInit();
Interrupts::Pin3.Init( Interrupts::Handler3 );
BoardDeclarations::Instances::ArduinoDigitalChannel_3.SystemStart();
Declarations::Instances::UltrasonicRanger1.SystemStart();
Declarations::Instances::TArduinoNeoPixelsColorPixelGroup1.SystemStart();
Declarations::Instances::RampToValue1.SystemStart();
Declarations::Instances::CompareValue1.SystemStart();
Declarations::Instances::CompareValue2.SystemStart();
// The loop function is called in an endless loop
unsigned long AElapsedMicros = BoardDeclarations::ElapsedSystemMicros.GetNewElapsedTime();
BoardDeclarations::Instances::ArduinoDigitalChannel_3.SystemLoopBegin();
Declarations::Instances::UltrasonicRanger1.SystemLoopBegin();
Declarations::Instances::TArduinoNeoPixelsColorPixelGroup1.SystemLoopBegin();
Declarations::Instances::RampToValue1.SystemLoopBeginElapsed( AElapsedMicros );
Declarations::Instances::RampToValue1.SystemLoopBegin();
Declarations::Instances::NeoPixels1.SystemLoopEnd();
That's very unlikely to produce any useful results.
That's an awful lot of code for something so simple.
Just reposted the code where I found the project
Why do you need another US sensor?
Will they be in the same direction?
Remember that the irradiation and return of a sound emission is like a cone.
Depending on how the assembly is done, one US can interfere with the other US.
The code you posted looks to be machine-generated code, not really the sort of thing anyone would write.
If you want to modify that Visuino project you will have to do it in the Visuino environment.
Add a second "Ultrasonic Ranger(Ping)" component. Connect the Trigger and Echo pins to two Arduino pins. Connect the output to some variable. Use that variable to control something.
If you want to learn how to do the same thing with Arduino programming instead of Visuino programming, you will have to start with an Arduino example.
This is autogenerated code by Visuino.
It is automatically highly optimized to reduce memory usage by using many different advanced tricks such as using single bits between bytes for different components, and is also designed to handle multiple sensors simultaneously.
Modifying such code by hand is very complex, and requires deep knowledge of how to optimize code to reduce memory usage (Takes a lot of source code to actually reduce binary footprint).
It is best to use Visuino to modify the original project. It is easy and free for what you are trying to achieve.
each sensor would be place 180 degrees from one another
