Ultrasonic detect object
Arduino code when ultrasonic sensor detect object after 5 min buzzer will turn on, after 5 min, if ultrasonic sensor detect object motor will turn on, other wish motor will not turn on
// Define the pins for ultrasonic sensor, buzzer, and motor
const int trigPin = 10; // Trig pin of ultrasonic sensor
const int echoPin = 9; // Echo pin of ultrasonic sensor
const int buzzerPin = 2; // Buzzer pin
const int motorPin = 5; // Motor pin
// Define the distance threshold to detect an object
const int objectThreshold = 280; // Adjust this value as needed
// Define variables to track time
unsigned long startTime = 0;
unsigned long detectionTime = 0;
  // Initialize the serial communication for debugging
  // Initialize the pins
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(motorPin, OUTPUT);
  // Turn off the motor and buzzer initially
  digitalWrite(buzzerPin, LOW);
  digitalWrite(motorPin, LOW);
  // Calculate the distance using the ultrasonic sensor
  long duration;
  int distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.034 / 2; // Calculate distance in cm
  // Print the distance for debugging
  Serial.print("Distance: ");
  Serial.println(distance);
  // Check if an object is detected
  if (distance < objectThreshold) {
    // If an object is detected, start the timer
    if (startTime == 0) {
      startTime = millis();
    // Check if 5 minutes have passed since the object detection (for testing i set it 2 sec.)
    if (millis() - startTime >= 2000) {
      // Turn on the buzzer
      digitalWrite(buzzerPin, HIGH);
    // Check if 10 minutes have passed since the object detection  (for testing i set it 4 sec.)
    if (millis() - startTime >= 4000) {
      // Turn on the motor
      digitalWrite(motorPin, HIGH);
    // Reset the timer and turn off the buzzer and motor
    startTime = 0;
My Question : This code is not work my expectation , if i need any change please suggest.
Hello bijoy01
I assume that you have written the sketch by yourself, then it is quite easy to find the error.
There's a trick to figuring out why something isn't working:
Use a logic analyzer to see what happens.
Put Serial.print statements at various places in the code to see the values of variables and determine whether they meet your expectations.
Hi, @bijoy01
Have you tried the NewPing library, it will do most of the work for you and there are example codes to use?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
