diseaf
August 2, 2020, 6:37pm
1
Hello,
I'm fairly new to all of this and I'm currently having trouble combining the Ultrasonic Module HC-SRO4 with
DFPlayer Mini DFR0299.I'm trying to switch to the next song when the distance is less than 10cm between my hand and the Ultrasonic module.Currently when i run my program it keeps switching between songs alone but when my hand is in front of the sensor it stops switching songs.Btw I combined 2 programs from other projects.Is there any way for me to use the Ultrasonic module as a switch and play the next song or must i stick to button switches.
Thanks.
Please post your code.
Don't forget the code tags.
diseaf
August 2, 2020, 6:52pm
3
/// MP3 PLAYER PROJECT
/// http://educ8s.tv/arduino-mp3-player/
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
# define trigPin 7
# define echoPin 6
# define led 2
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
boolean isPlaying = false;
void setup () {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
playFirst();
isPlaying = true;
void loop () {
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Serial.print(distance);
Serial.println(" cm");
delay(10);
if (distance >10)
play();
if (distance <10){
playNext();
void playFirst()
execute_CMD(0x3F, 0, 0);
setVolume(60);
execute_CMD(0x11,0,1);
void pause()
execute_CMD(0x0E,0,0);
void play()
execute_CMD(0x0D,0,1);
void playNext()
execute_CMD(0x01,0,1);
void playPrevious()
execute_CMD(0x02,0,1);
void setVolume(int volume)
execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
delay(2000);
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
