Somebody know how to get the value that de ultrasonic sensor send to my arduino on the lcd_I2C?
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
int trigPin = 9; // TRIG pin
int echoPin = 8; // ECHO pin
float duration_us, distance_cm;
Serial.begin(9600); //Serial baud rate
lcd.begin (16,2);
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.home ();
lcd.print("Hello");
delay(2000);
lcd.clear();
// configure the trigger pin to output mode
pinMode(trigPin, OUTPUT);
// configure the echo pin to input mode
pinMode(echoPin, INPUT);
{ // generate 10-microsecond pulse to TRIG pin
digitalWrite(trigPin, HIGH);
delayMicroseconds(10000);
digitalWrite(trigPin, LOW);
// measure duration of pulse from ECHO pin
duration_us = pulseIn(echoPin, HIGH);
// calculate the distance
distance_cm = 0.017 * duration_us;
// print the value to Serial Monitor
Serial.print("distance: ");
Serial.print(distance_cm);
Serial.println(" cm");
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
Welcome to the forum
lcd.home ();
lcd.print("Hello");
If this prints Hello on the LCD, then have you tried printing the distance_cm variable in loop() instead ?
yes , i tried that and it doesn't show something on my lcd.
Post the sketch showing what you tried
You mean the wiring diagram?
I actually meant the sketch but the schematic would be interesting too
this is what i tried. I'm just a beginner but this is my topic for school and i like to work with arduino so I will try till it works. I appreciate that you are helping me to find my solution
lcd.begin (16,2);
lcd.backlight();
lcd.home ();
lcd.print(distance_cm);
delay(2000);
lcd.clear();
Have you ever seen anything printed on the LCD ?
yes the program works now i think i will just add a button that when i push it the ultrasonic sensor only measure then. Thanks a lot for your help
lcd.begin (16,2);
lcd.backlight();
lcd.home ();
delay(2000);
lcd.clear();
delay(5000);
delay(5000);
lcd.clear();
