Ultrasonic sensor
I’m trying to recreate an ultrasonic sensor project I saw on YouTube. The wiring is pretty simple and the programming is straightforward. But the serial output is odd, so I’m missed something.
long duration;
int distance;
const int trigPin = 10;
const int echoPin = 11;
  pinMode (trigPin, OUTPUT);
  pinMode (echoPin, INPUT);
void loop (){
  // put your main code here, to run repeatedly;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.034 / 2;
  Serial.print("Distance: ");
  Serial.println(distance);
in the sketch
in the Serial monitor
They must match
That worked. Thanks guys.
The most common problem is the serial monitor speed not set to the same of the Serial.begin(115200). Check the monitor speed, set it to 115200:
