ultrasonic transducer arduino circuit- plz plz plz help!
hi all,
I need help with my uni project and i have been stuck at this point for days.
All i want to now is to transmit ultrasound using the arduino board. AND THATS IT!! I dont want want to detect or anything else at this point .
this is the UT i am using http://www.jaycar.com.au/products_uploaded/AU5550.pdf
and this is my source code
const int pingPin = 9;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(23);
negetive pin is grounded and positive pin is connected to 5v.
My question are :-
From my calculation , the frequency is 40kHz . Am i right ?
2)how can i calculate the p-p voltage ?
3) Do i need to use a op-amp to drive the ut ?
4)Also is there any to know if the UT is working ?
I am a real noob with electronics and so plz help me with this.
thanks in advance!
    { tone(9, 40000); }
void loop() { }
If you use a digital output the Peak to Peak voltage is 5 volts (or very close to it).
I don't know how you would detect the 40 kHz signal without a oscilloscope. If you had a second Arduino and a second transducer you could try playing a 41000 Hz tone and listen for the 1 kHz beat frequency.
hey mate,
Thanks for the code . Will give it a go now.
now just to make sure, so i can just connect my UT to the arduino pins and thats it?
do i need any amplifier or anything else at all ?
thanks
The transducer will take up to 140 volts (when sending 0.4 milliseconds pulses every 10 milliseconds) so I don't think you will get much volume at 5 volts. You may want to add a transformer and driver transistor to boost the voltage.
