Unable to communicate with SIM7600G-H (ESP32)
Hello all...
I am attempting to communicate with a SIM7600 from Waveshare (doc: https://www.waveshare.com/wiki/SIM7600E-H_4G_HAT) (schematic: https://www.waveshare.com/w/upload/c/c8/SIM7600E-H-4G-HAT-Schematic.pdf) via my ESP32 using Serial2. I have tested the SIM7600 with PuTTy (via USB to UART connection) and can confirm baud of 115200 and I was able to verify a few different commands that way. However, whenever I attempt to talk to it over the ESP32 serial pins, I don't get any responses when I send data (will put code and terminal info down below). What's interesting is if I power cycle the SIM7600, I see its boot up checks just fine (also below). I know this also is not a SIM7600 power supply issue as others have mentioned on the forums - I have a 5V 2.4A supply so that should be plenty.
Here are my connections:
ESP32 PIN 16 (RX) -> SIM7600 Control Interface PIN 3 (TXD)
ESP32 PIN 17 (TX) -> SIM7600 Control Interface PIN 4 (RXD)
SIM7600 UART Jumper: Position B (have tried the others as well)
Additional note if anyone needs to know...I am using VS Code PlatformIO.
Here is my code:
#include <Arduino.h>
#include "stdio.h"
#include "string.h"
#define DEBUG true
String sendData(String command, const int timeout, boolean debug)
  String response = "";
  Serial2.println(command);
  long int time = millis();
  while ( (time + timeout) > millis())
    while (Serial2.available())
      char c = Serial2.read();
      response += c;
  if (debug)
    Serial.println("debug...");
    Serial.print(response);
  return response;
bool moduleStateCheck()
    int i = 0;
    bool moduleState = false;
    for (i = 0; i < 5; i++)
        String msg = String("");
        msg = sendData("AT", 1000, DEBUG);
        if (msg.indexOf("OK") >= 0)
            Serial.println("SIM7600 Module had turned on.");
            moduleState = true;
            return moduleState;
    return moduleState;
  //Serial2.begin(115200);
  Serial2.begin(115200, SERIAL_8N1, 16, 17);
  delay(3000);
  Serial.println("4G HTTP Test Begin!");
  Serial.println("Lets test the SIM7600");
  Serial.println("Sending...");
  sendData("AT",2000,DEBUG);
  delay(5000);
Here is what the terminal is showing while running the code...
Sending...
debug...
AT
Sending...
debug...
AT
Sending...
debug...
AT
Here is what I see after power cycling the SIM7600:
RDY
+CPIN: READY
SMS DONE
PB DONE
Any advice would be greatly appreciated!!
Thanks in advance!
some advice
#include <HardwareSerial.h>
HardwareSerial SerialTFMini( 1 );
HardwareSerial SerialBrain( 2 );
voided setup()
  Serial.begin( SerialDataBits );
  SerialBrain.begin( SerialDataBits );
  SerialTFMini.begin(  SerialDataBits, SERIAL_8N1, 27, 26 );
SerialBrain is using the default Rx/Tx pins of GPIO_NUM_16 and GPIO_NUM_17.
Hello @Idahowalker,
I'm not sure what you are trying to point out other than that Serial 2 will default to using GPIO16 and GPIO17?
Sorry my message got lost. Good luck.
Feel free to explain it further if I am missing the point...
