Hi all. I am trying to use a USB host shield to read keystrokes from a keyboard, but i am unable to receive any data from the shield. I have the following products
A Arduino Uno
A USB Host Shield link
A generic keyboard link
5V power supply
I already soldered the 3 power pins pads 5v and 5V and 3.3V. I uploaded the USB host shield library and uploaded the USBHIDBootKbd and the serial monitor says start and then when i press any key nothing happens
I tried uncommenting this line //USBHub Hub(&Usb); NO change
I tried using the multimedia keyboard example NO change
I tried the HID mouse example and No change
keyboard and mouse work.
multi-meter testing
USB pins have 5V and GND connected
Vbus is 5V
Vin is 5V
5v is 5V
3.3V is 3.7V
What do I need to do? My plan is to make a Arduino with the keyboard connected and you type a password and it unlocks a relay.
Thank you in advance for your help.
Please explain how you are trying to receive the data.
Post the code, using code tags, and a wiring diagram showing all connections, with pin designations clearly labeled.
Did you connect the grounds?
I am using the Serial Monitor.
I am using this code from the library USB Host library 2
#include <hidboot.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key);
protected:
void OnControlKeysChanged(uint8_t before, uint8_t after);
void OnKeyDown (uint8_t mod, uint8_t key);
void OnKeyUp (uint8_t mod, uint8_t key);
void OnKeyPressed(uint8_t key);
void KbdRptParser::PrintKey(uint8_t m, uint8_t key)
MODIFIERKEYS mod;
*((uint8_t*)&mod) = m;
Serial.print((mod.bmLeftCtrl == 1) ? "C" : " ");
Serial.print((mod.bmLeftShift == 1) ? "S" : " ");
Serial.print((mod.bmLeftAlt == 1) ? "A" : " ");
Serial.print((mod.bmLeftGUI == 1) ? "G" : " ");
Serial.print(" >");
PrintHex<uint8_t>(key, 0x80);
Serial.print("< ");
Serial.print((mod.bmRightCtrl == 1) ? "C" : " ");
Serial.print((mod.bmRightShift == 1) ? "S" : " ");
Serial.print((mod.bmRightAlt == 1) ? "A" : " ");
Serial.println((mod.bmRightGUI == 1) ? "G" : " ");
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
Serial.print("DN ");
PrintKey(mod, key);
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
void KbdRptParser::OnControlKeysChanged(uint8_t before, uint8_t after) {
MODIFIERKEYS beforeMod;
*((uint8_t*)&beforeMod) = before;
MODIFIERKEYS afterMod;
*((uint8_t*)&afterMod) = after;
if (beforeMod.bmLeftCtrl != afterMod.bmLeftCtrl) {
Serial.println("LeftCtrl changed");
if (beforeMod.bmLeftShift != afterMod.bmLeftShift) {
Serial.println("LeftShift changed");
if (beforeMod.bmLeftAlt != afterMod.bmLeftAlt) {
Serial.println("LeftAlt changed");
if (beforeMod.bmLeftGUI != afterMod.bmLeftGUI) {
Serial.println("LeftGUI changed");
if (beforeMod.bmRightCtrl != afterMod.bmRightCtrl) {
Serial.println("RightCtrl changed");
if (beforeMod.bmRightShift != afterMod.bmRightShift) {
Serial.println("RightShift changed");
if (beforeMod.bmRightAlt != afterMod.bmRightAlt) {
Serial.println("RightAlt changed");
if (beforeMod.bmRightGUI != afterMod.bmRightGUI) {
Serial.println("RightGUI changed");
void KbdRptParser::OnKeyUp(uint8_t mod, uint8_t key)
Serial.print("UP ");
PrintKey(mod, key);
void KbdRptParser::OnKeyPressed(uint8_t key)
Serial.print("ASCII: ");
Serial.println((char)key);
USB Usb;
//USBHub Hub(&Usb);
HIDBoot<USB_HID_PROTOCOL_KEYBOARD> HidKeyboard(&Usb);
KbdRptParser Prs;
Serial.begin( 115200 );
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSC did not start.");
delay( 200 );
HidKeyboard.SetReportParser(0, &Prs);
Usb.Task();
So i reread the library page and realized it said it needs a Arduino Leonardo or 32u4 or SAMD board. I got a Arduino Leonardo and uploaded the keyboard sketch and it works. Thank you for the help!
