C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\deufi\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\deufi\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Arduino\Documents\libraries -fqbn=arduino:megaavr:nona4809:mode=off -vid-pid=2341_0058 -ide-version=10813 -build-path C:\Users\deufi\AppData\Local\Temp\arduino_build_262810 -warnings=none -build-cache C:\Users\deufi\AppData\Local\Temp\arduino_cache_162513 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -verbose E:\Arduino\Documents\PCA9685x4ServosPots\PCA9685x4ServosPots.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\deufi\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\deufi\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Arduino\Documents\libraries -fqbn=arduino:megaavr:nona4809:mode=off -vid-pid=2341_0058 -ide-version=10813 -build-path C:\Users\deufi\AppData\Local\Temp\arduino_build_262810 -warnings=none -build-cache C:\Users\deufi\AppData\Local\Temp\arduino_cache_162513 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -verbose E:\Arduino\Documents\PCA9685x4ServosPots\PCA9685x4ServosPots.ino
Using board 'nona4809' from platform in folder: C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Using core 'arduino' from platform in folder: C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Detecting libraries used...
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for HCPCA9685.h: [HCPCA9685]
ResolveLibrary(HCPCA9685.h)
-> candidates: [HCPCA9685]
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809" "-IE:\Arduino\Documents\libraries\HCPCA9685" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: E:\Arduino\Documents\libraries\HCPCA9685\HCPCA9685.cpp
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
Using cached library dependencies for file: C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\utility\twi.c
Generating function prototypes...
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809" "-IE:\Arduino\Documents\libraries\HCPCA9685" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp" -o "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809" "-IE:\Arduino\Documents\libraries\HCPCA9685" "-IC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp" -o "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp.o"
Compiling libraries...
Compiling library "HCPCA9685"
Using previously compiled file: C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\HCPCA9685\HCPCA9685.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\Wire\utility\twi.c.o
Compiling core...
Using previously compiled file: C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\core\variant.c.o
Using precompiled core: C:\Users\deufi\AppData\Local\Temp\arduino_cache_162513\core\core_arduino_megaavr_nona4809_mode_off_094ac080d220eb445ce43ba5613ea1df.a
Linking everything together...
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mmcu=atmega4809 -o "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.elf" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\sketch\PCA9685x4ServosPots.ino.cpp.o" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\HCPCA9685\HCPCA9685.cpp.o" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\Wire\Wire.cpp.o" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\libraries\Wire\utility\twi.c.o" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810\core\variant.c.o" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/..\arduino_cache_162513\core\core_arduino_megaavr_nona4809_mode_off_094ac080d220eb445ce43ba5613ea1df.a" "-LC:\Users\deufi\AppData\Local\Temp\arduino_build_262810" -lm "-Wl,-Map,C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.map"
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O binary -R .eeprom "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.elf" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.bin"
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.elf" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.eep"
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.elf" "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex"
Using library HCPCA9685 in folder: E:\Arduino\Documents\libraries\HCPCA9685 (legacy)
Using library Wire at version 1.0 in folder: C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire
"C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-size" -A "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.elf"
Sketch uses 6069 bytes (12%) of program storage space. Maximum is 49152 bytes.
Global variables use 494 bytes (8%) of dynamic memory, leaving 5650 bytes for local variables. Maximum is 6144 bytes.
Forcing reset using 1200bps open/close on port COM7
C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega4809 -cjtag2updi -PCOM7 -b115200 -e -D -Uflash:w:C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex:i -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x00:m {upload.extra_files}
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\deufi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM7
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 1.07
hardware version: 1
S_MCU:
firmware version: 6.07
hardware version: 1
Serial number: 00:00:00:00:00:00
Device ID: JTAGICE mkII
AVR Part : ATmega4809
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
prodsig 0 0 0 0 no 61 61 0 0 0 0x00 0x00
fuses 0 0 0 0 no 9 0 0 0 0 0x00 0x00
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse6 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse7 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse8 0 0 0 0 no 1 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00
data 0 0 0 0 no 0 0 0 0 0 0x00 0x00
usersig 0 0 0 0 no 64 64 0 0 0 0x00 0x00
flash 0 0 0 0 no 49152 128 0 0 0 0x00 0x00
eeprom 0 0 0 0 no 256 64 0 0 0 0x00 0x00
Programmer Type : JTAGMKII_PDI
Description : JTAGv2 to UPDI bridge
M_MCU hardware version: 1
M_MCU firmware version: 1.07
S_MCU hardware version: 1
S_MCU firmware version: 6.07
Vtarget : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.28s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex"
avrdude: writing flash (6070 bytes):
Writing | ################################################## | 100% 4.61s
avrdude: 6070 bytes of flash written
avrdude: verifying flash memory against C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex:
avrdude: load data flash data from input file C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex:
avrdude: input file C:\Users\deufi\AppData\Local\Temp\arduino_build_262810/PCA9685x4ServosPots.ino.hex contains 6070 bytes
avrdude: reading on-chip flash data:
Reading | #######avrdude: jtagmkII_paged_load(): timeout/error communicating with programmer (status -1)
########################################### | 100% 1.81s
avrdude: verifying ...
avrdude: 6070 bytes of flash verified
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 written
avrdude: verifying fuse2 memory against 0x01:
avrdude: load data fuse2 data from input file 0x01:
avrdude: input file 0x01 contains 1 bytes
avrdude: reading on-chip fuse2 data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 verified
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: verifying fuse5 memory against 0xC9:
avrdude: load data fuse5 data from input file 0xC9:
avrdude: input file 0xC9 contains 1 bytes
avrdude: reading on-chip fuse5 data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of fuse5 verified
avrdude: reading input file "0x00"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: verifying fuse8 memory against 0x00:
avrdude: load data fuse8 data from input file 0x00:
avrdude: input file 0x00 contains 1 bytes
avrdude: reading on-chip fuse8 data:
avrdude: 1 bytes of fuse8 verified
avrdude done. Thank you.
