Unable to open IDE
PS C:\Users\Admin\AppData\Local\Programs\Arduino IDE> .\Ardunio IDE
  .\Ardunio : The term '.\Ardunio' is not recognized as the name of a
cmdlet, function, script file, or operable
  program. Check the spelling of the name, or if a path was included,
verify that the path is correct and try again.
  At line:1 char:1
  + .\Ardunio IDE
      + CategoryInfo          : ObjectNotFound: (.\Ardunio:String) [],
CommandNotFoundException
      + FullyQualifiedErrorId : CommandNotFoundException
  PS C:\Users\Admin\AppData\Local\Programs\Arduino IDE> .\Arduino IDE
  .\Arduino : The term '.\Arduino' is not recognized as the name of a
  At line:1 char:1
  + .\Arduino IDE
      + CategoryInfo          : ObjectNotFound: (.\Arduino:String) [],
  At line:1 char:1
  + .\Ardunio IDE
  PS C:\Users\Admin\AppData\Local\Programs\Arduino IDE> &".\Arduino IDE"
  Arduino IDE 2.3.7
  Checking for frontend application configuration customizations.
Module path: C:\Users\Admin\AppData\Local\Programs\Arduino
IDE\resources\app\lib\backend\electron-main.js, destination
'package.json': C:\Users\Admin\AppData\Local\Programs\Arduino
IDE\resources\app\package.json
  [11072:0227/103716.903:ERROR:network_change_notifier_win.cc(267)]
WSALookupServiceBegin failed with: 0
  Setting 'theia.frontend.config.appVersion' application configuration
value to: "2.3.7" (type of string)
  Setting 'theia.frontend.config.cliVersion' application configuration
value to: "1.3.1" (type of string)
  Setting 'theia.frontend.config.buildDate' application configuration
value to: "2025-12-17T16:05:25.389Z" (type of string)
  Frontend application configuration after modifications:
{"applicationName":"Arduino
IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.7","cliVersion":"1.3.1","buildDate":"2025-12-17T16:05:25.389Z"}
  Starting backend process. PID: 6844
  Showing main window early
  [8976:0227/103717.263:ERROR:network_change_notifier_win.cc(267)]
  Using browser-only version of superagent in non-browser environment
  Configuration directory URI: 'file:///c%3A/Users/Admin/.arduinoIDE'
  Configuring to accept webviews on '^.+\.webview\..+$' hostname.
  2026-02-27T05:07:17.685Z root INFO Backend u.initialize: 27.6 ms
[Finished 0.582 s after backend start]
  2026-02-27T05:07:17.687Z root INFO Backend Object.initialize: 26.1
ms [Finished 0.582 s after backend start]
  2026-02-27T05:07:17.687Z root INFO Backend a.initialize: 1.3 ms
  2026-02-27T05:07:17.687Z root INFO Backend a.initialize: 1.1 ms
  2026-02-27T05:07:17.687Z root INFO Backend u.initialize: 1.4 ms
  2026-02-27T05:07:17.689Z root INFO Backend l.initialize: 26.1 ms
[Finished 0.583 s after backend start]
  2026-02-27T05:07:17.696Z root INFO configured all backend app contributions
  2026-02-27T05:07:17.696Z root INFO Backend l.onStart: 1.1 ms
[Finished 0.594 s after backend start]
  2026-02-27T05:07:17.696Z root INFO Backend d.onStart: 0.1 ms
  2026-02-27T05:07:17.697Z root INFO Backend a.onStart: 0.3 ms
  2026-02-27T05:07:17.697Z config INFO >>> Initializing CLI configuration...
  2026-02-27T05:07:17.697Z root INFO Backend x.onStart: 0.4 ms
[Finished 0.595 s after backend start]
  2026-02-27T05:07:17.697Z config INFO Loading CLI configuration from
c:\Users\Admin\.arduinoIDE\arduino-cli.yaml...
  2026-02-27T05:07:17.697Z daemon INFO Starting daemon from
IDE\resources\app\lib\backend\resources\arduino-cli.exe...
  2026-02-27T05:07:17.697Z root INFO Backend w.onStart: 0.3 ms
  2026-02-27T05:07:17.697Z discovery-log INFO start
  2026-02-27T05:07:17.697Z discovery-log INFO start new deferred
  2026-02-27T05:07:17.697Z root INFO Backend v.onStart: 0.2 ms
[Finished 0.596 s after backend start]
  2026-02-27T05:07:17.697Z root INFO Backend a.onStart: 0.1 ms
  2026-02-27T05:07:17.707Z root WARN The local plugin referenced by
local-dir:/c%3A/Users/Admin/.arduinoIDE/plugins does not exist.
local-dir:/c%3A/Users/Admin/.arduinoIDE/deployedPlugins does not exist.
local-dir:C:\Users\Admin\.arduinoIDE\plugins does not exist.
  2026-02-27T05:07:17.710Z root INFO Theia app listening on
http://127.0.0.1:50760.
  Restoring workspace roots:
d:\shravani\WSN\20260211_WirelessSensorNetwork\cc1120_tx_2\cc1120_tx_2.ino
  isTempSketch: false. Input was
  2026-02-27T05:07:17.711Z root INFO Finished starting backend
application: 13.0 ms [Finished 0.609 s after backend start]
  2026-02-27T05:07:17.726Z config INFO Loaded CLI configuration:
{"board_manager":{"additional_urls":[]}}
  2026-02-27T05:07:17.727Z config INFO Loading fallback CLI
configuration to get 'directories.data' and 'directories.user'
  2026-02-27T05:07:17.766Z root INFO Resolve plugins list: 67.4 ms
[Finished 0.664 s after backend start]
  2026-02-27T05:07:17.777Z daemon INFO
time="2026-02-27T10:37:17+05:30" level=info msg="arduino-cli version1.3.1"
time="2026-02-27T10:37:17+05:30" level=info msg="Using config file:
c:\\Users\\Admin\\.arduinoIDE\\arduino-cli.yaml"
  time="2026-02-27T10:37:17+05:30" level=info msg="Executing
`arduino-cli daemon`"
  2026-02-27T05:07:17.788Z daemon INFO Daemon is now listening on
127.0.0.1:50761
  {"IP":"127.0.0.1","Port":"50761"}
  2026-02-27T05:07:17.788Z daemon INFO Daemon is running.
  2026-02-27T05:07:17.812Z config INFO Loaded fallback CLI
configuration:
{"directories":{"user":"C:\\Users\\Admin\\Documents\\Arduino","data":"C:\\Users\\Admin\\AppData\\Local\\Arduino15"}}
  2026-02-27T05:07:17.812Z config INFO Merged CLI configuration with
the fallback:
{"directories":{"user":"C:\\Users\\Admin\\Documents\\Arduino","data":"C:\\Users\\Admin\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
  2026-02-27T05:07:17.812Z config INFO Loaded the CLI configuration.
  2026-02-27T05:07:17.814Z daemon INFO
time="2026-02-27T10:37:17+05:30" level=info msg="Starting download"
url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
  2026-02-27T05:07:17.814Z config INFO Mapped the CLI configuration:
{"dataDirUri":"file:///c%3A/Users/Admin/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Admin/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
  2026-02-27T05:07:17.814Z config INFO Validating the CLI configuration...
  2026-02-27T05:07:17.816Z config INFO The CLI config is valid.
  2026-02-27T05:07:17.816Z config INFO <<< Initialized the CLI configuration.
  2026-02-27T05:07:17.826Z root ERROR Detected an error response
during the gRPC core client initialization: code: 3, message: Error
downloading index
'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get
"https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial
tcp: lookup downloads.arduino.cc: getaddrinfow: This is usually a
temporary error during hostname resolution and means that the local
server did not receive a response from an authoritative server.
during the gRPC core client initialization: code: 9, message: Loading
index file: loading json index file
C:\Users\Admin\AppData\Local\Arduino15\package_index.json: open
C:\Users\Admin\AppData\Local\Arduino15\package_index.json: The system
cannot find the file specified.
  2026-02-27T05:07:17.827Z root ERROR Detected an error response
during the gRPC core client initialization: code: 9, message: Error
loading hardware platform: discovery builtin:serial-discovery not found
loading hardware platform: discovery builtin:mdns-discovery not found
index file: reading library_index.json: open
C:\Users\Admin\AppData\Local\Arduino15\library_index.json: The system
  2026-02-27T05:07:17.827Z daemon INFO
time="2026-02-27T10:37:17+05:30" level=info msg="Loading hardware
from: C:\\Users\\Admin\\AppData\\Local\\Arduino15\\packages"
  time="2026-02-27T10:37:17+05:30" level=info msg="Loading librariesindex file"
index="C:\\Users\\Admin\\AppData\\Local\\Arduino15\\library_index.json"
  time="2026-02-27T10:37:17+05:30" level=info msg="Adding libraries
dir" dir="C:\\Users\\Admin\\AppData\\Local\\Arduino15\\libraries"
isSingleLibrary=false location=ide
dir" dir="C:\\Users\\Admin\\Documents\\Arduino\\libraries"
isSingleLibrary=false location=user
  2026-02-27T05:07:17.892Z root ERROR The primary packages indexes are
missing. Running indexes update before initializing the core gRPC
client The index of the cores and libraries must be updated before
initializing the core gRPC client.
  The following problems were detected during the gRPC client initialization:
  [platform-index] - code: 9, message: Loading index file: loading
json index file
  [platform-index] - code: 9, message: Error loading hardware
  [library-index] - code: 9, message: Loading index file: reading
  2026-02-27T05:07:17.893Z daemon INFO
time="2026-02-27T10:37:17+05:30" level=info msg="Updating index"
url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
  2026-02-27T05:07:17.897Z daemon INFO
  2026-02-27T05:07:17.898Z root INFO core-client-provider
[library-index] Downloading index: library_index.tar.bz2
[platform-index] Downloading index: package_index.tar.bz2
  2026-02-27T05:07:17.900Z root ERROR Failed to update platform,
library indexes. Error: 13 INTERNAL: Error downloading index
      at t.callErrorFromStatus
(C:\Users\Admin\AppData\Local\Programs\Arduino
IDE\resources\app\lib\backend\main.js:2:3088066)
      at Object.onReceiveStatus
IDE\resources\app\lib\backend\main.js:2:6672872)
IDE\resources\app\lib\backend\main.js:2:2571272)
      at C:\Users\Admin\AppData\Local\Programs\Arduino
IDE\resources\app\lib\backend\main.js:2:4304750
      at process.processTicksAndRejections
(node:internal/process/task_queues:77:11)
  for call at
      at s.makeServerStreamRequest
IDE\resources\app\lib\backend\main.js:2:6672639)
      at s.updateLibrariesIndex
IDE\resources\app\lib\backend\main.js:2:3087159)
IDE\resources\app\lib\backend\main.js:2:6278159
IDE\resources\app\lib\backend\main.js:2:6278352
      at new Promise (<anonymous>)
      at y.doUpdateIndex
IDE\resources\app\lib\backend\main.js:2:6278331)
      at y.updateLibraryIndex
IDE\resources\app\lib\backend\main.js:2:6278131)
      at y.updateIndex (C:\Users\Admin\AppData\Local\Programs\Arduino
IDE\resources\app\lib\backend\main.js:2:6277405)
      at y.initInstanceWithFallback
IDE\resources\app\lib\backend\main.js:2:6275637)
(node:internal/process/task_queues:95:5)
  2026-02-27T05:07:17.906Z daemon INFO
  2026-02-27T05:07:17.907Z root ERROR Detected an error response
downloading index
  2026-02-27T05:07:17.966Z root ERROR Uncaught Exception:  Error: Theindex of the cores and libraries must be updated before initializing
json index file
  2026-02-27T05:07:17.966Z root ERROR Error: The index of the cores
and libraries must be updated before initializing the core gRPC client.
json index file
IDE\resources\app\lib\backend\main.js:2:6277148
      at y.evaluateErrorStatus
IDE\resources\app\lib\backend\main.js:2:6277164)
      at async a.<anonymous>
IDE\resources\app\lib\backend\main.js:2:6276834)
  2026-02-27T05:07:18.253Z root INFO Deploy plugins list: 554.1 ms
[Finished 1.151 s after backend start]
  2026-02-27T05:07:19.059Z root INFO creating connection for 1
  2026-02-27T05:07:19.973Z root WARN Frontend a.configure took longer
than the expected maximum 100 milliseconds: 223.3 ms [Finished 2.254 s
after frontend start]
  2026-02-27T05:07:19.999Z root WARN A command
editor.action.toggleStickyScroll is already registered.
  Opening channel for service path '/services/electron-window'.
  Opening channel for service path '/services/ide-updater'.
  2026-02-27T05:07:20.238Z root INFO Start frontend contributions:
400.4 ms [Finished 2.367 s after frontend start]
  2026-02-27T05:07:20.238Z root INFO Changed application state from
'init' to 'started_contributions'.
'started_contributions' to 'attached_shell'.
  2026-02-27T05:07:20.238Z root INFO >>> Restoring the layout state...
  2026-02-27T05:07:20.292Z root INFO
[86cc023c-6db4-411f-becd-34ddcc50c50d] Waiting for backend deployment:
208.4 ms [Finished 2.571 s after frontend start]
  2026-02-27T05:07:20.841Z root INFO [hosted-plugin: 6096]
PLUGIN_HOST(6096) starting instance
  [Object: null prototype] {}
  2026-02-27T05:07:21.402Z root INFO
[86cc023c-6db4-411f-becd-34ddcc50c50d] Sync of 23 plugins: 1111.5 ms
[Finished 3.683 s after frontend start]
Not able to open the Arduino 2.3.7 with above error log in power shell.
You seem to have issued the command (points 6 and 7 in post #2) incorrectly in powershell.
The & seems to be missing and you need the double quotes.
Can you pls see after few lines. I have tried with it later.
Not sure if I can help.
The IDE needs internet access the first time to install some additional stuff. Once that is all sorted the IDE does not need internet access although it's convenient.
  1. Is the computer connected to the internet?
  2. Is there anything special about your network setup
    • Corporate/school network?
    • Corporate computer?
    • Anything else that you can think of?
Ok. I don't have internet connected.
I've split your question from the existing topic.
Sort that and it will (hopefully) work without additional issues.
If you want to install libraries without having internet access you will need to download the ZIP versions of libraries using another computer that has internet access and next transfer them to your computer with the IDE.
If you want to install additional board packages (e.g. for ESP32, STM32, ...) you can install them first on a computer with internet access (running the same operating system) and next transfer the installed files to the computer without internet access.
Hence internet access is convenient.
