Unable to read LANC protocol commands
I would like to read LANC protocol communication and identify camera operation bytes.
I was able to communicate using Arduino UNO, but the Byte sent to the serial monitor was
17:54:25.668 -> BITS:
17:54:25.668 -> 00000000 00000000
17:54:26.672 -> BITS:
17:54:26.715 -> 00000000 00000000
In this way, only the above command is sent every 1 second.
The hardware used is Arduino UNO and Ethernet Shield 2.
Below is the Arduino code.
LANC SNIFFER
Version 1.0
Finds out LANC commands from a REMOTE
For the interface ciruit see
Feel free to use this code in any way you want.
2011, Martin Koch
"LANC" is a registered trademark of SONY.
CANON calls their LANC compatible port "REMOTE".
#define lancPin 3
int bitDuration = 104; //Duration of one LANC bit in microseconds.
int lancBit[16];
        Serial.begin(9600); //open the serial port
 pinMode(lancPin, INPUT); //listens to the LANC line
        delay(5000); //Wait for camera to power up completly
        bitDuration = bitDuration- 8; //Reading the digital port takes about 8 microseconds so only 96 microseconds are left for each bit
  readLancCommand();
void readLancCommand() {
     while (pulseIn(lancPin, HIGH) < 5000) {
      //"pulseIn, HIGH" catches any 0V TO +5V TRANSITION and waits until the LANC line goes back to 0V
      //"pulseIn" also returns the pulse duration so we can check if the previous +5V duration was long enough (>5ms) to be the pause before a new 8 byte data packet
      //Loop till pulse duration is >5ms
    //LOW after long pause means the START bit of Byte 0 is here
    delayMicroseconds(bitDuration);  //wait START bit duration
    delayMicroseconds(bitDuration/2); //wait until the middle of bit 0 of byte 0
    //Read the 8 bits of byte 0
    //Note that the command bits come in in reverse order with the least significant, right-most bit (bit 0) first
    for (int i=7; i>-1; i--) {
      lancBit[i] = digitalRead(lancPin);  //read bits.
    //Byte 0 is read
     delayMicroseconds(10); //make sure to be in the stop bit before byte 1
      while (digitalRead(lancPin)) {
        //Loop as long as the LANC line is +5V during the stop bit
      //0V after the previous stop bit means the START bit of Byte 1 is here
      delayMicroseconds(bitDuration/2); //wait until the middle of bit 0 of byte 1
      //Read the 8 bits of Byte 1
      //Note that the command bits have to be read in reverse order with the least significant, right-most bit (bit 0) first
      for (int i=15; i>7; i--) {
      //Byte 1 is read
      //Print byte 0 and byte 1 to the Serial Monitor console of the Arduino developing environment
      Serial.println("BITS: ");
      for (int i=0; i<16; i++) {
        Serial.print((lancBit[i]-1)*-1); //invert the bits
        if (i==7) Serial.print(" ");
      Serial.println("");
Hello Kosuke,
Good day.
Have you seen this project at the Arduino Hub?
Serial to LANC (Control-L)
Best regards Mascho
thank you!
Actually, it has been possible to send commands using the LANC protocol to the camera side for some time, and I would like to do the opposite.
The purpose is to analyze the LANC protocol commands operated on the camera side using Arduino in binary and obtain zoom and white balance operations in binary format.
