Unable to receive data from SPI
Hi, I am using Arduino MKRZero Board to communicate with Analog Devices AD5292 Digital Potentiometer using SPI interface.
The AD5292 uses 16 bit words for communication and so I am using SPI.transfer16() function.
My configuration is the Pins D0, D1, D2 and D3 on MKRZero forms a combination which acts as a chip select to select one out of 10 AD5292's that I have in my hardware. I am only using the AD5292 at position 0000 for testing in my current example. Pin D6 on MKRZero is RDY (Pin 14 on AD5292), Pin D7 on MKRZero is RESET (Pin 1 on AD5292) for AD5292 and these two pins are always set to HIGH as I am not using functions associated with these pins. Pin D8 (COPI/MOSI on MKRZero) is connected to Pin DIN (Pin 10 on AD5292), Pin D9 (SCK on MKRZero) is connected to Pin SCLK (Pin 11 on AD5292) and Pin D10 (CIPO/MISO on MKRZero) is connected to Pin SDO (pin 13 on AD5292).
Below is my entire code:
#include <SPI.h>
#include <bitset>
const byte delay_ms = 25; // delay after flush
const char sep = ':'; // Command and RDAC value seperator
  /* There are 4 Chip Select lines, depending on this combination
   *  one of the 10 potentiometers is selected. I am just using
   *  Potentiometer at position 0000 for current testing. */
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  /* RDY and RESET Pins */
  pinMode(6, OUTPUT); // RDY
  pinMode(7, OUTPUT); // RESET
  /* Setting RDY and RESET pins to HIGH */
  digitalWrite(6, HIGH);
  digitalWrite(7, HIGH);
  /* Setting up SPI */
  SPI.begin();
  SPI.beginTransaction(SPISettings(100000, MSBFIRST, SPI_MODE1));
  /* Setting up Serial */
  /* Data send over serial must be greater than at least 2 bytes. Minimum requirements are
   *  1 Command byte, 1 Seperator byte and 1 RDAC value byte.
   *  Values are send over Serial in following as Command_value:RDAC_value
   *  Possible Values that I am interested in (x = Don't Care):
   *    6:2 - Enable Wiper Position Update (always the first value to be sent)
   *    1:0 to 1:1023 - write 0 to 1023 to RDAC, changes wiper position to 0 (i.e. Min) or 1023 (i.e. Max)
   *    0:x - NOP Command i.e. Do Nothing
   *    2:x - Read RDAC Wiper Settings from the SDO output in next frame
  if(Serial.available() > 2){
    int serialIndex = Serial.available() - 1; // ignoring the last byte which can be new line
    char cmd_chars[16]; // to hold Command bytes
    char rdac_chars[16]; // to hold RDAC bytes
    memset(cmd_chars, 0, 16); // making sure all bytes in the array is set to 0
    memset(rdac_chars, 0, 16); // making sure all bytes in the array is set to 0
    int sepIndex = 0; // Seperator Index
    bool sepFound = false; // variable to know when Seperator has been found
    Serial.print("Received over Serial: "); // this will print the exact bytes received, including the seperator
    for(int ii = 0; ii < serialIndex; ++ii){
      char val = Serial.read();
      Serial.print(val); // printing current byte
      if(val == sep){
        sepFound = true;
        sepIndex = ii;
      else{
        if(sepFound){
          rdac_chars[ii - sepIndex - 1] = val;
        else{
          cmd_chars[ii] = val;
    /* Converting to integer */
    int cmd_int = atoi(cmd_chars);
    int rdac_int = atoi(rdac_chars);
    /* Writing data to potentiometer */
    writeDataToPotentiometer(cmd_int, rdac_int);
    /* Making sure there is a gap of one line between two different Serial Inputs */
    flushSerialInput(); // flushing serial
void writeDataToPotentiometer(int cmd, int rdac)
  /* bitsets to hold Command and rdac bits */
  std::bitset<4> cmd_bits;
  std::bitset<10> rdac_bits;
  /* Settings all bits to zero */
  cmd_bits.reset();
  rdac_bits.reset();
  /* Getting Command bits from its integer value */
  int cmd_index = 0;
  int cmd_tmp = cmd;
  while(cmd_tmp > 0){
    cmd_bits[3 - cmd_index] = cmd_tmp % 2;
    cmd_tmp = cmd_tmp / 2;
    ++cmd_index;
  /* Printing Command bits over Serial to check if it is correct */
  Serial.print("Command:: Int: ");
  Serial.print(cmd);
  Serial.print(" | Binary: ");
  for(int ii = 0; ii < 4; ++ii){
    Serial.print(cmd_bits.test(ii));
  /* Getting RDAC bits from its integer value */
  int rdac_index = 0;
  int rdac_tmp = rdac;
  while(rdac_tmp > 0){
    rdac_bits[9- rdac_index] = rdac_tmp % 2;
    rdac_tmp = rdac_tmp / 2;
    ++rdac_index;
  /* Printing RDAC bits over Serial to check if it is correct */
  Serial.print("RDAC:: Int: ");
  Serial.print(rdac);
  for(int ii = 0; ii < 10; ++ii){
    Serial.print(rdac_bits.test(ii));
  /* bitset to hold the entire 16 bits that is to be sent to the potentiometer. The bits are as follows:
   *  First 2 bits: 00 (always the same)
   *  Next 4 bits: Command bits (0110: Unfreeze Wiper, 0001: Write RDAC, 0000: Do Nothing, 0010: Read RDAC in Next frame)
   *  Next 10 bits: RDAC values, varies from 0 to 1023
   std::bitset<16> pot_bits;
   pot_bits.reset(); // making sure all bits are initially set to zero
   for(int ii = 2; ii < 16; ++ii){
    if(ii < 6){
      pot_bits[ii] = cmd_bits[ii - 2]; // copying Command bits to correct position
    else{
      pot_bits[ii] = rdac_bits[ii - 6]; // copying RDAC bits to correct position
   /* Printing out all 16 bits over serial to check if it is correct */
   Serial.print("Potentiometer Bits: ");
   for(int ii = 0; ii < 16; ++ii){
    Serial.print(pot_bits.test(ii));
  /* Getting the 2 byte value to be sent to potentiometer */
   uint16_t potVal = 0; // 2 byte value to be sent to potentiometer
   for(int ii = 15; ii >= 0; --ii){
    potVal += pot_bits.test(ii) * pow(2, 15 - ii);
   /* Printing the 2 byte potentiometer value */
   Serial.print("Value Sent to Potentiometer: ");
   Serial.print(potVal);
   /* A 2 byte variable to receive data from potentiometer */
   uint16_t receiveVal = 27; // 27 is just a placeholder to see if it is overriden
   /* Setting all Chip Select pins to LOW since my test potentiometer is at 0000 position */
    digitalWrite(ii, LOW);
  /* Sending and Receiving from Potentiometer */
  receiveVal = SPI.transfer16(potVal);
  /* Setting all Chip Select pins to HIGH to complete the SPI transfer */
    digitalWrite(ii, HIGH);
   /* Printing over Serial the value received from Potentiometer */
   Serial.print("Value Received from Potentiometer: ");
   Serial.print(receiveVal);
void flushSerialInput() {
  /* Function to flush data if needed */
  while (Serial.available() > 0) {
    Serial.read();
    delay(delay_ms);
Below are the outputs that I received:
Received over Serial: 6:2
Command:: Int: 6 | Binary: 0110
RDAC:: Int: 2 | Binary: 0000000010
Potentiometer Bits: 0001100000000010
Value Sent to Potentiometer: 6146
Value Received from Potentiometer: 0
Received over Serial: 1:0
Command:: Int: 1 | Binary: 0001
RDAC:: Int: 0 | Binary: 0000000000
Potentiometer Bits: 0000010000000000
Value Sent to Potentiometer: 1024
Received over Serial: 1:1023
RDAC:: Int: 1023 | Binary: 1111111111
Potentiometer Bits: 0000011111111111
Value Sent to Potentiometer: 2047
Received over Serial: 2:0
Command:: Int: 2 | Binary: 0010
Potentiometer Bits: 0000100000000000
Value Sent to Potentiometer: 2048
Received over Serial: 1:1020
RDAC:: Int: 1020 | Binary: 1111111100
Potentiometer Bits: 0000011111111100
Value Sent to Potentiometer: 2044
The wiper position of AD5292 is set correctly, which means the SPI.transfer16() function is sending data correctly and my pins are connected correctly.
The returned value is always 0, since I initialize the return value variable with a value of 27, this means that the return value variable is being overridden by SPI.transfer16() function. But it is always 0, I would expect it to give me 2047 at least in the last output since in second last command is 2:0 or 2048 in integer terms, which is to read RDAC wiper settings in next frame.
Using an oscilloscope, I can see the SDO Pin of AD5292 is sending data pulses back and I can see the same being received on MKRZero's MISO pin (D10, where the SDO pin of AD5292 is connected) but the data received from the serial input is always zero. What am I missing? Is there some catch to get the data from SPI.transfer16() function?
I don't see a command in the datasheet that allows writing and reading of the RDAC register at the same time.
As you failed to tell us what value you write or post complete code (what we always expect!), we can only guess what you actually did.
That's interesting, I would expect the chip not to do this. As the MKR didn't get it, I guess you measured incorrectly. Post the scope output!
Hi, thanks for your answer. I have updated my question with much more detail and complete code.
The Command Operation table for AD5292:
The Example commands to show how can the RDAC value be read:
In the second table, there is mostly a non-zero value at SDO. What I am getting is zero all the time.
I did not measure incorrectly, there is definitely a spike in the SDO line which only occurs when I am sending data to AD5292, otherwise, the SDO line remains constantly high. I can also see the same when I connect my scope to Pin D10/PA19/CIPO(SC1) on Arduino MKRZero. I tried getting the screenshot from the scope, but the spike is extremely fast and fleeting and so I was unable to capture it at the exact moment. The screenshot would not have been useful anyway because all you can see is a single spike and not a train of bits. But the presence of a spike on the SDO line at the exact moment I send data to my potentiometer, and the absence of a spike on the SDO line in any other condition is definitive proof that the SDO line is responding.
pow() is a floating point function and not precise for integer use. Use bit manipulations operations like |, &, <<, >> for manipulating bits:
    potVal |= pot_bits.test(ii) << (15 - ii) ;
The use of bitsets is overengineered and complex for this kind of coding, any integer is a vector of bits already.
The way I'd code this is in one line:
  potVal = ((cmd & 0xF) << 10) | (rdac & 0x3FF) ;
Mask each field to ensure its not larger than it should be, combine with shifts and OR's. Simple.
Hi, thanks a lot, it is really helpful. I will implement these changes immediately :slight_smile:
Thank you. You shouldn't edit the original post as a reader of the thread may be surprised about the rest of the thread if all the information is already in the first post. Better to post additional information in additional posts.
Yes, but not using the command bits you used.
The only command that reads (2) isn't complete because you don't read the following 16 bits where the information was transferred.
A spike doesn't mean anything. The data must be available for at least one half of a clock round.
BTW: you can initialize a std::bitset directly using an integer:
std::bitset<4> cmd_bits(cmd);
std::bitset<10> rdac_bits(rdac);
The use of the bit shift operators was already described by MarkT, so you probably don't need the bitsets at all.
Hi, thanks I will take all your recommendations into account.
Can you elaborate on this, I am not sure if I understand it. How am I supposed to read the following 16 bits? The only way I can read the data from SDO is using SPI.transfer16() function as far as I know. According to the datasheet for command 2:
Read RDAC wiper setting from the SDO output in the next frame.
By 'next frame' I assumed that it will be in the SDO output when I send a new 16-bit data word to the AD5292. Am I wrong?
Yes, but without pulling CS high in between. transfer() or transfer16() send and receive data. If you don't want to send anything, you usually just send 0.
