I have two NodeMCU 1.0 boards.
I am trying to send UDP packets with the string true or false from the serial monitor of the sender in client mode(STA) and send it to the receiver in access point mode (AP) and print the desired results on LCD.
Issue: The packet is sent successfully from the sender(STA) but it is not received by the receiver(AP).
Receiver in AP mode(receiver.ino):
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include "ESPAsyncWebServer.h"
#include <Wire.h>
#define ssid "Bike-Module-AP"
#define password "qwerty123"
#define PORT 4210 // local port to listen on
#define SDA D2
#define SCL D1
AsyncWebServer server(80);
WiFiUDP Udp;
LiquidCrystal_I2C lcd(0x27, 16, 2);
char incomingPacket[255]; // buffer for incoming packets
char replyPacket[] = "Got message successfully!"; // a reply string to send back
//unsigned long Interval = 20000;
Wire.begin(SDA, SCL);
lcd.begin(16, 2); // initializing the LCD
lcd.backlight(); // Enable or Turn On the backlight
lcd.home();
Serial.print("Setting soft-AP ... ");
Serial.println(WiFi.softAP(ssid, password) ? "Ready":"Failed!");
Serial.print("AP IP address: ");
Serial.println(WiFi.softAPIP());
Udp.begin(PORT);
server.begin();
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.softAPIP().toString().c_str(), PORT);
// LED pin to show client status
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
lcd.clear();
lcd.print("System ready!");
lcd.clear();
bool _client = client_status();
lcd.setCursor(0, 0);
lcd.print("Connection: ");
lcd.setCursor(12, 0);
if(_client) {
// Serial.printf("client: true\t");
lcd.print("Okay");
if(receive_packets()) {
// Serial.printf("packet: true\n");
lcd.setCursor(0, 1);
lcd.print("All good");
digitalWrite(LED_BUILTIN, LOW); // turn led ON
else {
// Serial.printf("packet: false\n");
lcd.print("Ignition off");
digitalWrite(LED_BUILTIN, HIGH); //turn led OFF
else {
lcd.print("Lost");
bool client_status() {
unsigned char number_client;
number_client= wifi_softap_get_station_num();
// Serial.printf("Total Connected Clients are = %d\n", number_client);
if(number_client == 0) {
return false;
else if(number_client > 0) {
return true;
bool receive_packets() {
// digitalWrite(LED_BUILTIN, LOW); // client connected
int packetSize = Udp.parsePacket();
Serial.printf("packetSize = %d\n", packetSize);
if(packetSize) {
// receive incoming UDP packets
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 255);
if (len > 0) {
incomingPacket[len] = 0;
Serial.printf("UDP packet contents:%s\n", incomingPacket);
if(strcmp(incomingPacket, "true")==10) {
Serial.printf("incoming: TRUE\n");
return true;
else if(strcmp(incomingPacket, "false")==10) {
Serial.printf("incoming: FALSE\n");
return false;
// send back a reply, to the IP address and port we got the packet from
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(replyPacket);
Udp.endPacket();
else {
// digitalWrite(LED_BUILTIN, HIGH); // client disconnected
Serial Monitor:
Setting soft-AP ... Ready
AP IP address: 192.168.4.1
Now listening at IP 192.168.4.1, UDP port 4210
Sender in STA mode(sender.ino):
#define ssid "Module-AP"
#define IP "192.168.4.1"
WiFiUDP Udp;
char senderPacket[100];
// Connect to AP
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" connected");
while (Serial.available() > 0 ) {
String inputString = Serial.readString();
inputString.toCharArray(senderPacket, 100);
if(Udp.beginPacket(IP, PORT) &&
Udp.write(senderPacket) &&
Udp.endPacket()) {
Serial.printf("Packet sent: %s\n", senderPacket);
Serial monitor:
Connecting to Module-AP .................. connected
19:08:05.107 -> Packet sent: true
