I bought a ESP8266 ESP-12 ESP-12F NodeMcu D1 Module on Amazon and am having a hard time connecting to it with Arduino IDE.
Amazon.com: ESP8266 ESP-12 ESP-12F NodeMcu D1 Module WeMos Lua 4M Bytes WLAN WiFi Internet Development Board Base on ESP8266 ESP-12F, Compatible with WeMos Wifi Module : Electronics
I am able to send AT commands with PuTTY but am not able to upload sketches or even send AT commands in Arduino IDE.
I have made sure the baude rate and port is the same on both but all I get in Arduino are ERROR messages
What could I be doing wrong? Here at my Tools in Arduino IDE
Load the blink sketch from Files/Samples and show all the output.
Ran just now and get this
. Variables and constants in RAM (global, static), used 28104 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 920 constants
╚══ BSS 25688 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59667 / 65536 bytes (91%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 26899 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 232148 / 1048576 bytes (22%)
╚══ IROM 232148 code in flash
esptool.py v3.0
Serial port COM3
Connecting......................................_____
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
Just retry a few times; if that doesn't work, shut down the IDE and try a few more times; if that doesn't work, do a COLD reboot, etc. BTW, change preferences to show verbose output.
Not sure what a cold reboot it but I unplugged and replugged the module. Here is the verbose output
FQBN: esp8266:esp8266:d1_mini:baud=115200
Using board 'd1_mini' from platform in folder: C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "C:\\Users\\isaac\\AppData\\Local\\Programs\\arduino-ide\\resources\\app\\lib\\backend\\resources" 10607 "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4" "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt" "C:\\Users\\isaac\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\\Blink/Blink.ino.globals.h" "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding: cp65001
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'C:\Users\isaac\AppData\Local\Temp\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\Blink\Blink.ino.globals.h' does not exist.
Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core -c @C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core -c @C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI" -DARDUINO_BOARD_ID="d1_mini" -DFLASHMODE_DIO -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4\sketch\Blink.ino.cpp -o C:\Users\isaac\AppData\Local\Temp\322752821\sketch_merged.cpp
C:\Users\isaac\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\isaac\AppData\Local\Temp\322752821\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode header --publickey "C:\\Users\\isaac\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\\Blink/public.key" --out "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/core/Updater_Signing.h"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt" "-IC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/core" -c "@C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini\"" -DFLASHMODE_DIO "-IC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\d1_mini" "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4\\sketch\\Blink.ino.cpp" -o "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\isaac\AppData\Local\Temp\arduino\cores\6c28c9156730842334a45218353f363a\core.a
Linking everything together...
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkdir.py" -p "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/ld_h/"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/cp.py" "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/ld/eagle.flash.4m2m.ld" "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/ld_h/local.eagle.flash.ld.h"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/ld_h/local.eagle.flash.ld.h" -o "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/local.eagle.flash.ld"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/local.eagle.app.v6.common.ld"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.map" -g "@C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cflags" -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lib" "-LC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4" "-LC:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/lib" -Tlocal.eagle.flash.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.elf" -Wl,--start-group "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4\\sketch\\Blink.ino.cpp.o" "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\cores\\6c28c9156730842334a45218353f363a\\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/elf2bin.py" --eboot "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/bootloaders/eboot/eboot.elf" --app "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.elf" --flash_mode dio --flash_freq 40 --flash_size 4M --path "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin" --out "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin"
Creating BIN file "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin" using "C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/bootloaders/eboot/eboot.elf" and "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.elf"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode sign --privatekey "C:\\Users\\isaac\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\\Blink/private.key" --bin "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin" --out "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin.signed" --legacy "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin.legacy_sig"
"C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -X utf8 -I "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sizes.py" --elf "C:\\Users\\isaac\\AppData\\Local\\Temp\\arduino\\sketches\\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.elf" --path "C:\\Users\\isaac\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin" --mmu "-DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000"
"C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/upload.py" --chip esp8266 --port "COM3" --baud "115200" "" --before default_reset --after hard_reset write_flash 0x0 "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/Blink.ino.bin"
esptool.py v3.0
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____....._____
My reply is getting hidden, but I am getting the same error after cycling the module. What info in the logs do you need to see?
Compiling sketch...
Compiling core...
Here is the top
"C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/mkbuildoptglobals.py" "C:\Users\isaac\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources" 10607 "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4" "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt" "C:\Users\isaac\AppData\Local\Temp\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\Blink/Blink.ino.globals.h" "C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266/CommonHFile.h"
Note: optional global include file 'C:\Users\isaac\AppData\Local\Temp.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\Blink\Blink.ino.globals.h' does not exist.
Read more at How to specify global build defines and options — ESP8266 Arduino Core 3.1.2-21-ga348833 documentation
Compiling sketch...
"C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/signing.py" --mode header --publickey "C:\Users\isaac\AppData\Local\Temp\.arduinoIDE-unsaved2024629-18796-h341gi.ep17p\Blink/public.key" --out "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core/Updater_Signing.h"
"C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core/build.opt" "-IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include" "-IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include" "-IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4/core" -c "@C:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" "-DARDUINO_BOARD_ID="d1_mini"" -DFLASHMODE_DIO "-IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266" "-IC:\Users\isaac\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\d1_mini" "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4\sketch\Blink.ino.cpp" -o "C:\Users\isaac\AppData\Local\Temp\arduino\sketches\BC44C6539AF92CD14675DF20D2C2A9E4\sketch\Blink.ino.cpp.o"
Compiling core...
Compiling sketch...
Compiling core...
esptool.py v3.0
Serial port COM3
That's it
Sorry if this is obvious, but are you holding down the Flash/Boot/Pgm button, NOT Reset. When you see Connecting press and hold that button (usually on the right) untill you see progress.
Even dumber question, where is it on the board I have? Do I have to hook it up a breadboard and connect a pin?
Looks like it. Here is what you need to know.
Must be LOW to enter Flashing mode, that means a switch with one side on G and the other on D3/GPIO0/Flash
bummer, this module didn't come with a breadboard and I don't have one handy
