I am trying to upload a sketch to an ATTiny85 using an Arduino Uno. I have done it previously but since updating the IDE to 1.6 I've had no luck.
Configuration
ATTiny85
Arduino Uno R2
Mac OS X 10.10.4
Arduino IDE 1.6.4
Steps
- Modify ArduinoISP sketch to have a heartbeat delay of 40
- Upload ArduinoISP sketch to Arduino Uno
- Connect ATTiny85 to Arduino Uno like this
- In the Arduino IDE
- Set the board to ATTiny85 @ 1 MHz
- Set progammer to "Arduino as ISP"
- Upload blink sketch
Results
It erased the blink sketch that was on the ATTiny85 and fails to write the new one. Heres the verbose output.
Sketch uses 710 bytes (8%) of program storage space. Maximum is 8,192 bytes.
Global variables use 9 bytes (1%) of dynamic memory, leaving 503 bytes for local variables. Maximum is 512 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -pattiny85 -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -Uflash:w:/var/folders/20/0kqxp2dx2n90121zr32rbjh00000gn/T/build4722774662855568999.tmp/Blink.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/clevererror/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1421
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.11s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/20/0kqxp2dx2n90121zr32rbjh00000gn/T/build4722774662855568999.tmp/Blink.cpp.hex"
avrdude: writing flash (710 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I've tried multiple ways of adding ATTiny support to the Arduino IDE but they all have the same result.
This is driving me crazy, any help would be appriciated.
