Unable to use digital read
Hi folks,
I'm experiencing a very weird behaviour on the nano 33 BLE SENSE.
I'm trying to read a simple button press, connected to pin D3 using a pulldown resistor. The value read, however, is always HIGH.
I tried swapping the nano BLE with other nano BLE and get the same result.
To check if the problem was in my wiring I also tried to upload the same sketch on a nano 33IOT and indeed the button works as expected
Setting the pin as INPUT_PULLUP and changing the wiring on the breadboard also produce the expected result.
If I measure the voltage on the pin when the button is open, instead of 0V I read 1.3 which really I don't understand.
Here is a picture of my wiring https://photos.app.goo.gl/a8qW3v6FSykh3L6R8
Could you please post your sketch? This might sound silly but could be important.
Please use code tags. Click Preview in the Quick Reply and use the </> button.
Hi Klaus_k.
I'm actually just using the simple digitalReadSerial example.
  DigitalReadSerial
  Reads a digital input on pin 2, prints the result to the Serial Monitor
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/DigitalReadSerial
// digital pin 2 has a pushbutton attached to it. Give it a name:
int pushButton = 3;
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  // make the pushbutton's pin an input:
  pinMode(pushButton, INPUT);
// the loop routine runs over and over again forever:
  // read the input pin:
  int buttonState = digitalRead(pushButton);
  // print out the state of the button:
  Serial.println(buttonState);
  delay(1);        // delay in between reads for stability
The sketch you posted and your exact circuit works as expected on my Nano 33 BLE Sense. I also get a ~1.3 V voltage reading across the pull-down resistor.
Does the problem occur on any pin, or only pin 3?
Thank you for reporting this. There is a PR to fix it. You can find it here
Indeed the PR solves the issue.
Thanks Arturo!
