Unable to verify or upload
I am unable to verify or upload any code i write in Adruino IDE.
After verifying this error mesage pops up.
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\kopar\AppData\Local\arduino\sketches\F214670560D1A97C928AC78DE9DFBA06\sketch\Blink.ino.cpp -o nul
Error while detecting libraries included by C:\Users\kopar\AppData\Local\arduino\sketches\F214670560D1A97C928AC78DE9DFBA06\sketch\Blink.ino.cpp
Generating function prototypes...
C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\kopar\AppData\Local\arduino\sketches\F214670560D1A97C928AC78DE9DFBA06\sketch\Blink.ino.cpp -o C:\Users\kopar\AppData\Local\Temp\1717587399\sketch_merged.cpp
exit status 0xc0000142
Compilation error: exit status 0xc0000142
This message pops up no matter what file i try to run.
I am using IDE verision 2.3.4 and Adruino Uno.
I even tried running something in visual studio code with PlatformIO.
Same error there.
I already tried uninstaling and re-instaling Adruino IDE.
Checked a lot of steps online and none worked.
I am running out of ideas.
Help would be greatly appreciated.
Start by reading the "how to post" etc. details at the top of the forum.
Then supply your code (in code brackets) show a circuit diagram of how the devices are connected showing pin numbers ( no fritzing) and whatever power supplies you are using.
Show how and what you are using to upload.
Did you also uninstall all the stuff that relates to Arduino? There is a variety of directories.
The following might solve the issue. Downgrade the AVR board package in board manager to version 1.8.3 and see if that solves the issue. Next you can upgrade again (to 1.8.6).
hi. Thanks for reply.
Uploading all code, circut and error message.
I am really sorry if this is stupid question ,but why i need to upload all code and circut? I am not an expert but i think this is something wrong in files, compiling or softwere , because as i said diffrent sketch doesnt change a thing.
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
my code is just example Blink
C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\kopar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\kopar\AppData\Local\arduino\sketches\F214670560D1A97C928AC78DE9DFBA06\sketch\Blink.ino.cpp -o C:\Users\kopar\AppData\Local\Temp\639624710\sketch_merged.cpp
Computer is only conected to adruino and thats it.
[quote="bluejets, post:2, topic:1345083"]
[/quote]
I am not sure what you want me to do.
Record a video?
Hi thanks for reply
Yeah I uninstaled those directories Adruino15 etc.
Thanks for the tip with downgradeing but unfortunately it didn`t work.
Here are the basic steps to begin to develop using the Arduino platform
  1. Install the latest IDE
    1. If using a board other than UNO and relatives, get and install the boards URL for that platform.
  2. Install any needed libraries.
  3. Select the board you want to use
  4. Select the port you want to use.
    Verify and Upload will now work
Hi @kamyq.
Try this experiment and then reply here to let us know what happened:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Right click the Windows "Start" button.
    A context menu will open.
  2. Select "Search" from the context menu.
    The Windows "Start" menu will open with a search field selected.
  3. Type windows powershell ise in the search field.
  4. Select "Windows PowerShell ISE" from the search results.
    A "Windows PowerShell ISE" window will open.
  5. Type the following command:
    & "C:\Users\kopar\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++.exe"
  6. Press the Enter key.
My hope is that either a dialog, or a message printed to the PowerShell terminal will now appear that will give a more helpful explanation of the problem than that cryptic "exit status 0xc0000142" error message you see when Arduino IDE runs the compiler. If so, please tell us the full and exact text from the dialog or terminal.
Hi
I tested this Windows PowerShell Ise Sugestion a few times and the result is always the same.
In the terminal nothing happens. But a window pops up
Sorry for another language. Let me translate:
avr-g++.exe-App error
The app was not started correctly (0xc0000142). Click OK button, to close the app.
This might be a problem with your Windows; see e.g. https://answers.microsoft.com/en-us/windows/forum/all/0xc0000142-application-unable-to-start-correctly/e5c4616b-a03c-45ec-b3af-067d61da2ad1
It might also be a problem with libraries; see https://www.reddit.com/r/arduino/comments/16pilvm/compilation_error_exit_status_0xc0000142/. If you don't have any libraries installed, it's unlikely that this is the cause (and downgrading/upgrading the AVR board package should have solved it). If you have libraries installed in the libraries directory of the sketchbook directory, try to uninstall them and see if the problem disappears.
More search results: https://www.google.com/search?client=firefox-b-d&q=avr-g%2B%2B+Compilation+error%3A+exit+status+0xc0000142
Hi ,
sorry for not replying earlier. I was testing everything i could think of.
Thanks for those tips ,but unfortunately none of them worked.
I have run System File Checker and DISM tool from the guide you linked and look at the reddit conversation you also linked but still nothing.
Although in the reddit post autor said he fixed the problem :
Thanks guys we managed to fix the problem after fixing a bit the code and checking some libraries
However as i said this error come up no metter what code i use.
I also tried re-installing again but no result.
I think i will use a laptop for now and just reinstal system.
If anyone have any idea , please help.
