Uncooperative scheduler
Hi everyone
I have a problem with the scheduler settings.
time zone set.
I created variable "prog" and assigned "CloudSchedule" from the variables menu.
In the dashboard I added a scheduler panel.
Until I connect the panel to the "prog" variable I can set times, days, repetition, expiration etc.
As soon as I connect the panel to the "prog" variable the time is not set.
I write the desired time and when I click Done I find the field filled in as hh:mm.
I have recreated the variable and the dashboard several times but I can't get it to work...
I hope someone can help me.
Hi @SPR42 I'm not able to reproduce your issue. Is your board connected? Can you send a short video to help me to replicate this behaviour?
I hope a wetransfer link is fine: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Otherwise, if you advise me where to upload it, I'll do it!
Thanks @SPR42, I was able to replicate the issue. Looks like the bug happens only if you select TimeOnly in scheduler configuration.
Using date and time works.
I will write you as soon as the issue is fixed in the meanwhile you can use date and time configuration.
@SPR42 The issue with the cloud scheduler widget should be fixed.
