LightuC:
Post the code and don't attach the files. I'm not willing to download them on my mobile device.
Maybe you should suggest #8 in How to use this forum - please read to be changed
LightuC:
You have declared the variable to the compiler (there is a variable of type NaturFade and it is called NatureFadeIR somewhere). The compiler then compiles happily, because it trusts you and your declaration. Then the linker comes in and wants to resolve the addresses necessary to use the variable, but it can't find the variables definition anywhere.
Ok, I guess I understand what you explain. But I thought, "NatureFade" is definied in the main class.
NatureFade.cpp:
NatureFade.h - Library für natürliche Fades mit Adafruit NeoPixels - implementation
2020 © MH
#include "Arduino.h"
#include "Adafruit_NeoPixel.h"
#include "TimerInterrupt.h"
#include "NatureFade.h"
Adafruit_NeoPixel LEDs;
NatureFade::NatureFade(byte _PinN, byte _Count) {
_LastFastMillis = millis();
_LastSecond = _LastFastMillis / 1000;
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
_NUMPIXELS = _Count;
_PIN = _PinN;
void NatureFade::begin() {
LEDs.updateType(NEO_GRBW + NEO_KHZ800);
LEDs.updateLength(_NUMPIXELS);
LEDs.setPin(_PIN);
LEDs.begin();
void NatureFade::DoUpdate() {
FastSunFade();
_NowSecond = millis() / 1000;
if (_NowSecond > _LastSecond) {
_LastSecond = _NowSecond;
SunRise();
void NatureFade::AllowBreakActiveFade(bool _allow) {
_BreakActiveFade = _allow;
bool NatureFade::NoFadingActive() {
return !(_FastFading || _SunRising);
void NatureFade::StartSunRise(unsigned long _SRDuration) {
if (_BreakActiveFade) {
StopAllFades();
if (NoFadingActive()) {
_SunRiseDuration = _SRDuration * 60;
_DestSecond = _LastSecond + _SunRiseDuration;
_SunRising = true;
void NatureFade::StartFastFade(bool _Direction, unsigned long _Pause) {
StopAllFades();
_FastFIndex = 0;
_FastFading = true;
_FastFDirection = _Direction;
_FastFPause = _Pause;
void NatureFade::StopAllFades() {
_SunRising = false;
_FastFading = false;
_FastFIndex = 0;
void NatureFade::FullBlank(bool _Blank) {
StopAllFades();
if (_Blank) {
LEDs.fill(LEDs.Color(0, 0, 0, 0));
else {
LEDs.fill(LEDs.Color(255, 255, 255, 255));
LEDs.show();
void NatureFade::FastSunFade() {
if (_FastFIndex == 255) {
_FastFIndex = 0;
byte _i;
if (_FastFading) {
unsigned long _NowFastMillis = millis();
if (_NowFastMillis > _LastFastMillis + _FastFPause) {
_LastFastMillis = _NowFastMillis;
if (_FastFDirection) {
_i = _FastFIndex;
else {
_i = 255 - _FastFIndex;
LEDs.fill(LEDs.gamma32(LEDs.Color(_i, _i, _i, _i)));
LEDs.show();
_FastFIndex++;
void NatureFade::SunRise() {
if (_NowSecond > _DestSecond) {
_SunRising = false;
if (_SunRising) {
LEDs.fill(SunRiseColor(GetFactorWithGamma(GetQuotient(_SunRiseDuration))), 0, _NUMPIXELS);
LEDs.show();
uint32_t NatureFade::SunRiseColor(int i) {
byte gir, gig, gib, giw;
switch (i) {
case 0 ... 44:
gir = LEDs.gamma8(i);
gig = LEDs.gamma8(i/3.0);
return LEDs.Color(gir, gig, 0, 0);
case 45 ... 99:
return LEDs.Color(gir, gig, 0, 1);
case 100 ... 124:
gig = LEDs.gamma8((i-100)*1.427586207+33);
gib = LEDs.gamma8((i-100)*1.503448276);
return LEDs.Color(gir, gig, gib, 2);
case 125 ... 154:
giw = LEDs.gamma8((i-125)*1.946153846+2);
return LEDs.Color(gir, gig, gib, giw);
case 155 ... 199:
case 200 ... 244:
gib = LEDs.gamma8((i-200)*2.111111111+155);
case 245 ... 255:
gig = LEDs.gamma8(240);
gib = LEDs.gamma8(245);
default:
return 0;
byte NatureFade::GetFactorWithGamma(float _Quotient) {
return round(_Quotient * 232.0 + 23);
float NatureFade::GetQuotient(unsigned long _Duration) {
float _QNow = _Duration-(_DestSecond-(millis()/1000));
float _QDest = _Duration;
return _QNow / _QDest;
NatureFade.h:
NatureFade.h - Library für natürliche Fades mit Adafruit NeoPixels - description
2020 © MH
#ifndef NatureFade_h
#define NatureFade_h
class NatureFade {
friend class TimerInterrupt;
private:
int _NUMPIXELS, _PIN;
bool _BreakActiveFade = true;
bool _FastFading, _SunRising = false;
unsigned long _LastSecond, _NowSecond, _DestSecond, _LastFastMillis = 0;
unsigned long _SunRiseDuration, _SunDownDuration, _FastFPause;
byte _FastFIndex = 0;
bool _FastFDirection;
void DoUpdate();
void FastSunFade();
void SunRise();
uint32_t SunRiseColor(int i);
byte GetFactorWithGamma(float _Quotient);
float GetQuotient(unsigned long _Duration);
public:
NatureFade(byte _PPinN, byte _Count);
void begin();
void AllowBreakActiveFade(bool _allow);
bool NoFadingActive();
void StartSunRise(unsigned long _SRDuration);
void StartFastFade(bool _Direction, unsigned long _Pause);
void StopAllFades();
void FullBlank(bool _Blank);
#endif
TimerInterrupt.cpp:
TimerInterrupt.cpp - implementation
2008 © Ron Kreymborg
from https://www.mail-archive.com/avr-libc-dev@nongnu.org/msg02454.html
2020 adapted by MH
extern NatureFade NatureFadeIR;
TimerInterrupt::TimerInterrupt()
OCR0A = 0xAF;
TimerInterrupt::~TimerInterrupt()
TIMSK0 &= ~_BV(OCIE0A);
void TimerInterrupt::OnInterrupt()
NatureFadeIR.DoUpdate();
TimerInterrupt.h:
2020 adapted by MH
#define STRINGIFY(name) #name
#define CLASS_IRQ(name, vector) \
static void name(void) asm(STRINGIFY(vector)) \
__attribute__ ((signal, __INTR_ATTRS))
#ifndef TimerInterrupt_h
#define TimerInterrupt_h
class TimerInterrupt {
private:
CLASS_IRQ(OnInterrupt, TIMER0_COMPA_vect);
public:
TimerInterrupt();
~TimerInterrupt();
#endif
UKHeliBob:
@MdE2020 - be very careful that you don't get banned for starting a duplicate topic.
I'm sorry I didn't know duplicate posting is a "capital offence" here, in spite of searching I wasn't even able to find the old thread, fortunately I had the draft on my computer. Thank you for merging (really).
